1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: iocCore port
Date: Tue, 12 Oct 1999 14:13:02 -0600
Dear all,
We are considering the use of real-time Linux (RTL or RTAI) as the
environment for iocCore in the upcoming Magdalena Ridge Observatory optical
interferometer project.
Anyone else thinking about similar lines?
Aloha,
	Peregrine
Peregrine M. McGehee
Coordinator, Los Alamos Astrophysics
Sloan Digital Sky Survey		APT/LEDA Controls
(505) 667-3273 			MS H820, LANL, Los Alamos, NM 87545
-----Original Message-----
Sent:	Friday, September 10, 1999 2:06 PM
To:	[email protected]
Subject:	iocCore port
Work on porting iocCore to other operating systems besides vxWorks is
progressing.
The following has been accomplised
Almost all of base except Channel Access, the sequencer, and hardware
support
has been changed to use the new osi routines rather than vxWorks specific
calls.
I have not touched Channel Access becuse this needs help from Jeff Hill.
William
Lupton is already working on a version of the sequencer that is independent
of
vxWorks. The hardware dependent code will be unbundled from base.
Janet Anderson has modified the make system so that it works for non
vxWorks IOC
targets. The new system is actually easier than the old.
Using the new osi independent code the example application generated by
makeBaseApp has been run successfully. This was a major milestone.
A document describing the iocCore port is attached. Note that to port to
other
systems only the libraries osiSem and osiThread need to be implemented. It
should be possible to implement these using posix calls. If this is done we
should be able to run iocCore on many platforms.
Marty Kraimer
RE: iocCore port Thomas Fechner
Prev: Re: DTYP + Link order Andrew Johnson
Next: Opportunity for CapFast Site License Dr. Chong Lee
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: iocCore port Marty Kraimer
Next: RE: iocCore port Thomas Fechner
