1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: The problem in mvme162 to access A32 space for STR7201 board.
To: [email protected]
Cc: [email protected], [email protected]
Date: Thu, 7 Oct 1999 7:25:38 -0500
Hi Vladislav,
> I work with mvme162 CPU board (16MB), EPICS R3.13, vxWorks version 5.3.1.
> I encounted problems when I started to work with STR7201 board (32 Channel
> VME Multiscaler). I used MCA Record, corresponding devSTR7201.c device
> Support and drvSTR7201.c driver.
> It is recommended to work with this board in A32 addressing
> mode. But any attempts to acceess the board registers in this mode
> caused Bus error.
Please check something on the board first:  I believe the STR7201 has switches
to enable A32, A24 and A16 address modes, and the factory configuration is to
set them all to ENABLED.  Make sure you disable A24 and A16.  Are you using
the STR7201 from Struck, or the SIS3801 from SIS, which is essentially an
identical model, but with some additional features?
I have several of the SIS3801 boards, but so far I have been using them with
MVME167 CPUS.  I do have an IOC with the same setup you have (mvme162 16MB,
EPICS R3. 13.1.1, vxWorks 5.3.1), so I will try it today and let you know.  I
can also borrow a real STR7201 to test that as well.
Note that I have updated devSTR7201.c and drvSTR7201 to take advantage of the
new features of the SIS38xx boards, namely the on-board 10 MHz clock and the
prescaler.  With the SIS38xx you can select internal or external channel
advance and a prescaler to be applied to either channel advance input.
Mark Rivers
Prev: The problem in mvme162 to access A32 space for STR7201 board. Vladis Korobov
Next: Re: The problem in mvme162 to access A32 space for STR7201 board. Andrew Johnson
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: The problem in mvme162 to access A32 space for STR7201 board. Andrew Johnson
Next: problem w/ 3.13.1 -> 3.13.1.1 Dale L. Brewe
