> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> Sent: Wednesday, September 01, 1999 12:48 PM
> To: [email protected]
> Subject: One CA server question and one CA server problem
> To people running portable CA servers:
> Question: I've recently added diagnostics to my CA server to keep track
> of the last 10 PVs broadcast to me that don't exist on
> my server.
> I also keep a counter of the number of times non-existent PVs
> are requested and the time of the last request. I see I'm being
> bombarded constantly with many PVs that belong on a totally
> different control system (BaBar - and a different subnet). So
> there is a leak somewhere (probably the gateway).
> Besides shutting
> down each client until the problem goes away, are there other
> less invasive techniques for finding "noisy" clients?
1) In the old server you can type "CASDEBUG = NNN" from the vxWorks shell,
and
in the new server you can set the debug level from the command line.
2) From the vxWorks shell you can frequently type "dbcar 1" at the vxWorks
shell prompt to see the unresolved DB links. There is a similar command in
the
sequencer - as I recall it is call "seqShow".
3) I frequently use the Solaris command "snoop dstport 5064" to watch the
UDP name resolution traffic. The command "snoop dstport 5065" can be used
to watch the server beacons on your LAN. You will typically need to be root
to run this program.
> The server
> runs on a VMS system with Multinet (there may be some Multinet
> tool...).
As I recall Multinet supplies a similar facility to Solaris's "snoop" called
tcpdump.
Jeff
- One CA server question and one CA server problem saa
RE: One CA server question Jeff Hill
Job Opening at Argonne/APS Bill McDowell
<1999>
2025
2026
Arrays and portable channel access server Tony Cox - (415)926-3105
<1999>
2025
2026
