on Page93, chap 7,sect5 of EPICS IOC Application Developer's Guide,it says,
"get_array_info() function returens the CURRENT number of elements and
the offset of the first value of the
specified array".
In other words, no_elements which get_array_info() return may be
smaller than the maximu size of this array.
Now, ca library compares requested elements count with privCount field
of channel structure and
it rejects request when the requested count is larger than privCount.
privCount field is updated only when
channel is (re) connected. i.e. you cannot request loger array data
than the size of array which get_array_info
when your channel is connected with the Database.
In our application , the CURRENT number of elements of SubArray records
can vary time to time.
However, application program cannot read an array data longer than the
element count which is a element count
at the time channel is connected. It may loose data and its size cannot
be predictable.
Does anyone encounterd similar problem? Or have you solved this problem?
Ragards,
Noboru Yamaoto
KEKB control Group
KEK, JAPAN
- RE: Array Information Jeff Hill
RE: Channel Access Gateway software Jeff Hill
[Re: drvGpib.c] Noboru Yamamoto
<1999>
2025
2026
FW: MVME162 Bug in system clock Jeff Hill
<1999>
2025
2026
