1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Array Information
To: Jeff Hill <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 11 Aug 1999 11:40:12 +0900
Jeff Hill wrote:
> Hi Noboru,
> When channel access connects to the process variable it is provided
> with the maximum number of array elements by the "dbAddr" structure
> which is filled in by the "cvt_dbaddr" record support routine. As
> you have correctly observed the client library will not allow the
> client program to send get or put requests for more than this maximum
> number of elements, and a new maximum is only discovered when the
> client reconnects.
> Here is an extract from the cvt_dbaddr() function from the subArray
> record:
> static long cvt_dbaddr(paddr)
>     struct dbAddr *paddr;
>     if (!psa->udf && psa->nelm > psa->nord)
>        paddr->no_elements = psa->nord;
>     else
>        paddr->no_elements = psa->nelm;
> So we can see that the NELM and the NORD field are used to provide this
> maximum.
ubarray Record has three fields related size of array, i.e. MALM, NORD, NELM.
According to REcord reference mannual, each fields has following meanig.
MALM : Maximum number of Elements in sub-array.
NELM  : Number of Elements in sub-array.
NORD  : Number of Elements read.
Usually, MALM is equal to NELM (Larger  MALM than NELM is possible).
So you can say NELM field is a maximum number of elements in a sub-array.
In our application, NORD may vary time-to-time. (NORD should be less than
or equal to MALM=NELM).
If you use cvt_dbaddr routines from running database, it retuns NORD filed
as a number of elements in a sub-array, and it is NOT the MAXIMUM number
of elements in a sub-array(MALM=NELM)
> Is it possible to just set the maximum value in these fields to be greater
> the maximum number of elements that will at any time be used in your
> system?
We  set MALM and NELM to the maximum number of elements in the application.
NORD may vary time-to-time, depending on the state of the device.
(We collect data from the device periodically. Number of record
accumulated
in each period may vary , 1 or 2).
The problem is that CA picks a number of elements in an array at one
point and use it as a maximum number of elements in the array.
It will be OK if CA can get  the MAXIMUM number of elemetns correctly
when channel is open.
> If not I am open to discussing relaxing this restriction so that the
> client can send get and put request for more than the maximum provided
> at connect time. In this situation the database access layer will be
> responsible for detecting, and refusing, out of bounds requests.
I think dbAccess layer routines and/or record access routines checks
size of array already. Am I wrong?
> The primary
> drawback will be that client applications that use put and get requests
> that do not receive a call back on IO completion may have more trouble
> determining which get/put has failed when several get/put(s) occur
> together, and the wrong number of elements is specified.
Or user should check size of sending data explicitly before
CA request.
> Jeff
Noboru
> > on Page93, chap 7,sect5 of EPICS IOC Application Developer's
> > Guide,it says,
> > "get_array_info() function  returens the CURRENT number of elements and
> > the offset of the first value of the
> > specified array".
> > In other words,  no_elements which get_array_info() return may be
> > smaller than the maximu size of this array.
> > Now, ca library compares requested elements count with privCount field
> > of channel structure and
> > it rejects request when the requested count is larger than privCount.
> > privCount field is updated only when
> > channel is (re) connected. i.e. you cannot request loger array data
> > than the size of array which get_array_info
> > when your channel is connected with the Database.
> > In our application , the CURRENT number of elements of SubArray records
> > can vary time to time.
> > However,  application program cannot read an array data longer than the
> > element count which is a element count
> > at the time channel is connected. It may loose data and its size cannot
> > be predictable.
> > Does anyone encounterd similar problem? Or have you solved this problem?
> > Ragards,
> > Noboru Yamaoto
> > KEKB control Group
> > KEK, JAPAN
RE: Array Information Jeff Hill
Prev: RE: Array Information Jeff Hill
Next: RE: Array Information Jeff Hill
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
