1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: One CA server question and one CA server problem
To: [email protected]
Date: Wed, 01 Sep 1999 11:47:55 -0700 (PDT)
To people running portable CA servers:
Question:  I've recently added diagnostics to my CA server to keep track
           of the last 10 PVs broadcast to me that don't exist on my server.
           I also keep a counter of the number of times non-existent PVs
	   are requested and the time of the last request.  I see I'm being
           bombarded constantly with many PVs that belong on a totally
           different control system (BaBar - and a different subnet).  So
           there is a leak somewhere (probably the gateway).  Besides shutting
           down each client until the problem goes away, are there other
           less invasive techniques for finding "noisy" clients?  The server
           runs on a VMS system with Multinet (there may be some Multinet
           tool...).
Problem:   My server was freezing about once a week.  I tracked the problem
           down to a rare bad status return from the select call in the process
           function in the fdManager.cc file.  I have changed it so that
           all fd sets are zeroed and return is done if there is ANY bad status
           from select.  I have not seen the freeze since correcting this
           problem though I'll continue monitoring.  Here is a snippet with
           the change for anyone interested:
	if (ioPending) {
		status = select (this->maxFD, &this->fdSets[fdrRead],
			&this->fdSets[fdrWrite], &this->fdSets[fdrExcp], &tv);
	else {
		status = 0;
	if (waitPending) staticTimerQueue.process();
	if (status<=0) {
		for (size_t i=0u;
		     i<sizeof(this->fdSets)/sizeof(this->fdSets[0u]); i++) {
			FD_ZERO(&this->fdSets[i]);
		if ((status < 0) && (SOCKERRNO != SOCK_EINTR)) {
			fprintf(stderr,
			"fdManager: select failed because errno=%d=\"%s\"\n",
				SOCKERRNO, SOCKERRSTR);
		this->processInProg = 0;
		return;
Thanks for your help!  Sorry I'm missing you all at ICALEPCS.
Stephanie Allison
Re: One CA server problem Ralph Lange
Re: One CA server question Ralph Lange
RE: One CA server question and one CA server problem Jeff Hill
Prev: workQPanic! Oh no! Mark M. Ito
Next: Re: workQPanic! Oh no! Tim Mooney
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: workQPanic! Oh no! Tim Mooney
Next: Re: One CA server problem Ralph Lange
