It seems the routing is in fact getting screwed up in some way. What seems
to work is to add "routeAdd" lines to the ioc startup w/ the most necessary
workstations. This has been working for an hour or so thus far. Thanks for
everyone's help.
Dale
At 01:14 PM 8/25/99 , Maren Purves wrote:
Dale,
yes, the routers could act differently depending on how they are/were
programmed. We don't use "routeAdd" as long as we stay on the same
subnet. I just looked up an old startup file where the ioc (temporarily,
we were still testing then) was on a different subnet than the devices
it was connected to, and in that case we used a routeAdd that had the
router's address and the subnet specified.
My understanding is that a routeAdd "0" , "x.x.x.x" tells the router
that all traffic is going "out" (and the programming of the router
decides whether "out" really means "out" or not).
Maren Purves
Dale L. Brewe wrote:
> Chip
> Well, something along these lines seems plausible, I guess, altho the
> gateway has not changed, nor have the ioc parameters. However, these
> problems surfaced a few days after a new main switch/router was installed.
> Clearly the problem seems to be at a pretty basic level, as I have troubles
> pinging the ioc with no CA clients running. I haven't found anything that
> looks bad in either hardware or software. In the ioc startup, I have
> routeAdd "0", "x.x.x.x" for our subnet gateway. Is this correct? It worked
> before, but could the routers be acting differently for some reason?
> Dale
> At 08:08 AM 8/25/99 , Chip Watson wrote:
> >Dale,
> >Your problem is similar to one I tracked down at PSI. If you
> >have a gateway (default routing node) improperly set in the
> >boot parameters of the IOC, then the following scenario can
> >happen:
> >(1) the first client connects, but the ioc sends all traffic for
> >that client through the gateway
> >(2) the gateway eventually sends a message to the ioc telling it
> >what the correct ethernet address for that host is (it doesn't want
> >to carry traffic unnecessarily)
> >(3) the ioc mistakenly updates the gateway address instead of
> >installing an explicit host entry
> >(4) the second client connects, and the ioc attempts to route
> >all traffic through the gateway again, but now it uses the
> >"updated" address for the gateway, which is client one
> >(5) client one refuses to forward the packets (lazy, huh?), so
> >the ioc appears to drop off the net for everyone except the
> >first client to have connected
> >Log into the ioc via the console if you can, and you can watch
> >this scenario play out. Then, check your boot parameters and
> >either fix or remove the gateway entry.
> >Chip
Dale L. Brewe PNC-CAT/U. of Washington
ph: 630 252 0582 fax: 630 252 0580
Mail:
Argonne National Laboratory/APS
Bldg 435E sector 20
9700 S. Cass Ave.
Argonne, IL 60439
- network problem w/ ioc Dale L. Brewe
- Re: network problem w/ ioc Dale L. Brewe
- Re: network problem w/ ioc Maren Purves
Re: bug in EPICS R3.13 and R3.12 Kenneth Kang
RE: network problem w/ ioc Jeff Hill
<1999>
2025
2026
<1999>
2025
2026
