Notice to anyone using CrossWind in "system" mode with EPICS.
There is a bug. CrossWind crashes in "system" mode when the
target system has task names with embedded spaces (e.g.,
"CA TCP", "EV dbCaLink", etc.).
Wind River has issued an SPR on this (#28322), but for some
reason, they have not yet put it on their Wind Surf web
site. Eventually, I should get a response from Wind River
as to what a valid task name is in the context of the Tornado
tools.
The following is part of an e-mail I sent to
a Wind River tech support person. It describes the
problem in some detail.
> In the file $WIND_BASE/host/src/vxgdb/gdb/remote-wtx.c
> is a function "taskListBuild()".
> As described in taskListBuild()'s header, this function
> "builds an internal list of tasks running on the target".
> Also described in taskListBuild()'s header,
> * This query should return a list of the following information for
> * each task:
> * id, name, stack base, stack end and a pointer to the integer
> * register block
> Unfortunately, taskListBuild() does not handle task names with
> embedded spaces well. Below is a memory dump of "taskInfo".
> Note the last two task entries. taskListBuild() gets all out
> of synchronization on the "taskInfo" data block when it encounters
> a task name with embedded spaces. The result is that strtoul()
> is passed a "value" = NULL; and when it tries to read the string,
> the following error occurs.
> Program received signal SIGSEGV, Segmentation fault.
> 0xef5ce9e8 in strtoul ()
> 0x2c4c08: "0x7e8480 tExcTask 0x7e8480 0x7e6540 0x7e85ac
> 0x7e5b6c tLogTask 0x7e5b6c 0x7e47e4 0x7e5c98
> 0x70b684 cbLow 0x70b684 0x708b8c 0x70b7b0
> 0x7089e8 cbMedium 0x7089e8 0x705ef0 0x708b14
> 0x60a170 cbHigh 0x60a170 0x607678 0x60a29c
> 0x6074d4 dbCaLink 0x6074d4 0x6049dc 0x607600
> 0x5fc828 {CA repeater} 0x5fc828 0x5fb440 0x5fc954
> 0x5f50a4 {EV dbCaLink} 0x5f50a4 0x5f3cbc 0x5f51d0"
> I searched VxWorks documentation and found a similar problem
> reported in SPR# 8615. But that document says;
> "FIXED ON: Jan 20 1998", so this may be a different problem.
> One question I have (from which I don't expect an answer) is;
> Why does this error only show up on my application when CrossWind
> is in system mode?
> My workaround is, of course, to eliminate embedded spaces in
> all task names. Hopefully, Wind River will either fix this or
> redefine valid task names in future releases.
curious OMS58 Problem / Waveform-Size-Limitation Jens Eden
Re: curious OMS58 Problem / Waveform-Size-Limitation Andrew Johnson
<1999>
2025
2026
Tornado Tool usage. Ron Sluiter
CAN Bus hardware/interface suggestions? Please? Bill Brown
<1999>
2025
2026
