Dear Madam/Sir,
At present time, I port IOC codes from VxWorks to LynxOS/x86 platform.
I emulate VxWorks calls by LynxOS features.
I attach the list emulated VxWorks calls to end this letter. I do not
emulate some libraries supports BSP calls. Because this functions would be
executed by UNIX drivers. I do not compile iocCore completely yet.
Now I port data base, and I find difficulty in doing 'symbol table
subroutine library'.
EPICS uses following symLib calls:
1) symFindByNameEPICS(...) is equal to symFindByName(...)
2) symFindByNameAndTypeEPICS(..)is equal to symFindByNameAndType(...)
3) symFindByValue(...)
4) symTblCreate(...)
5) symAdd(...)
6) symRemove(...)
EPICS uses sysSymTbl as pointer to symbol table. I do not find <creation
of symbol table> in IOC codes.
1-st question :
IOC uses system symbol table which spawned by
tornado/target/config/mv167/symTabl.c
Is it correct?
2-nd question:
How can search a pointer (or address) this symbol table in vxWorks?
I guess that I can read all SYMBOL structures from this table and create
area with same structure in iocCore. This area will contain only EPICS
entries from symbol table.
So, tornado/target/config/mv167/symTabl.c contains
SYMBOL standTbl[2424] { ... ,};
vxWorks uses definitions
typedef SYMTAB *SYMBAB_ID;
SYMBAB_ID sysSymTbl;
Please, explain , is the pointer of standTbl disposed in struct
symtab SYMTAB?
If you will interest this IOC development at LynxOS, I will glad to
transfer this codes to you. And I will hear your comments about this work.
Thanks.
Best Regards,
Tatiana
Budker Institute of Nuclear Physics
prospekt Lavrentev 11
630090, Novosibirsk, RUSSIA
fax +7 3832 342163
phone +7 3832 394977
1 bLib.h IT WORKS
rsrv/caservertask.c
cast_server.c
online_notify.c
bfill()
2 bootLib.h IT WORKS
This library is used by
db/drvTS.c
bootStringToStruct() is equal to
gettimeofday()
libvxWorks/iocLogClient.c
dev/...
drv/...
3 dbgLib.h IT does not WORKS
This lybrary is used by
ca/os_depen.h
4 errnoLib.h IT WORKS
5 envLib.h IT WORKS
EPICS uses putenv & getenv only
6 fioLib.h IT WORKS
db/db_access.c
EPICS can uses
vprintf <stdio.h>
vsprintf <varargs.h>
7 hostLib IT does not WORKS
Only libCom/os/vxWorks/bsdSockResource.c uses
hostGetByAddr
hostGetByName
8 inetLib.h IT WORKS
it is analog of LynxOS libbsd
Differences:
inet_ntoa_b
9 intLib.h IT does not WORKS
UNIX drivers executes this functions ONLY!!!
db/callback.c
db/dbScan.c
db/devLibVxWorks.c
db/drvTS.c
libCom/errlogVX.c
libvxWorks/bus_error_recovery.c
libvxWorks/timerLib.c
libvxWorks/veclist.c
dev/...
drv/...
10 ioLib.h IT WORKS
contains close(), create(), ioctl() ...
Differences:
sequencer/seq_main.c uses ioGlobalStdGet()
it changes the assignment of spec file
descriptions: 0 - input, 1 - output, 2 - error
11 iosLib.h IT does not WORKS
src/devOpt/
src/dev/apsDev
src/dev/vxStatusDev
src/drv/old
12 logLib.h IT WORKS
13 lstLib.h IT WORKS
14 memLib.h IT WORKS
15 moduleLib.h IT does not WORKS
libvxWorks/ldpp.c
libvxWorks/ldpp_new.cc
16 msqQLib.h IT does not WORKS
17 rebootLib.h IT WORKS
dev/...
drv/...
18 remLib.h IT WORKS
ca/vxWorks_depen.c
19 rngLib.h IT WORKS
20 selectLib.h IT WORKS
EPICS uses select only
select() witch is same as LynxOS select()
21 semLib.h IT WORKS
22 sockLib.h IT WORKS
It provides 4.3 BSD socket calls
DIFFERENCES:
libvxWorks/iocLogClient.c uses connectWithTimeout()
23 stdioLib.h containes "stdio.h" only
24 strLib.h containes "string.h" only
25 symLib.h IT does not WORKS
26 sysLib.h IT WORKS
sysClkRateGet was done,
other calls supports BSP of VxWorks
27 taskHookLib.h IT WORKS
28 taskInfo.h IT WORKS
29 taskLib.h IT WORKS
30 tasVarLib IT does not WORKS
ca/os_depend.h
vxWorks_depen.c
access.c
sequenser/seq_ca.c
seq_task.c
31 tickLib.h IT WORKS
32 timerLib.h IT does not WORKS
drv/ansi
33 timexLib.h IT does not WORKS
timexN is used by db/dbTest.c only.
34 usrLib.h IT WORKS
Big part of this library contains standard UNIX set calls
libvxWorks/ldpp.c
rsrv/caservertask.c
rsrv/cast_server.c
rsrv/rsrv_init.c
sequencer/seq_qry.c
35 vxLib.h IT does not WORKS
routines from BSP of VxWorks
ca/os_depen.h
db/dbBkpt.c
db/dbAccess.c
db/dbEvent.c
db/dbFastLinkConv.c
db/dbScan.c
db/devLibVxWorks.c
db/fast_lock.h
db/taskwd.c
libCom/errlogVX.c
rec/recDynLink.c
rec/recWaitCa.c
rsrv/server.h
dev/...
drv/...
36 wdLib.h IT WORKS
- Re: symLib Andrew Johnson
CapFast source code release Dr. Chong Lee
drvGpib.c Ned Arnold
<1999>
2025
2026
<1999>
2025
2026
