Stephanie,
> This was exactly how I fixed it to begin with but then discovered that I
> got into an infinite loop where select would always return a bad status
> complaining about a bad file-descriptor. Zeroing the fd sets on
> bad status
> got rid of this problem. But I'll continue to watch out for it.
I don't think that select() will complain if a valid socket (which
has not been closed) is used. Since there is an FD_CLR() in
fdManager::removeReg() which is called by the fdReg destructor,
then the bit in the file descriptor mask will be properly cleared
as long as the fdReg object is destroyed by the application whenever
the corresponding socket is closed by the application.
It is possible that select() could return frequently with
SOCKERRNO == SOCK_EINTR if there are UNIX signals in use. Therefore,
I am somewhat reluctant to add the FD_ZERO() that you suggest
because this introduces considerable overhead looping through
three potentially large file descriptor mask sets.
Even if I add the code that you suggest, there will still be
trouble if the fdReg object persists after the file descriptor
has been closed because I loop through the installed
fdReg objects and set the corresponding bits in the masks in
fdManager::process() just before select() is called.
In summary:
If you are creating fdReg objects then be careful that they
are always deleted when the file descriptor is closed. Otherwise,
this must be originating from the server library (a
quick look at the current source does not reveal any
obvious cause). Let me know if the problem persists.
Jeff
- Re: fdManager.cc question saa
Re: IOC Benjamin Franksen
RE: One CA server question Jeff Hill
<1999>
2025
2026
Tornado on HPUX - Base config bug Ralph Lange
<1999>
2025
2026
