re...,
> I know that this is probably a VxWorks question, but what exactly does
> workQPanic: Kernel work queue overflow.
> mean? We note a perfect correlation with IOC crashes ;). Running
> R3.13.0beta11 and VxWorks 5.2 on a MVME162-532A, 16 MB, not obviously near
> the memory limit, not totally CPU limited either. Running lots of
> sequences, for what that's worth.
> -- Mark
> Mark M. Ito, Thomas Jefferson National Accelerator Facility
Too many interrupts. The perfect correlation with IOC crashes is not
coincidental.
John Winans got off on a rant on this subject several years ago. Here's the
part of his reply that was on point, or at least in the vicinity of the point:
>> ...The only workQPanic stuff I am
>> aware of is based on the fact that VW uses a ring buffer to collect a
>> list of junk to do 'next'. It backically contains a list of semaphores
>> that need to be 'given' now. The reason they have this set up this way
>> is because they are idiots and don't know enough to write code that
>> scales properly. You see, this ring buffer is a fixed size (engenius
>> eh?) and it can fill up if it decides to defer the giving of these
>> semaphores.
>> Well, the only time these semaphore 'give' operations are deferred is
>> when a semGive() is in an interrupt handler. Thus this message means
>> that there were too many semGive()s that happened in a narrow time in
>> one or more interrupt handlers. Where a "narrow time" is one where not
>> enough time has elapsed to let the cpu run the code to complete all the
>> semGive()s.
>> Personally, I think the boyz at VW are idiots because it is not very
>> hard to replacethe code that currently looks like this:
>> if (ringAroundTheCollarBufferIsFull)
>> panic;
>> else
>> addMoreCrapTo(ringAroundTheCollarBuffer, crap);
>> with code that is more sensable and truely useful in the real world that
>> might look more like this:
>> flushTheDamnThing(ringAroundTheCollarBuffer);
>> consoleWrite("WARNING: ring buffer overflow\");
>> Yah, it is a bad thing to do list-processing and large amounts of work
>> at an interrupt level, but it sure beats asserting a panic()!!!!
>> Now, the way I deal with this misfeature is to figure out what IRQs might
>> be generated at the time that it dies... it is usually fairly easy
>> because you can normally narrow things down to some single device that
>> is being used or saturated at the panic moment... that driver is the
>> one that is generating too many IRQs.
>> The most common occurrance of this that I have seen is caused by using
>> raw (non-debounced) binary inputs on a card whose driver is configured
>> to generate interrupts on input transitions. It is pretty much a
>> guarentee to panic the beast. The second easy way to do it would be to
>> enable IRQ processing of global events on Frank Lenksus's global event
>> boards... and then generating a boat-load of events with the event code
>> numbers of those enabled IRQs... I wrote the code... I know it will
>> fail if not configured properly. I have caused it to do so while bench
>> testing.
>> Groovus?
>> --John Winans
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab
One CA server question and one CA server problem saa
Arrays and portable channel access server Tony Cox - (415)926-3105
<1999>
2025
2026
workQPanic! Oh no! Mark M. Ito
<1999>
2025
2026
