1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VxWorks reliable source level debugger
To: [email protected]
Date: Tue, 19 Oct 1999 08:47:06 -1000
X-Sun-Data-Type: text
X-Sun-Data-Description: text
X-Sun-Data-Name: text
X-Sun-Charset: us-ascii
X-Sun-Content-Lines: 52
At Keck we just installed Data Display Debugger (DDD), which is a public
domain GUI debugger front-end.  It interfaces to many lower level debuggers
including gdb, dbx, jdb, python, and perl.  DDD comes from the Technical
University of Braunschweig in Germany.
See: http://www.cs.tu-bs.de/softech/ddd
In addition to the standard features of your underlying debugger it
also supports graphical display of data, plotting of array and scalars
and multi-level undo and redo.
If it is specifically a crosswind problem that you're experiencing then
this bypasses crosswind.  However if you're having problems with WindRiver's
version of gdb then this may not help becuase you'll still be using the
same version of gdb.
Attached is a pdf file I wrote for use by us at Keck.  It should
guide you in invoking ddd and linking to vxWorks.  Installation of
ddd is left up to you.  Again, since we just installed it here it
has not undergone rigourous usage.
Hope this helps...
Kevin Tsubota
California Assoc. for Research in Astronomy
W.M. Keck Observatory
ph: (808)885-7887
email: [email protected]
> From [email protected] Tue Oct 19 07:30:26 1999
> Date: Tue, 19 Oct 1999 12:23:18 -0500
> From: Carl Schumann <[email protected]>
> Subject: VxWorks reliable source level debugger
> MIME-version: 1.0
> X-Mailer: Mozilla 4.6 [en] (WinNT; I)
> Content-transfer-encoding: 7bit
> X-Accept-Language: en
> Folks,
> We currently use Wind Rivers Tornado I crosswind debugger for source
> level debugging.   Crosswind has been very unreliable for us.  We are
> considering third party debuggers.   What is the EPICS community doing
> for source level debugging?
> Thanks,
> Carl Schumann
> FNAL
X-Sun-Data-Type: postscript-file
X-Sun-Data-Description: postscript-file
X-Sun-Data-Name: doc.pdf
X-Sun-Charset: iso-8859-1
X-Sun-Content-Lines: 5386
%!PS-Adobe-3.0
%%Title: (MO380CB5C00FF0EFB.pdf)
%%Version: 1 2
%%Creator: (FrameMaker xm5.5P4f)
%%CreationDate: (D:19991014114606)
%%DocumentData: Clean7Bit
%%LanguageLevel: 2
%%BoundingBox: 0 0 612 792
%%Pages: 7
%%DocumentProcessColors: (atend)
%%DocumentSuppliedResources:
%%+ font Times-Bold
%%+ font Courier-Bold
%%+ font Courier
%%+ font Times-Italic
%%+ font Times-Roman
%%+ font ZapfDingbats
%%+ procset (Adobe Acrobat - PDF operators) 1.2 0
%%+ procset (Adobe Acrobat - type operators) 1.2 0
%%+ procset (Adobe Acrobat - general image support) 1.2 0
%%+ procset (Adobe Acrobat - monochrome image support) 1.2 0
%%+ procset (Adobe Acrobat - color image support) 1.2 0
%%+ procset (Adobe Acrobat - indexed color image supportAdobe Acrobat - CIDFont download support) 1.2 0
%%EndComments
%%BeginDefaults
%%EndDefaults
%%BeginProlog
%%EndProlog
%%BeginSetup
%%BeginFile: l2check
%%Copyright: Copyright 1993 Adobe Systems Incorporated. All Rights Reserved.
systemdict /languagelevel known
{ systemdict /languagelevel get 1 eq }
{ true }
ifelse
initgraphics /Helvetica findfont 18 scalefont setfont
72 600 moveto (Error: Your printer driver needs to be configured) dup show
72 580 moveto (for printing to a PostScript Level 1 printer.) dup show
exch = =
/Helvetica-Bold findfont 16 scalefont setfont
72 520 moveto (Windows and Unix) show
/Times-Roman findfont 16 scalefont setfont
72 500 moveto (Select ªLevel 1º in the PostScript options section) show
72 480 moveto (of the Acrobat Exchange or Reader print dialog.) show
72 440 moveto (Macintosh) show
72 420 moveto (In the Chooser, select your printer driver.) show
72 400 moveto (Then select your printer and click the Setup button.) show
72 380 moveto (Follow any on-screen dialogs that may appear.) show
showpage
quit
if
%%EndFile
/currentpacking where{pop currentpacking true setpacking}if
userdict /PDF 85 dict put
%%BeginFile: pdfvars.prc
%%Copyright: Copyright 1987-1996 Adobe Systems Incorporated. All Rights Reserved.
userdict /PDFVars 75 dict dup begin put
/_save 0 def
/_cshow 0 def
/InitAll 0 def
/TermAll 0 def
/_lp /none def
/_doClip 0 def
/sfc 0 def
/_sfcs 0 def
/_sfc 0 def
/ssc 0 def
/_sscs 0 def
/_ssc 0 def
/_fcs 0 def
/_scs 0 def
/_fp 0 def
/_sp 0 def
/_f0 0 array def
/_f1 1 array def
/_f3 3 array def
/_f4 4 array def
/_fc null def
/_s0 0 array def
/_s1 1 array def
/_s3 3 array def
/_s4 4 array def
/_sc null def
/_cpcf null def
/_cpcs null def
/_inT false def
/_tr -1 def
/_rise 0 def
/_ax 0 def
/_cx 0 def
/_ld 0 def
/_tm matrix def
/_ctm matrix def
/_mtx matrix def
/_hy (-) def
/_fScl 0 def
/_hs 1 def
/_pdfEncodings 2 array def
/_baselineadj 0 def
/_Tj 0 def
/_italMtx[1 0 .212557 1 0 0]def
/_italMtx_WMode1 [1 -.212557 0 1 0 0]def
/_basefont 0 def
/_basefonto 0 def
/_pdf_oldCIDInit null def
/_categories 10 dict def
/_sa? true def
/_op? false def
/_ColorSep5044? false def
/_tmpcolr? [] def
/_tmpop? {} def
end
%%EndFile
PDFVars begin PDF begin
%%BeginFile: pdfutil.prc
/bd {bind def} bind def
/ld {load def} bd
/dd { PDFVars 3 1 roll put } bd
/xdd { exch dd } bd
/Level2?
{ systemdict /languagelevel get 2 ge } { false } ifelse
def
/here {
dup currentdict exch known
{ currentdict exch get true }
{ pop false }
ifelse
} bd
/isdefined? { where { pop true } { false } ifelse } bd
/StartLoad { dup dup not { /_save save dd } if } bd
/EndLoad { if not { _save restore } if } bd
/npop { { pop } repeat } bd
%%EndFile
%%BeginFile: pdf.prc
/initialize {
_ColorSep5044? {sep_ops begin 50 dict begin} if
newpath
} bd
/terminate {
_ColorSep5044? {end end} if
} bd
Level2? StartLoad
{ /m/moveto ld
/l/lineto ld
/c/curveto ld
/setSA/setstrokeadjust ld
} EndLoad
Level2? not StartLoad
/pl {
transform
0.25 sub round 0.25 add exch
itransform
} bd
/m { _sa? { pl } if moveto } bd
/l { _sa? { pl } if lineto } bd
/c { _sa? { pl } if curveto } bd
/setSA { /_sa? xdd } bd
} EndLoad
/v { currentpoint 6 2 roll c } bd
/y { 2 copy c } bd
/h/closepath ld
/d/setdash ld
/j/setlinejoin ld
/J/setlinecap ld
/M/setmiterlimit ld
/w/setlinewidth ld
/cf currentflat def
/i {
dup 0 eq { pop cf } if
setflat
} bd
/ilp { /_lp /none dd } bd
/sfc {
_lp /fill ne {
_sfcs
_sfc
/_lp /fill dd
} if
} dd
/ssc {
_lp /stroke ne {
_sscs
_ssc
/_lp /stroke dd
} if
} dd
/n {
_doClip 1 ge {
_doClip 1 eq { clip } { eoclip } ifelse
/_doClip 0 dd
} if
newpath
} bd
/f {
_doClip 1 ge
gsave sfc fill grestore
newpath
ilp
/_doClip 0 dd
{ sfc fill }
ifelse
} bd
/f* {
_doClip 1 ge
gsave sfc eofill grestore
newpath
ilp
/_doClip 0 dd
{ sfc eofill }
ifelse
} bd
/S {
_doClip 1 ge
gsave ssc stroke grestore
newpath
ilp
/_doClip 0 dd
{ ssc stroke }
ifelse
} bd
/s { h S } bd
/B {
_doClip dup 1 ge
gsave f grestore
gsave S grestore
newpath
ilp
/_doClip 0 dd
{ pop S }
ifelse
} bd
/b { h B } bd
/B* {
_doClip dup 1 ge
gsave f* grestore
gsave S grestore
newpath
ilp
/_doClip 0 dd
{ pop S }
ifelse
} bd
/b* { h B* } bd
/W { /_doClip 1 dd } bd
/W* { /_doClip 2 dd } bd
/q/save ld
/Q { restore ilp } bd
Level2? StartLoad
{ /defineRes/defineresource ld
/findRes/findresource ld
currentglobal
true systemdict /setglobal get exec
[/Function /ExtGState /Form]
{ /Generic /Category findresource dup length dict copy /Category defineresource pop }
forall
} EndLoad
{ /AlmostFull?
{ dup maxlength exch length sub 2 le
} bind def
/Expand
{ 1 index maxlength mul cvi dict
dup begin exch { def } forall end
} bind def
/xput
{ 3 2 roll
dup 3 index known not
{ dup AlmostFull? { 1.5 Expand } if
} if
dup 4 2 roll put
} bind def
/defineRes
{ _categories 1 index known not
{ /_categories _categories 2 index 10 dict xput store
} if
_categories exch 2 copy get 5 -1 roll 4 index xput put
} bind def
/findRes
{ _categories exch get exch get
} bind def
} EndLoad
/cs
dup where { pop load } if
dup /_fcs xdd
ucs
_cpcf exch get
/_fc xdd
/_fp null dd
} bd
/CS
dup /_scs xdd ucs _cpcs exch get /_sc xdd /_sp null dd
} bd
/ucs {
dup type /arraytype eq
{ dup 0 get
dup /Indexed eq
{ pop 0 get }
{ /Pattern eq
{ dup length 2 eq
{ 1 get ucs }
{ 0 get }
ifelse }
{ 0 get }
ifelse }
ifelse }
if }
bd
/_cpcf
15 dict dup begin
/DefaultGray _f1 def
/DeviceGray _f1 def
/DefaultRGB _f3 def
/DeviceRGB _f3 def
/DeviceCMYK _f4 def
/CalGray _f1 def
/CalRGB _f3 def
/CalCMYK _f4 def
/Lab _f3 def
/Pattern _f0 def
/Indexed _f1 def
/Separation _f1 def
/CIEBasedA _f1 def
/CIEBasedABC _f3 def
end
dd
/_cpcs
15 dict dup begin
/DefaultGray _s1 def
/DeviceGray _s1 def
/DefaultRGB _s3 def
/DeviceRGB _s3 def
/DeviceCMYK _s4 def
/CalGray _s1 def
/CalRGB _s3 def
/CalCMYK _s4 def
/Lab _s3 def
/Pattern _s0 def
/Indexed _s1 def
/Separation _s1 def
/CIEBasedA _s1 def
/CIEBasedABC _s3 def
end
dd
Level2? not StartLoad {
/ri/pop ld
/makePat/pop ld
} EndLoad
Level2? StartLoad {
/ri
/findcolorrendering isdefined?
mark exch
findcolorrendering
counttomark 2 eq
{ type /booleantype eq
{ dup type /nametype eq
{ dup /ColorRendering resourcestatus
{ pop pop
dup /DefaultColorRendering ne
/ColorRendering findresource
setcolorrendering
} if
} if
} if
} if
} if
cleartomark
{ pop
} ifelse
} bd
/makePat /makepattern ld
} EndLoad
Level2? not _ColorSep5044? or StartLoad
/L1setcolor {
aload length
dup 0 eq
{ pop .5 setgray }
{ dup 1 eq
{ pop setgray }
{ 3 eq
{ setrgbcolor }
{ setcmykcolor }
ifelse }
ifelse }
ifelse
} bind dd
/_sfcs { } dd
/_sscs { } dd
} EndLoad
Level2? not _ColorSep5044? not and StartLoad
/_sfc { _fc L1setcolor } dd
/_ssc { _sc L1setcolor } dd
} EndLoad
Level2? _ColorSep5044? not and StartLoad
/_sfcs
_fcs setcolorspace
} bind dd
/_sscs
_scs setcolorspace
} bind dd
/_sfc
_fc aload pop
_fp null eq
{ setcolor }
{ _fp setpattern }
ifelse
} bind dd
/_ssc
_sc aload pop
_sp null eq { setcolor } { _sp setpattern } ifelse
} bind dd
} EndLoad
/sc
_fc astore pop
ilp
} bd
/SC
_sc astore pop
ilp
} bd
/scn {
dup type /dicttype eq
{ dup /_fp xdd
/PaintType get 1 eq
{ /_fc _f0 dd ilp }
{ /_fc _cpcf _fcs ucs get dd
sc }
ifelse }
{ sc }
ifelse
} bd
/SCN {
{ dup /_sp xdd
/PaintType get 1 eq
{ /_sc _s0 dd ilp }
{ /_sc _cpcs _scs ucs get dd
SC }
ifelse }
{ SC }
ifelse
} bd
/g { /DefaultGray cs sc } bd
/rg { /DefaultRGB cs sc } bd
/k { /DeviceCMYK cs sc } bd
/G { /DefaultGray CS SC } bd
/RG { /DefaultRGB CS SC } bd
/K { /DeviceCMYK CS SC } bd
/cm { _mtx astore concat } bd
/re {
4 2 roll m
1 index 0 rlineto
0 exch rlineto
neg 0 rlineto
h
} bd
/RC/rectclip ld
/EF/execform ld
/PS { cvx exec } bd
/initgs {
/DefaultGray where
{ pop }
{ /DefaultGray /DeviceGray dd }
ifelse
/DefaultRGB where
{ pop }
{ /DefaultRGB /DeviceRGB dd }
ifelse
0 g 0 G
[] 0 d 0 j 0 J 10 M 1 w
true setSA
} bd
21 dict dup begin
/CosineDot
{ 180 mul cos exch 180 mul cos add 2 div } bd
/Cross
{ abs exch abs 2 copy gt { exch } if pop neg } bd
/Diamond
{ abs exch abs 2 copy add .75 le
{ dup mul exch dup mul add 1 exch sub }
{ 2 copy add 1.23 le
{ .85 mul add 1 exch sub }
{ 1 sub dup mul exch 1 sub dup mul add 1 sub }
ifelse }
ifelse } bd
/Double
{ exch 2 div exch 2 { 360 mul sin 2 div exch } repeat add } bd
/DoubleDot
{ 2 { 360 mul sin 2 div exch } repeat add } bd
/Ellipse
{ abs exch abs 2 copy 3 mul exch 4 mul add 3 sub dup 0 lt
{ pop dup mul exch .75 div dup mul add 4 div
1 exch sub }
{ dup 1 gt
{pop 1 exch sub dup mul exch 1 exch sub
.75 div dup mul add 4 div 1 sub }
{ .5 exch sub exch pop exch pop }
ifelse }
ifelse } bd
/EllipseA
{ dup mul .9 mul exch dup mul add 1 exch sub } bd
/EllipseB
{ dup 5 mul 8 div mul exch dup mul exch add sqrt 1 exch sub } bd
/EllipseC
{ dup .5 gt { 1 exch sub } if
dup .25 ge
{ .5 exch sub 4 mul dup mul 1 sub }
{ 4 mul dup mul 1 exch sub }
ifelse
exch
dup .25 ge
ifelse
add -2 div } bd
/InvertedDouble
{ exch 2 div exch 2 { 360 mul sin 2 div exch } repeat add neg } bd
/InvertedDoubleDot
{ 2 { 360 mul sin 2 div exch } repeat add neg } bd
/InvertedEllipseA
{ dup mul .9 mul exch dup mul add 1 sub } bd
/InvertedSimpleDot
{ dup mul exch dup mul add 1 sub } bd
/Line
{ exch pop abs neg } bd
/LineX
{ pop } bd
/LineY
{ exch pop } bd
/Rhomboid
{ abs exch abs 0.9 mul add 2 div } bd
/Round
{ abs exch abs 2 copy add 1 le
ifelse } bd
/SimpleDot
{ dup mul exch dup mul add 1 exch sub } bd
/Square
{ abs exch abs 2 copy lt { exch } if pop neg } bd
end
{ /Function defineRes pop } forall
/Identity {} /Function defineRes pop
_ColorSep5044? StartLoad {
/_defaulttransferfunc currenttransfer def
/currentcolortransfer where
{ pop /_defaultcolortransferfuncs [ currentcolortransfer ] def }
if
/concattransferfuncs {
[ 3 1 roll /exec load exch /exec load ] cvx
} bd
/concatandsettransfer {
/_defaulttransferfunc load concattransferfuncs settransfer
} bd
/concatandsetcolortransfer {
colorplate 0 eq
_defaultcolortransferfuncs aload pop
8 -1 roll 5 -1 roll concattransferfuncs 7 1 roll
6 -1 roll 4 -1 roll concattransferfuncs 5 1 roll
4 -1 roll 3 -1 roll concattransferfuncs 3 1 roll
concattransferfuncs
setcolortransfer
} if
colorplate 1 ge colorplate 4 le and
4 colorplate sub index 4 { exch pop } repeat
} if
colorplate 5 ge
0 index 4 { exch pop } repeat
} if
} bd
/tn5044sethalftone
begin
HalftoneType 5 eq
{ [/Default /Cyan /Magenta /Yellow /Black /Default /Default /Default]
colorplate get
here not {
/Default here not { currentdict } if
} if
{ currentdict }
ifelse
end
begin
/TransferFunction here
currentdict dup length dict
begin
1 index /TransferFunction ne { def } { pop pop } ifelse
} forall
currentdict
end
currentdict
} ifelse
end
sethalftone
} bd
} EndLoad
Level2? StartLoad {
/gs
begin
/SA here { setstrokeadjust } if
/OP here { setoverprint } if
/BG here { setblackgeneration } if
/UCR here { setundercolorremoval } if
/TR here
_ColorSep5044?
dup xcheck
{ concatandsettransfer }
{ aload pop concatandsetcolortransfer }
ifelse
dup xcheck
{ settransfer }
{ aload pop setcolortransfer }
ifelse
} ifelse
} if
/sethalftonephase isdefined? { /HTP here { sethalftonephase } if } if
/HT here
{ _ColorSep5044?
{ tn5044sethalftone }
{ sethalftone }
ifelse
} if
end
} bd
/_defaulthalftone currenthalftone def
} EndLoad
/gs
begin
/SA here { /_sa? xdd } if
/OP here { dup /_op? xdd
/setoverprint where {pop setoverprint}
{pop} ifelse
} if
/TR here
_ColorSep5044?
{ dup xcheck
ifelse
{ dup xcheck
{ settransfer }
ifelse
} ifelse
} if
/HT here
{ _ColorSep5044?
{ sethalftone }
ifelse
} if
end
} bd
5 dict dup
begin
currentscreen 1 [/HalftoneType /SpotFunction /Angle /Frequency ]
{ exch def } forall
end
/_defaulthalftone exch def
} EndLoad
/int {
dup 2 index sub 3 index 5 index sub div 6 -2 roll sub mul
exch pop add exch pop
} bd
/limit {
dup 2 index le { exch } if pop
dup 2 index ge { exch } if pop
} bd
/_sfc
_fp null eq
{ _fcs type /arraytype eq
{_fcs 0 get /Separation eq
_fcs 1 get /All eq
_fc aload pop 1 exch sub
/setseparationgray where pop begin setseparationgray end
1 _fcs 3 get exec _fcs 1 get
/findcmykcustomcolor where pop begin findcmykcustomcolor end
_fc aload pop
/setcustomcolor where pop begin setcustomcolor end
ifelse
{ _fc L1setcolor }
ifelse
{ _fc L1setcolor }
ifelse
{ _fc L1setcolor }
ifelse
} bind dd
/_ssc
_sp null eq
{ _scs type /arraytype eq
{_scs 0 get /Separation eq
_scs 1 get /All eq
_sc aload pop 1 exch sub
1 _scs 3 get exec _scs 1 get
_sc aload pop
ifelse
{ _sc L1setcolor }
ifelse
{ _sc L1setcolor }
ifelse
{ _sc L1setcolor }
ifelse
} bind dd
} EndLoad
%%EndFile
%%BeginFile: pdftext.prc
%%Copyright: Copyright 1987-1997 Adobe Systems Incorporated. All Rights Reserved.
PDF /PDFText 65 dict dup begin put
/initialize { PDFText begin } bd
/terminate { end } bd
/pdf_has_composefont? systemdict /composefont known def
/CopyFont {
1 index /FID ne 2 index /UniqueID ne and
} forall
} bd
/Type0CopyFont
exch
dup length dict
begin
CopyFont
exch
FDepVector
dup /FontType get 0 eq
1 index Type0CopyFont
/_pdfType0 exch definefont
/_pdfBaseFont exch
2 index exec
ifelse
exch
forall
pop
/FDepVector exch def
currentdict
end
} bd
/cHexEncoding
[/c00/c01/c02/c03/c04/c05/c06/c07/c08/c09/c0A/c0B/c0C/c0D/c0E/c0F/c10/c11/c12
/c13/c14/c15/c16/c17/c18/c19/c1A/c1B/c1C/c1D/c1E/c1F/c20/c21/c22/c23/c24/c25
/c26/c27/c28/c29/c2A/c2B/c2C/c2D/c2E/c2F/c30/c31/c32/c33/c34/c35/c36/c37/c38
/c39/c3A/c3B/c3C/c3D/c3E/c3F/c40/c41/c42/c43/c44/c45/c46/c47/c48/c49/c4A/c4B
/c4C/c4D/c4E/c4F/c50/c51/c52/c53/c54/c55/c56/c57/c58/c59/c5A/c5B/c5C/c5D/c5E
/c5F/c60/c61/c62/c63/c64/c65/c66/c67/c68/c69/c6A/c6B/c6C/c6D/c6E/c6F/c70/c71
/c72/c73/c74/c75/c76/c77/c78/c79/c7A/c7B/c7C/c7D/c7E/c7F/c80/c81/c82/c83/c84
/c85/c86/c87/c88/c89/c8A/c8B/c8C/c8D/c8E/c8F/c90/c91/c92/c93/c94/c95/c96/c97
/c98/c99/c9A/c9B/c9C/c9D/c9E/c9F/cA0/cA1/cA2/cA3/cA4/cA5/cA6/cA7/cA8/cA9/cAA
/cAB/cAC/cAD/cAE/cAF/cB0/cB1/cB2/cB3/cB4/cB5/cB6/cB7/cB8/cB9/cBA/cBB/cBC/cBD
/cBE/cBF/cC0/cC1/cC2/cC3/cC4/cC5/cC6/cC7/cC8/cC9/cCA/cCB/cCC/cCD/cCE/cCF/cD0
/cD1/cD2/cD3/cD4/cD5/cD6/cD7/cD8/cD9/cDA/cDB/cDC/cDD/cDE/cDF/cE0/cE1/cE2/cE3
/cE4/cE5/cE6/cE7/cE8/cE9/cEA/cEB/cEC/cED/cEE/cEF/cF0/cF1/cF2/cF3/cF4/cF5/cF6
/cF7/cF8/cF9/cFA/cFB/cFC/cFD/cFE/cFF] def
/modEnc {
/_enc xdd
/_icode 0 dd
counttomark 1 sub -1 0
index
_enc _icode 3 -1 roll put
_icode 1 add
if
/_icode xdd
} for
cleartomark
_enc
} bd
/trEnc {
/_enc xdd
255 -1 0 {
exch dup -1 eq
{ pop /.notdef }
{ Encoding exch get }
ifelse
_enc 3 1 roll put
} for
pop
_enc
} bd
/TE {
/_i xdd
StandardEncoding 256 array copy modEnc
_pdfEncodings exch _i exch put
} bd
/TZ
/_usePDFEncoding xdd
findfont
dup length 2 add dict
begin
1 index /FID ne { def } { pop pop } ifelse
} forall
/FontName exch def
_usePDFEncoding 0 ge
/Encoding _pdfEncodings _usePDFEncoding get def
pop
_usePDFEncoding -1 eq
counttomark 0 eq
{ pop }
modEnc /Encoding exch def
ifelse
256 array
trEnc /Encoding exch def
ifelse
ifelse
FontName currentdict
end
definefont pop
bd
/Level2?
{systemdict /languagelevel get 2 ge}
{false}
ifelse
def
Level2?
/_pdfFontStatus
currentglobal exch
/Font resourcestatus
{pop pop true}
{false}
ifelse
exch setglobal
} bd
/_pdfFontStatusString 50 string def
_pdfFontStatusString 0 (fonts/) putinterval
/_pdfFontStatus
_pdfFontStatusString 6 42 getinterval
cvs length 6 add
_pdfFontStatusString exch 0 exch getinterval
status
{ pop pop pop pop true}
{ false }
ifelse
} bd
ifelse
Level2?
/_pdfCIDFontStatus
/CIDFont /Category resourcestatus
pop pop
/CIDFont resourcestatus
{pop pop true}
{false}
ifelse
{ pop false }
ifelse
} bd
if
/_pdfString100 100 string def
/_pdfComposeFontName
dup length 1 eq
0 get
1 index
type /nametype eq
_pdfString100 cvs
length dup dup _pdfString100 exch (-) putinterval
_pdfString100 exch 1 add dup _pdfString100 length exch sub getinterval
2 index exch cvs length
add 1 add _pdfString100 exch 0 exch getinterval
exch pop
true
pop pop
false
ifelse
false
ifelse
} bd
/_pdfComposeFont
1 index /CMap resourcestatus
{pop pop true}
{false}
ifelse
1 index true exch
_pdfCIDFontStatus not
{pop false exit}
if
forall
and
{ 3 -1 roll pop composefont true}
4 -1 roll pop
_pdfComposeFontName
dup _pdfFontStatus
{ findfont definefont true }
pop
dup _pdfFontStatus
{ findfont true }
{ pop false }
ifelse
ifelse
dup _pdfFontStatus
{ findfont true }
{ pop false }
ifelse
ifelse
ifelse
} bd
/_pdfComposeFont
4 -1 roll pop
_pdfComposeFontName not
dup
if
2 copy _pdfFontStatus
{pop findfont exch pop true}
eq
{pop false}
dup _pdfFontStatus
{findfont true}
{pop false}
ifelse
ifelse
ifelse
} bd
ifelse
/_pdfFaceByStyleDict 4 dict dup begin
Level2?
/Serif
/HeiseiMin-W3-83pv-RKSJ-H _pdfFontStatus
{/HeiseiMin-W3}
{/Ryumin-Light}
ifelse
def
/SansSerif
/HeiseiKakuGo-W5-83pv-RKSJ-H _pdfFontStatus
{/HeiseiKakuGo-W5}
{/GothicBBB-Medium}
ifelse
def
/HeiseiMaruGo-W4-83pv-RKSJ-H _pdfFontStatus
{/HeiseiMaruGo-W4}
/Jun101-Light-RKSJ-H _pdfFontStatus
{ /Jun101-Light }
{ SansSerif }
ifelse
ifelse
/RoundSansSerif exch def
/Default Serif def
/Serif /Ryumin-Light def
/SansSerif /GothicBBB-Medium def
(fonts/Jun101-Light-83pv-RKSJ-H) status
}stopped
{pop}{
{ pop pop pop pop /Jun101-Light }
{ SansSerif }
ifelse
}ifelse
/Default Serif def
ifelse
end
def
/_pdf_Adobe-Japan1-2 (Adobe-Japan1-2) def
/_pdfConcatNames
exch
_pdfString100 cvs
3 -1 roll exch cvs length
} bind def
/_pdfSubSetFontByStyleDict 4 dict dup begin
_pdfFaceByStyleDict
_pdf_Adobe-Japan1-2 _pdfConcatNames
dup _pdfFontStatus
{ def }
pop
dup /SansSerif eq
/HeiseiKakuGo-W5-Adobe-Japan1-2 dup _pdfFontStatus
{ def exit }
{ pop }
ifelse
if
dup /Serif eq
/HeiseiMin-W3-Adobe-Japan1-2 dup _pdfFontStatus
{ def exit }
{ pop }
ifelse
if
pop exit
loop
ifelse
forall
end def
/TZzero
/_fyAdj xdd
/_wmode xdd
/_styleArr xdd
4 copy
_pdfComposeFont
{exch pop exch pop exch pop}
0 1 _styleArr length 1 sub
_styleArr exch get
_pdfFaceByStyleDict exch 2 copy known not
{ pop /Default }
if
get
for
exch pop
3 index 3 index 4 2 roll
_pdfComposeFont
{exch pop}
findfont
ifelse
ifelse
dup /FontType get 3 eq _wmode 1 eq and
_pdfVerticalRomanT3Font dup length dict copy
begin
/_basefont exch def
/Encoding _basefont /Encoding get def
begin
{1 index /FID ne {def}{pop pop} ifelse }
forall
} ifelse
/WMode _wmode def
/BaseLineAdj _fyAdj def
FontType 0 ne
/Encoding Encoding dup length array copy dup 16#5c /yen put def
/_fauxfont true def
} if
currentdict
end
definefont pop
bd
/swj {
dup 4 1 roll
dup length exch stringwidth
exch 5 -1 roll 3 index mul add
4 1 roll 3 1 roll mul add
6 2 roll /_cnt 0 dd
{1 index eq {/_cnt _cnt 1 add dd} if} forall pop
exch _cnt mul exch _cnt mul 2 index add 4 1 roll 2 index add 4 1 roll pop pop
} bd
/jss {
4 1 roll
2 npop
(0) exch 2 copy 0 exch put
gsave
32 eq
exch 6 index 6 index 6 index 5 -1 roll widthshow
currentpoint
false charpath currentpoint
4 index setmatrix stroke
ifelse
grestore
moveto
2 copy rmoveto
} exch cshow
6 npop
} def
/jsfTzero {
2 npop
exch show
32 eq
4 index 4 index rmoveto
if
2 copy rmoveto
} exch cshow
5 npop
} def
/jsp
2 npop
32 eq
{ exch 5 index 5 index 5 index 5 -1 roll widthshow }
{ false charpath }
ifelse
2 copy rmoveto
} exch cshow
5 npop
} bd
/trj { _cx 0 fWModeProc 32 _ax 0 fWModeProc 6 5 roll } bd
/pjsf { trj sfc fawidthshowProc } bd
/pjss { trj _ctm ssc jss } bd
/pjsc { trj jsp } bd
/_Tjdef [
/pjsf load
/pjss load
dup
currentpoint 3 2 roll
pjsf
newpath moveto
pjss
} bind
trj swj rmoveto
} bind
dup currentpoint 4 2 roll gsave
pjsf
grestore 3 1 roll moveto
pjsc
} bind
currentpoint gsave newpath moveto
pjss
pjsc
} bind
dup currentpoint 3 2 roll
pjsf
newpath moveto
pjss
pjsc
} bind
/pjsc load
] def
/BT
/_inT true dd
_ctm currentmatrix pop matrix _tm copy pop
0 _rise _baselineadj add translate _hs 1 scale
0 0 moveto
} bd
/ET
/_inT false dd
_tr 3 gt {clip} if
_ctm setmatrix newpath
} bd
/Tr {
_inT { _tr 3 le {currentpoint newpath moveto} if } if
dup /_tr xdd
_Tjdef exch get /_Tj xdd
} bd
/Tj {
userdict /$$copystring 2 index put
_Tj
} bd
/iTm { _ctm setmatrix _tm concat 0 _rise _baselineadj add translate _hs 1 scale } bd
/Tm { _tm astore pop iTm 0 0 moveto } bd
/Td { _mtx translate _tm _tm concatmatrix pop iTm 0 0 moveto } bd
/TD { dup /_ld xdd Td } bd
/_nullProc {} bd
/Tf {
dup 1000 div /_fScl xdd
exch findfont dup
/_nullProc exch
/WMode known
1 index /WMode get 1 eq
{pop /exch}
if
if
load /fWModeProc xdd
dup
/FontType get 0 eq dup _cx 0 ne and
{ /jsfTzero }
{ /awidthshow }
ifelse
load /fawidthshowProc xdd
/_fTzero xdd
dup /BaseLineAdj known
{ dup /BaseLineAdj get _fScl mul }
{ 0 }
ifelse
/_baselineadj xdd
currentpoint iTm moveto
exch scalefont setfont
} bd
/TL { neg /_ld xdd } bd
/Tw {
/_cx xdd
_cx 0 ne _fTzero and
{ /jsfTzero }
{ /awidthshow }
ifelse
} bd
/Tc { /_ax xdd } bd
/Ts { /_rise xdd currentpoint iTm moveto } bd
/Tz { 100 div /_hs xdd iTm } bd
/Tk { exch pop _fScl mul neg 0 fWModeProc rmoveto } bd
/T* { 0 _ld Td } bd
/' { T* Tj } bd
/" { exch Tc exch Tw ' } bd
/TJ {
dup type /stringtype eq
{ Tj }
{ 0 exch Tk }
ifelse
} forall
} bd
/T- { _hy Tj } bd
/d0/setcharwidth ld
/d1 { setcachedevice /sfc{}dd /ssc{}dd } bd
/nND {{/.notdef} repeat} bd
/T3Defs {
/BuildChar
1 index /Encoding get exch get
1 index /BuildGlyph get exec
def
/BuildGlyph {
exch begin
GlyphProcs exch get exec
end
} def
} bd
/_pdfBoldRomanWidthProc
stringwidth 1 index 0 ne { exch .03 add exch }if setcharwidth
} bd
/_pdfType0WidthProc
dup stringwidth 0 0 moveto
2 index true charpath pathbbox
0 -1
7 index 2 div .88
setcachedevice2
pop
} bd
/_pdfBoldBaseFont
10 dict begin
/FontType 3 def
/FontMatrix[1 0 0 1 0 0]def
/FontBBox[0 0 1 1]def
/Encoding cHexEncoding def
/_setwidthProc /_pdfBoldRomanWidthProc load def
/_bcstr1 1 string def
/BuildChar
exch begin
_basefont setfont
_bcstr1 dup 0 4 -1 roll put
dup
_setwidthProc
0 0 moveto
dup show
_basefonto setfont
0 0 moveto
show
end
}bd
currentdict
end
def
/_pdfVerticalRomanT3Font
10 dict begin
/FontType 3 def
/BuildChar
exch begin
_basefont setfont
dup
_pdfType0WidthProc
0 0 moveto
show
end
}bd
currentdict
end
def
/MakeBoldFont
dup dup length 2 add dict
begin
CopyFont
/PaintType 2 def
/StrokeWidth .03 0 FontMatrix idtransform pop def
/dummybold currentdict
end
definefont
_pdfBoldBaseFont 8 dict copy begin
/_basefont exch def
/_basefonto exch def
currentdict
end
definefont
} bd
/MakeBold {
findfont dup
/FontType get 0 eq
_pdfBoldBaseFont /_setwidthProc /_pdfType0WidthProc load put
{MakeBoldFont} Type0CopyFont definefont
dup /_fauxfont known not
_pdfBoldBaseFont /_setwidthProc /_pdfBoldRomanWidthProc load put
MakeBoldFont
{ definefont }
ifelse
ifelse
pop
}bd
/MakeItalic {
findfont
dup /WMode 2 copy known
get 1 eq
{ _italMtx_WMode1 }
{ _italMtx }
ifelse
{ pop pop _italMtx }
ifelse
makefont
definefont pop
}bd
/MakeBoldItalic {
/dummybold exch
MakeBold
/dummybold
MakeItalic
}bd
currentdict readonly pop end
%%EndFile
PDFText begin
[39/quotesingle 96/grave 128/Adieresis/Aring/Ccedilla/Eacute/Ntilde/Odieresis
/Udieresis/aacute/agrave/acircumflex/adieresis/atilde/aring/ccedilla/eacute
/egrave/ecircumflex/edieresis/iacute/igrave/icircumflex/idieresis/ntilde
/oacute/ograve/ocircumflex/odieresis/otilde/uacute/ugrave/ucircumflex
/udieresis/dagger/degree/cent/sterling/section/bullet/paragraph/germandbls
/registered/copyright/trademark/acute/dieresis/.notdef/AE/Oslash
/.notdef/plusminus/.notdef/.notdef/yen/mu/.notdef/.notdef
/.notdef/.notdef/.notdef/ordfeminine/ordmasculine/.notdef/ae/oslash
/questiondown/exclamdown/logicalnot/.notdef/florin/.notdef/.notdef
/guillemotleft/guillemotright/ellipsis/.notdef/Agrave/Atilde/Otilde/OE/oe
/endash/emdash/quotedblleft/quotedblright/quoteleft/quoteright/divide
/.notdef/ydieresis/Ydieresis/fraction/currency/guilsinglleft/guilsinglright
/fi/fl/daggerdbl/periodcentered/quotesinglbase/quotedblbase/perthousand
/Acircumflex/Ecircumflex/Aacute/Edieresis/Egrave/Iacute/Icircumflex
/Idieresis/Igrave/Oacute/Ocircumflex/.notdef/Ograve/Uacute/Ucircumflex
/Ugrave/dotlessi/circumflex/tilde/macron/breve/dotaccent/ring/cedilla
/hungarumlaut/ogonek/caron
0 TE
[1/dotlessi/caron 39/quotesingle 96/grave
127/bullet/bullet/bullet/quotesinglbase/florin/quotedblbase/ellipsis
/dagger/daggerdbl/circumflex/perthousand/Scaron/guilsinglleft/OE
/bullet/bullet/bullet/bullet/quoteleft/quoteright/quotedblleft
/quotedblright/bullet/endash/emdash/tilde/trademark/scaron
/guilsinglright/oe/bullet/bullet/Ydieresis/space/exclamdown/cent/sterling
/currency/yen/brokenbar/section/dieresis/copyright/ordfeminine
/guillemotleft/logicalnot/hyphen/registered/macron/degree/plusminus
/twosuperior/threesuperior/acute/mu/paragraph/periodcentered/cedilla
/onesuperior/ordmasculine/guillemotright/onequarter/onehalf/threequarters
/questiondown/Agrave/Aacute/Acircumflex/Atilde/Adieresis/Aring/AE/Ccedilla
/Egrave/Eacute/Ecircumflex/Edieresis/Igrave/Iacute/Icircumflex/Idieresis
/Eth/Ntilde/Ograve/Oacute/Ocircumflex/Otilde/Odieresis/multiply/Oslash
/Ugrave/Uacute/Ucircumflex/Udieresis/Yacute/Thorn/germandbls/agrave
/aacute/acircumflex/atilde/adieresis/aring/ae/ccedilla/egrave/eacute
/ecircumflex/edieresis/igrave/iacute/icircumflex/idieresis/eth/ntilde
/ograve/oacute/ocircumflex/otilde/odieresis/divide/oslash/ugrave/uacute
/ucircumflex/udieresis/yacute/thorn/ydieresis
1 TE
end
%%BeginFile: pdfimage.prc
%%Copyright: Copyright 1987-1993 Adobe Systems Incorporated. All Rights Reserved.
PDF /PDFImage 38 dict put
PDF /PDFIVars 20 dict put
PDF /PDFImage get begin
/initialize { PDFImage begin } bd
/nulldict 0 dict def
/gv { PDFIVars exch get } bd
/pv { PDFIVars 3 1 roll put } bd
/BI { save /savelevel exch pv mark } bd
/EI { /savelevel gv restore } bd
end
%%EndFile
%%BeginFile: pdfimg2.prc
Level2? StartLoad {
/ID {
5 counttomark 2 idiv
dup 3 1 roll add
dict begin
{ def } repeat
cleartomark
currentdict
end
begin
/ImageType 1 def
/ImageMatrix [ Width 0 0 Height neg 0 Height ] def
/ImageMask here { not } { true } ifelse
{ /ImageMask false def } if
ImageMask not { ColorSpace setcolorspace } if
/Intent here { ri } if
/Decode here { pop } {
/Decode [
ImageMask {
0 1
currentcolorspace 0 get /Indexed eq {
0 2 BitsPerComponent exp 1 sub
mark currentcolor counttomark
dup 2 add 1 roll cleartomark
{ 0 1 } repeat
} ifelse
} ifelse
] def
} ifelse
/DataSource here { pop } {
currentfile
/Filter here {
dup type /arraytype eq { length } { pop 1 } ifelse
1 sub 0 1 3 -1 roll {
/DecodeParms here {
1 index get
} if
dup null eq { pop } { exch } ifelse
} if
Filter dup type /arraytype eq
{ exch get } { exch pop } ifelse
filter
dup
} for
} if
/DataSource exch def
} ifelse
currentdict
/ImageMask here not { false } if
{ sfc imagemask } { image } ifelse
counttomark
{ dup status
{ dup flushfile closefile }
{ pop }
ifelse
repeat
pop
end
} bd
} EndLoad
end
%%EndFile
end end
/currentpacking where {pop setpacking}if
PDFVars/InitAll{[PDF PDFText PDFImage]{/initialize get exec}forall initgs 0 Tr}put
PDFVars/TermAll{[PDFImage PDFText PDF]{/terminate get exec}forall}put
PDFVars begin PDF begin PDFVars/InitAll get exec
/N47 <<
/SA false
/OP false
>> /ExtGState defineRes pop
% Begin encoding-delta
[ 39 /quotesingle 96 /grave 127 /.notdef/Adieresis/Aring/Ccedilla
/Eacute/Ntilde/Odieresis/Udieresis/aacute/agrave
/idieresis/ntilde/oacute/ograve/ocircumflex/odieresis
/otilde/uacute/ugrave/ucircumflex/udieresis/dagger
/.notdef/cent/sterling/section/bullet/paragraph
/germandbls/registered/copyright/trademark/acute/dieresis
/.notdef/AE/Oslash/.notdef/.notdef/.notdef
/.notdef/yen/.notdef/.notdef/.notdef/.notdef
/oslash/questiondown/exclamdown/logicalnot/.notdef/florin
/.notdef/.notdef/guillemotleft/guillemotright/ellipsis/.notdef
/Agrave/Atilde/Otilde/OE/oe/endash
/emdash/quotedblleft/quotedblright/quoteleft/quoteright/.notdef
/guilsinglright/fi/fl/daggerdbl/periodcentered/quotesinglbase
/quotedblbase/perthousand/Acircumflex/Ecircumflex/Aacute/Edieresis
/Egrave/Iacute/Icircumflex/Idieresis/Igrave/Oacute
/Ocircumflex/.notdef/Ograve/Uacute/Ucircumflex/Ugrave
/ring/cedilla/hungarumlaut/ogonek/caron
/N43/Times-Bold -1 TZ
% End encoding-delta
/N42/Times-Roman -1 TZ
/N65/Times-Italic -1 TZ
%%BeginResource: font ZapfDingbats
%%BeginFont: ZapfDingbats
%!PS-AdobeFont-1.0: ZapfDingbats 001.004
%%CreationDate: Fri Dec  1 12:57:36 1989
%%VMusage: 39281 49041
%% ITC Zapf Dingbats is a registered trademark of International Typeface
%% Corporation.
11 dict begin
/FontInfo 10 dict dup begin
/version (001.004) readonly def
/Notice (Copyright (c) 1985, 1987, 1988, 1989 Adobe Systems Incorporated.  All rights reserved.ITC Zapf Dingbats is a registered trademark of International Typeface Corporation.) readonly def
/FullName (ITC Zapf Dingbats) readonly def
/FamilyName (ITC Zapf Dingbats) readonly def
/Weight (Medium) readonly def
/ItalicAngle 0 def
/isFixedPitch false def
/UnderlinePosition -98 def
/UnderlineThickness 54 def
end readonly def
/FontName /ZapfDingbats def
/Encoding 256 array
0 1 255 {1 index exch /.notdef put} for
dup 32 /space put
dup 33 /a1 put
dup 34 /a2 put
dup 35 /a202 put
dup 36 /a3 put
dup 37 /a4 put
dup 38 /a5 put
dup 39 /a119 put
dup 40 /a118 put
dup 41 /a117 put
dup 42 /a11 put
dup 43 /a12 put
dup 44 /a13 put
dup 45 /a14 put
dup 46 /a15 put
dup 47 /a16 put
dup 48 /a105 put
dup 49 /a17 put
dup 50 /a18 put
dup 51 /a19 put
dup 52 /a20 put
dup 53 /a21 put
dup 54 /a22 put
dup 55 /a23 put
dup 56 /a24 put
dup 57 /a25 put
dup 58 /a26 put
dup 59 /a27 put
dup 60 /a28 put
dup 61 /a6 put
dup 62 /a7 put
dup 63 /a8 put
dup 64 /a9 put
dup 65 /a10 put
dup 66 /a29 put
dup 67 /a30 put
dup 68 /a31 put
dup 69 /a32 put
dup 70 /a33 put
dup 71 /a34 put
dup 72 /a35 put
dup 73 /a36 put
dup 74 /a37 put
dup 75 /a38 put
dup 76 /a39 put
dup 77 /a40 put
dup 78 /a41 put
dup 79 /a42 put
dup 80 /a43 put
dup 81 /a44 put
dup 82 /a45 put
dup 83 /a46 put
dup 84 /a47 put
dup 85 /a48 put
dup 86 /a49 put
dup 87 /a50 put
dup 88 /a51 put
dup 89 /a52 put
dup 90 /a53 put
dup 91 /a54 put
dup 92 /a55 put
dup 93 /a56 put
dup 94 /a57 put
dup 95 /a58 put
dup 96 /a59 put
dup 97 /a60 put
dup 98 /a61 put
dup 99 /a62 put
dup 100 /a63 put
dup 101 /a64 put
dup 102 /a65 put
dup 103 /a66 put
dup 104 /a67 put
dup 105 /a68 put
dup 106 /a69 put
dup 107 /a70 put
dup 108 /a71 put
dup 109 /a72 put
dup 110 /a73 put
dup 111 /a74 put
dup 112 /a203 put
dup 113 /a75 put
dup 114 /a204 put
dup 115 /a76 put
dup 116 /a77 put
dup 117 /a78 put
dup 118 /a79 put
dup 119 /a81 put
dup 120 /a82 put
dup 121 /a83 put
dup 122 /a84 put
dup 123 /a97 put
dup 124 /a98 put
dup 125 /a99 put
dup 126 /a100 put
dup 161 /a101 put
dup 162 /a102 put
dup 163 /a103 put
dup 164 /a104 put
dup 165 /a106 put
dup 166 /a107 put
dup 167 /a108 put
dup 168 /a112 put
dup 169 /a111 put
dup 170 /a110 put
dup 171 /a109 put
dup 172 /a120 put
dup 173 /a121 put
dup 174 /a122 put
dup 175 /a123 put
dup 176 /a124 put
dup 177 /a125 put
dup 178 /a126 put
dup 179 /a127 put
dup 180 /a128 put
dup 181 /a129 put
dup 182 /a130 put
dup 183 /a131 put
dup 184 /a132 put
dup 185 /a133 put
dup 186 /a134 put
dup 187 /a135 put
dup 188 /a136 put
dup 189 /a137 put
dup 190 /a138 put
dup 191 /a139 put
dup 192 /a140 put
dup 193 /a141 put
dup 194 /a142 put
dup 195 /a143 put
dup 196 /a144 put
dup 197 /a145 put
dup 198 /a146 put
dup 199 /a147 put
dup 200 /a148 put
dup 201 /a149 put
dup 202 /a150 put
dup 203 /a151 put
dup 204 /a152 put
dup 205 /a153 put
dup 206 /a154 put
dup 207 /a155 put
dup 208 /a156 put
dup 209 /a157 put
dup 210 /a158 put
dup 211 /a159 put
dup 212 /a160 put
dup 213 /a161 put
dup 214 /a163 put
dup 215 /a164 put
dup 216 /a196 put
dup 217 /a165 put
dup 218 /a192 put
dup 219 /a166 put
dup 220 /a167 put
dup 221 /a168 put
dup 222 /a169 put
dup 223 /a170 put
dup 224 /a171 put
dup 225 /a172 put
dup 226 /a173 put
dup 227 /a162 put
dup 228 /a174 put
dup 229 /a175 put
dup 230 /a176 put
dup 231 /a177 put
dup 232 /a178 put
dup 233 /a179 put
dup 234 /a193 put
dup 235 /a180 put
dup 236 /a199 put
dup 237 /a181 put
dup 238 /a200 put
dup 239 /a182 put
dup 241 /a201 put
dup 242 /a183 put
dup 243 /a184 put
dup 244 /a197 put
dup 245 /a185 put
dup 246 /a194 put
dup 247 /a198 put
dup 248 /a186 put
dup 249 /a195 put
dup 250 /a187 put
dup 251 /a188 put
dup 252 /a189 put
dup 253 /a190 put
dup 254 /a191 put
readonly def
/PaintType 0 def
/FontType 1 def
/FontMatrix [0.001 0 0 0.001 0 0] readonly def
/UniqueID 26200 def
/FontBBox{-1 -143 981 820}readonly def
currentdict end
currentfile eexec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0000000000000000000000000000000000000000000000000000000000000000
cleartomark
%%EndFont
%%EndResource
% Begin encoding-delta
[/N45/ZapfDingbats -1 TZ
% End encoding-delta
[ 39 /quotesingle 96 /grave 127 /.notdef/Adieresis/Aring/Ccedilla
/Eacute/Ntilde/Odieresis/Udieresis/aacute/agrave
/acircumflex/adieresis/atilde/aring/ccedilla/eacute
/egrave/ecircumflex/edieresis/iacute/igrave/icircumflex
/idieresis/ntilde/oacute/ograve/ocircumflex/odieresis
/otilde/uacute/ugrave/ucircumflex/udieresis/dagger
/.notdef/cent/sterling/section/bullet/paragraph
/germandbls/registered/copyright/trademark/acute/dieresis
/.notdef/AE/Oslash/.notdef/.notdef/.notdef
/.notdef/yen/.notdef/.notdef/.notdef/.notdef
/.notdef/.notdef/ordfeminine/ordmasculine/.notdef/ae
/oslash/questiondown/exclamdown/logicalnot/.notdef/florin
/.notdef/.notdef/guillemotleft/guillemotright/ellipsis/.notdef
/Agrave/Atilde/Otilde/OE/oe/endash
/emdash/quotedblleft/quotedblright/quoteleft/quoteright/.notdef
/.notdef/ydieresis/Ydieresis/fraction/currency/guilsinglleft
/guilsinglright/fi/fl/daggerdbl/periodcentered/quotesinglbase
/quotedblbase/perthousand/Acircumflex/Ecircumflex/Aacute/Edieresis
/Egrave/Iacute/Icircumflex/Idieresis/Igrave/Oacute
/Ocircumflex/.notdef/Ograve/Uacute/Ucircumflex/Ugrave
/dotlessi/circumflex/tilde/macron/breve/dotaccent
/ring/cedilla/hungarumlaut/ogonek/caron
/N44/Courier-Bold -1 TZ
/N46/Courier -1 TZ
PDFVars/TermAll get exec end end
%%EndSetup
%%Page: 1 1
%%BeginPageSetup
userdict /pgsave save put
PDFVars begin PDF begin PDFVars/InitAll get exec
%%EndPageSetup
0 0 612 792 RC
1 g
/N47 /ExtGState findRes gs
1 i
0 0 612 792 re
f
BT
/N42 1 Tf
12 0 0 12 72 712 Tm
0 g
0 Tc
0 Tw
[(W. M. KECK OBSERVATORY)-17605 (KSD/<name>_<nn>)]TJ
0 -1.3333 TD
[(Keck Software Document <nn>)-22041 (K.Tsubota)]TJ
T*
[(Version 1)-30974 (14-Oct-99)]TJ
/N43 1 Tf
18 0 0 18 204.43 641.45 Tm
[(Using DDD with VxW)75 (orks)]TJ
14 0 0 14 72 608.11 Tm
(File)Tj
12 0 0 12 94.55 608.11 Tm
(:)Tj
/N42 1 Tf
0.5833 0 TD
[(3.5.6 \(KSDs\), Library KSD Binder)41 (, Summit KSD Binder)]TJ
/N43 1 Tf
14 0 0 14 72 580.78 Tm
[(Cir)18 (culation)]TJ
12 0 0 12 140.19 580.78 Tm
(:)Tj
/N42 1 Tf
0.8333 0 TD
( <circulation>)Tj
ET
q
72 676 468 -8.55 re
W n
0 G
2 J
0 j
0.6 w
3.86 M
[]0 d
541 670.9 m
71 670.9 l
S
Q
0 G
2 J
0 j
0.36 w
3.86 M
[]0 d
540 55.03 m
69.28 55.03 l
S
1 g
45 720 18 -72 re
f*
BT
/N43 1 Tf
18 0 0 18 72 537 Tm
0 g
[(T)92 (able of Contents)]TJ
16 0 0 16 72 496.33 Tm
[(1.0  Intr)18 (oduction)]TJ
/N42 1 Tf
12 0 0 12 72 477 Tm
[(This document does not go into an)15 (y detail as to the use of Data Display Deb)21 (ugger \(DDD\). It is)]TJ
0 -1.1667 TD
[(intended)-227 (only)-228 (to)-228 (get)-228 (you)-227 (to)-228 (a)-228 (point)-228 (where)-228 (you)-227 (can)-228 (successfully)-228 (attach)-228 (to)-228 (an)-228 (e)15 (xisting)-228 (VxW)80 (orks)-227 (task)]TJ
T*
[(in a tar)18 (get. F)16 (or more details on using DDD refer to W)93 (.Lupton\325)55 (s Purify and DDD presentation)]TJ
T*
[(notes at: http://www)66 (.k)10 (eck.ha)15 (w)10 (aii.edu:8080/~wlupton/doc/purify)65 (.)]TJ
/N43 1 Tf
16 0 0 16 72 400.33 Tm
[(2.0  Setup T)92 (o)0 (r)15 (nado En)40 (vir)18 (onment)]TJ
/N42 1 Tf
12 0 0 12 72 381 Tm
[(T)80 (o)0 ( use DDD with vxW)81 (orks requires you to do the follo)25 (wing:)]TJ
/N44 1 Tf
11 0 0 11 72 360 Tm
(\245)Tj
/N42 1 Tf
12 0 0 12 85.75 360 Tm
[(add the follo)26 (wing to your path:)]TJ
/N45 1 Tf
8 0 0 8 85.75 342 Tm
(q)Tj
/N42 1 Tf
12 0 0 12 99.5 342 Tm
[(/usr/local/vw/m5.3.1.ppc/host/sun4-solaris2/bin    <=== po)25 (werPC)]TJ
/N45 1 Tf
8 0 0 8 85.75 324 Tm
(q)Tj
/N42 1 Tf
12 0 0 12 99.5 324 Tm
(/usr/local/vw/m5.3.1.base/host/sun4-solaris2/bin    <=== frc40/mv177)Tj
/N44 1 Tf
11 0 0 11 72 304 Tm
(\245)Tj
/N42 1 Tf
12 0 0 12 85.75 304 Tm
[(set the follo)26 (wing en)40 (vironment v)25 (ars:)]TJ
/N45 1 Tf
8 0 0 8 85.75 286 Tm
(q)Tj
/N42 1 Tf
12 0 0 12 99.5 286 Tm
[(seten)40 (v WIND_HOST sun4-solaris2)]TJ
/N45 1 Tf
8 0 0 8 85.75 268 Tm
(q)Tj
/N42 1 Tf
12 0 0 12 99.5 268 Tm
[(seten)40 (v WIND_REGISTR)65 (Y apua)]TJ
/N45 1 Tf
8 0 0 8 85.75 250 Tm
(q)Tj
/N42 1 Tf
12 0 0 12 99.5 250 Tm
[(seten)40 (v WIND_B)35 (ASE /usr/local/vw/m5.3.1.ppc)]TJ
/N44 1 Tf
11 0 0 11 72 215 Tm
(\245)Tj
/N42 1 Tf
12 0 0 12 85.75 215 Tm
(create a .gdbinit \336le in your home directory that contains the path t\
o your objects compiled)Tj
T*
(with the -g \337ag:)Tj
/N45 1 Tf
8 0 0 8 85.75 183 Tm
(q)Tj
/N42 1 Tf
12 0 0 12 99.5 183 Tm
[(this is a cop)10 (y of ~ktsubota/.gdbinit:)]TJ
/N46 1 Tf
11 0 0 11 108 169.67 Tm
(#)Tj
0 -1 TD
(# specify search directories for source)Tj
T*
(#)Tj
T*
(# powerPC)Tj
T*
(dir /sunos/local/epics/r3.13.0Beta12/base/bin/mv2304)Tj
T*
(dir /home/kahala/ktsubota/kroot/rel/epcom/bin/mv2304)Tj
T*
(dir /home/kahala/ktsubota/kroot/rel/dcs/bin/mv2304)Tj
ET
userdict /pgsave get restore
showpage
%%PageTrailer
%%EndPage
%%Page: 2 2
%%BeginPageSetup
/N62 [/Indexed /DeviceRGB  255  <~
s8W,urr2lprVZTkqtp9eqYL$`q=sa[p\4FUp@e1Pp%7nKoCMSEo()>@naQ&;n*f`5
mdBK0mHj3+lg*m%lK[Wul0.?pkND$jk2tdejlGL`j5]1Zio8qUiS`YPhr!>JhVR)E
h;$f@gY:K:g=k65g"=s0f@SX*f%/C%e^W*ue'ldodaHOjdEp7ecd0q_cHa\Zc-4DU
bKJ)Ob0%iJaiMQEa2c6?`l?!:`Pf^5_o'C/_SX.*_8*k%^V@Ot^:q:o]tD"j]=Y\d
]"5G_\[]/Z\$riT[^NTO[C!<JZa7!DZEga?Z*:I:YHP.4Y-+n/XfSV*X/i;$WiE%t
WMlboVl-GiVP^2dV50o_USFTYU8"?TTqJ'OT:_aISt;LDSXc4?S"#n9R[TY4R@'A/
Q^=&)QBmf$Q'@MtPEV2nP*1riOcYZdO,o?^NfK*YNJrgTMi3LNMMd7IM26tDLPLY>
L5(D9KnP,4K7ef.JqAQ)JUi9$It)rsIXZ]nI=-EiH[C*cH?sj^H$FRYGB\7SG'8"N
F`__IF)uDCEcQ/>EH#l9Df9Q3DJj<.D/=$)CMR^#C2.HsBkV0nB4kjhAnGUcARo=^
@q0"X@U`bS@:3JN?XI/H?=$oC?!LW>>?b<8>$>'3=]ed.='&I(<`W4#<E)ps;c?Um
;Gp@h;,C(c:JXb]:/4MX9h\5S91qoM8kMZH8OuBC7n6'=7Rfg8779O36UO4-6:*t(
5sR\#5<h@r5!D+m4Zkhh4$,Mb3]]8]3B/uX2`EZR2E!EM2)I-H1G^gB1,:R=0eb:8
0/"t2/hS_-/M&G(.k<,".Olkr.4?Sm-RU8g-71#b,pX`],9nEW+sJ0R+WqmM+!2RG
*Zc=B*?6%=)]K_7)B'J2)&O2-(Ddl'()@W"'bh>r',)#l&eYcg&J,Kb%hB0\%LrpW
%1EXR$O[=L$4:3sg&M*PEhE@q=,b)Ls0oJHAnGZ!bfg%e!;,pU~>] /ColorSpace defineRes pop
%%EndPageSetup
0 0 612 792 RC
1 g
1 i
0 0 612 792 re
f
BT
/N42 1 Tf
10 0 0 10 72 749.33 Tm
0 g
0 Tc
(2/7)Tj
38.579 0 TD
(KSD/<name>_<nn>)Tj
ET
0 G
2 J
0 j
0.36 w
3.86 M
[]0 d
72 55.03 m
542.72 55.03 l
S
BT
8 0 0 8 72 42.62 Tm
0 Tw
[(Setup T)80 (a)0 (r)18 (get Connection)]TJ
/N43 1 Tf
16 0 0 16 72 709.33 Tm
[(3.0  Setup T)92 (a)0 (r)10 (get Connection)]TJ
/N42 1 Tf
12 0 0 12 72 690 Tm
[(This follo)26 (wing is required for the deb)20 (ugger so that it can attach to the speci\336ed tar)19 (get so that)]TJ
0 -1.1667 TD
[(license information can be v)16 (eri\336ed. Also you must create your o)26 (wn tar)18 (get on your host, it w)10 (on\325)18 (t)]TJ
T*
[(let you connect to a tar)18 (get on a dif)26 (ferent host. \(I ne)25 (v)15 (er tried rsh\325ing to an e)15 (xisting tar)18 (get host and)]TJ
T*
(tried connecting.\))Tj
/N44 1 Tf
11 0 0 11 72 627 Tm
(\245)Tj
/N42 1 Tf
12 0 0 12 85.75 627 Tm
[(startup the T)80 (ornado Launcher tool by typing:)]TJ
ET
0 J
0.6 w
303.76 625.8 m
330.24 625.8 l
S
BT
/N65 1 Tf
12 0 0 12 303.76 627 Tm
(launc)Tj
ET
330.24 625.8 m
336.24 625.8 l
S
BT
12 0 0 12 330.24 627 Tm
(h)Tj
/N43 1 Tf
10 0 0 10 72 582.33 Tm
[(FIGURE 1. T)92 (o)0 (r)15 (nado Launcher)]TJ
/N44 1 Tf
11 0 0 11 72 135 Tm
(\245)Tj
/N42 1 Tf
12 0 0 12 85.75 135 Tm
[(from the Launcher pulldo)26 (wn select: "T)80 (ar)18 (get" -> "Create")]TJ
ET
q
360 0 0 378 117.08 192 cm
BI
	/Width 543
	/Height 530
	/BitsPerComponent 8
	/ColorSpace /N62 /ColorSpace findRes
	/Filter [/ASCII85Decode /LZWDecode ]
ID
J3Vsg3$\D##D>EP:q1$o*=mro@So+\<\5,H7Uo<*jE<[.O@Wn[3@&nY-\&mB;Rp$&
9.uZ+AlC^cenm@9:1mH29X7duT$O62l.m,78#0$s<4ZX!9gY/mBMZd)<ioH)<bk^H
j`\=EYZP^B4!g3;B=(iZ<kDqO[o/hp-*PLgeb^c-?>ioWjnAY&^gM+`4=1jRLW!YA
=M/6)*KS9JlAthEg4qto:pQF7lh;p%ctIN)4XQLiVpoI(>.nOW?*DmsG$@,,f58"P
DKN8p`aZ&hX(H5(4sq/+a0J#,(%,-VS^6MA2mV9<DhZU*G'd5&D\nmHn+WI1^F,Am
=m=<0[B@9:h='=tGb6J#dbXWlIXbTu:4(R<1^X'R!PjU$jFj@I;k!qQE(U\-+]*7L
qEY[5<:@YbKHCT7D[\+E__<W1&Z(KQ.fZ,rgf5(=:M`T=`,P>f"iIU86Q/=SbX!0t
&3P4Y6P6t\#KIG3Er8B>9?PC0YhT0'7;IQ^,ta5GAKXV914:@iODMBZ-rLIr/P*+q
Yq/Q]XOQg7C;a=)Xts>Do?/p@cON<_m)LnTnoW&<9CkRC1sU1nT/N_?OnR^*F>Y&u
:9j^K1.ZMgpIWeS'X^P2o]8#*;=t=9&$!!:),XBE'_sghe("[ue+E9l5>ok@mgN53
9m!\g&pdO85LnSCZq&Wr1G;:]jF[cU1#-OP;c[1d8ON&;LMNr5m7Q\K(@AeRg^kd=
hHQ<Uc#_\W9B0X9c4/<JhA;14qV@/>:O1h6c1Q&2GMW4Ii"oDjJDceI%9-15NYR9,
Qu3q"iY[\%M;jo''$T;dehrHIR-m+uj;AFrOlVo_5<MNi5#mm0P#W'AAf6V?RHBp?
D4B]+c?5]@RI5KqkSaqbU$.ptNMG_V:6h[?$?@__3P&h!WToqTXfLb+cF'e?R]5k-
*ub^/Z0[r4c*QdV:=ZVhd&pfbmMh2J\aGrimCVg+cLnm>S*p6in/MrB^E5N9`-_"o
:DLk=S8TFgnf3+t[_mHA#Ku]YcS`u=SF8VeoGnFb_X&3P,Lc<+:K,C#&8s/JFrcWT
g%Lu?D;4Mb-P+aOSaTS0=kp"Lgj#DDNT9gU:R/50>rR2pqAa.!QhZ#:Xm>j*caE0,
rb:odr#UosB(c/dc1ClU:Y!:.h[eQ"r-NXgp&:SemJHmTDr:Ncs,Vj4+9V^q:^u0o
VtgAKC]8'%c2p8`*<Y5PH[sHe$93hUl_%a"+jH7)2rYnL#Y=`4YG?fZQoaTm$ZLdd
rXuZ\>5f[=,)'uN(UnW:"^j_7,u9f4_cU+NiN%9[mZo!*-q<"N>X`a3*P4_<>hrk1
H&=2:'#ci"'-WSkG7b$07@*NSiPYSK6hVQg8>t0M"B]RRNZ^?L],@)J[#OIHYXLP7
'AN_3MQs0=`TJTj,.q-:O`ih"f*q8G$os:W[N32Oi=R;eI#X8o.7a`l-)78gN`';n
7p.De>f:rPOZ#EqGWdJ1oN[TCJ^MP_^ER2f,*A"N7mY6?+68qEQ'"s%6Pqm<iJ]OO
0[:D,8VJJM,^Y\pH9oK;PX:kPSsIhtA&<M^11k'4R<'E[9K>r\ALpuOP56?HM0@h=
<4[nWQ>SUj_(6Z:@uR`hFNS=b3TmboQu`U>`TYc-AqYZ,;^-V6C&:*SgjPeNqL-W1
s$8"?Eei$PJ^8VV)<b?1TQE@^:PmFcB\`Q[dZ/Ot#K7nD$k$okra&J>nK;Ae'r/*5
MaSsl7jsoGVN`j%bo/*-BItF+'OI-T3e'3U,\X&Sk+G[6"]&lM,,-j$&^k@38fjfZ
QLu;:bSKFUW!qXX1kM^T\SY/X>fhiq7\7SEa\1oABVBDiUfGQ[>G7T]Y-f1Y_MOa`
B[q<D<0jRHl/aL4D/H#,p3P?5Q!*0q8?ruMRa<P;5-"QXYBDtL:3qJ(/DUrD<S#@F
b*,?^e30g/G/@?_H"$!gWijm<@bIe`=D3+6U/`DF:>5kAl#h'V<f4C]Me?[>4Jf?J
ngI[&m;?da[B[2->Z]M$CL7AWSi'sI=G_#5+UmG!f'ZO4R=[cnrOfHoL4W:&o/:5]
hj9T@CX'D@1[!lq]JkjGcti/sn)aM9E^Hs;=d=,?gto_#G#McbR4Fr('RBDh!D02-
'<(O8_b^P<?&*_q+,/L!:_(jo]4H`e7ObSo`t(4o(?:3_+dQ*)$p[J=Jo:i'`E;R=
A#cKqnT0[5:8ihU-RhZ]1`pc!7H+ma\!&R]%!L;b&nM:QMd0*aE?lnT@iVh;[email protected]
R?'+8=-]'k?:2s_:C6#.s-^3JER%>21cgR]C\)^?c?\kBB@ef->_XoT\Z+KLS84b(
7Z#Mef/eu[#F;W<OO1M_XQ[>LV=_Z6cl,P036S^ro>[$,\n=oU>kt$47YJs1ZGU?i
)W>gnZ.<+)>&.D\XnB]Ef37WLCYaEBp'/@c>7Y1Z?&c,_7`j=f)QLQrn"fM9Y1\.t
C2I7Y[J%VngKST6D;D>#?Zq%MgPOJGiVPhXG3RgeYBFg>geP-ZG1$.J8FK9H/E%AA
hcoP)6Ms'][-h_bKAV#n>ssBjcMZX+/dQCYIB'\MXNVO.Q#N<4`V@@FiQpt*n84r>
DGI#R*+tEpXuCNKL9'Dg7PXFN974hL0BQ"7PIc2Nb-[Knk:WNq`5[\eq>4Xb/Vg$\
Ne0RN/1p(uc^460Fj;q;7FW:6MJdljd)XHtlQ']5Fe4<<qYsiam1HP5?HLYWB26b-
#FlA7gVM7o0'Lo4[('GLh7L.'mi?bLG=L!:Hgc=JIJQ<QY6f@Kk@iqiWT`m/H+CPQ
@^(;/a`h)@iT5!%d@O^]6SBtIq_*NlIOgh2c6(4(-Nek46`].gin1mKF7n"4I!Zr"
+hZD\Lq_Wf@/gIB]s".'?B<NZ]tq@j+&_KRhpqH'S)dnY#)9k_^eHsLk<:8fSQ1%%
Hqogm@2l$/hY"/N+,e,:2DF&2.hD/-&bJ5W9)=$H%DtEBH@G&0_%]9&qj-C50>@2l
`;<@0nLr2HO4&%::koO,Ckl>QWcnC1FRq-WYRI?-YUZMB(B3ZJpb.)tW2fP%K`UPA
r6Pr4:_L1^*r3_mrX/N(0D(it..fhT!tYa40BVju'(U!*,#/dODha.j>6N;Jhf)Kt
:0@1N*.DiLPcuG1BUJ[rJ?mOW"u("Pn>)t#E:_GDSSDL;#:u*P9*gW:eBj6_#:0[P
Es]'l""WH'YWW&eXE&&!$1(dnO78er!$BQZ$4k;_Dk`;L.1S&T"V6Y'&):<l>mCq3
$Hg<q&KLrBrr:*3X>$IQ;!AHD!s6d/qX4jl9.p^9$I^]T&I5-A:brQC+TKT]L%(\&
msPYbjV%&6KeW60.A2^)&JORa(GJ2fO[e5*9,,D]!O-[9E>oOJ_#,lr%WLA.;(@;S
ZOu_4ld7Wo0a>JaGn=c-#18&3d17(U<o`VM$#r4hnCmr$q&,<Z][>1&B'C4Lb8l\S
r_:c/YK!j7ns?Vp)sp36EPrpgN=JOuK5lGFM#dsff,;u4)6'":&\T=n39AP+&2EnL
EHpFl[i\I9+3bNC&]Gl3BcsGU+Rlud0ZO,cE?VSi%e<e@&h>$EXUGIPM(tV&dQGtK
5o>bR#V'I2&@.>E,:)W@,g+]>P)T:bq'+4.o$T;3nL#\=ru<cqEY<^8$7??[km11B
%l,:W0l&(tAL5ahr\<pIkVWQbV'f0?.]4::n&Y]1?CfIa-5,VsP33(5b8rA<o<Qt"
NT2V=XVDJr0%0=]dgl!`'+8jh0,"!ZZC_nQEA-\k-ZMj5%>=%G1@+Nin$>(CF#Np_
K^dGT15ur&d1IkqL?K:OkYk[KP@!J%>3QKNku2(Kdjm#V"EAI.k&*[J%i$r5d5S7$
,P-IG1NbWh'0)2:3Nggk1R0(]#s$J62pOaM:%::9X#k>d4%Ej%NR6MQ`B84`4L<9p
o>]!1\NP#dF$]C\;qjJljDVB]lE]G6F7DIJCH`F)5I::!oD(WC"[CK$Ab63moD:eN
a[$UY5'.KUe/L_1fg4dO6<#NtZm]Z<kpuAfX3!.Ze1T-J13Lbe\#D^dM+"e2QDh/W
J.tJ.E[IHXh*_\g74^3O$qj$emmZH^7OgH^X8><l;+BgO7n=dnNp.Er&JD9S*qZ!$
$gaA,#.gk^^Wp6'CYq^*Bh69'8IUeN[&BD9.^P-k.k9XSE2Q=O9Xa8=\.lHsoE)<2
TX4-39b`E0Pj#&<p:>"7[VM:+eDF"7m7[(1"%pT8o!:u*j%hN0Z"oB/ME+K)s%`4g
ch-59CR1<l"KQK&dhN`ood$mYcD?dH;KW^PVZTT7@\6XF/*j.=ck*O+>=@!9\2;/H
C(F*?:jDY4L5X3C['IEHeAh"eS?a3N0]-"@oY0XN((8)RF?N]<BihHNUD9V/lr@5F
o0nqL>GrWJ8Fp"B]j,4S>SY@cm7U^7d9UT@>ufQ`kT\W>b>S#l?F@N!8/YTj]jGpW
gFkKm[K0bo"^lKZg1a_3ee)<kojK`n?Shjm[NT*3D*IY>@^[jtp+Y5M*,r>'Ac_L5
[N/1bjZ8H@/QM/]W68\:'4]TZ??SaZZ[lYl@q=rNAMub]YCgD06U93m3S%ak2JH_<
2eM%8D>$tC[Wb#\HTANaBm,*KQ>L7FYA-ch@Ikj'esg7eT#EU_Bb3^JPP8YYJ<_RC
6]B-&2TKTV\S-0"&,+am[`'JmQUK4_<9M_I(?KC(*GR!J@u&67<j%G'ij&$'DTC(A
(B\SH+(j(df!bTna$Pck1nODV@[@aJ8/lQ.DfPL2!7c]2ljm,/Ij4D<Rqs$@eBE9+
&T\@\CUP+'pGllK]XOmhZ$1&(DeCN(HZ56k+'3YT8!.q<=N)'nB3&;]<mu#DiuaU\
G7"j*;E#7A>pFQ\HWPoGCc-I7C`bTGBi4`(pQmHjRsIoEH4]%<=3Gusb^0#eHO(d>
Y7Z,g+_S81$eMG"GKFf<0lg?nGL^DM="SjPZY4(8E4=pq\*6r9Bm,j]9t-Nl9:353
.!,.;J6+OWM/.XmPC@^g#BcXKPd;b%R_=f\<u$Kn[g[=[.tYhIIL05/oJL@*'lk]I
Km6^M3*a;p@76JnVoY3Z\-%K\0890WH^HaC(:?XL;SZAkLcC*B\1rFlO+oWX172p8
kO"$Ys+b])LUOIEfW]lC[00UB8%?6ifYNLomu21gN4&7tnth6=e9tHOpc.)C(7C.A
k'i]`K3++\f912s4`&?_N`c$ppnNY4s+?^A7VX_Lf$BC[%rV1VLKLI0R&`XLnsid0
C)J=\GnH0A7;`p(D^^Tp=*^"2GECKDHJ'g,GqY)b^JQpT^'\kF(Xi>-6WSGuKipX*
Vmh_sNKJIJ(`427X"(W!HZka*Ihc==<p4lJ=dU#YQ2&Ie36d:=W=uc<S#b9bao-Ti
]7!b"HTA!mLR4B1mqLCiKGhaY)-(r[8P8aUT!acPfmfP1X-@m<R$aiaQg9#Z+e*Rb
Ru60N=lFb]j./4%T3<,)RBN790q]?u8,+<Yq<Xjn+a2BrQ_uR.qAabUeXIE4QV&+2
;*fm(pCB;Z<0YUtQmQmc6)5ldUj=>Q=W4V+Iu1A8VO?tK(u(jRn;9_EUW84gH@0o4
D"\YfDfn-H3fU+B)lYl6RbECkq6QtSf;T[eG++b^R/rQ#4fb$_G$;Xs3D5AFF0(hQ
FrJ\G'<A7(g2oC5WO@5THKV?_XcD+hIZdR*0WqP?if<m9E*DA,-U"WA4.NdN<9Uk_
atL%]+"s)pGrlbC3uFmZ[='g"H7:oM)_J64/$7P"O4p#,H4Z++2gfC`Z:g%]3d\5H
EO,GXnMQAT8oL$==!(LdRFRQ4$fRpte[Bfn[RWWlR2GWZ4`n5qR9=U$(Op`gBqlL?
RO;aPqi.BJ9:1'%ZPhQlRCTm*H%.iB\f&JWR5\<iCV(OkE-m_7]9KsTd@T$bPBTBB
BmlM`o:GgO[QE6TqmW,?B"2'[]ik_)3Z!9<KqTD>Tiqo4S,L+bA%h^<\Q^qE&\5H]
ms;I8TXj0YeGI$$,Jlr>_O;h@'q"j,dC9nUs-(>m3aoL":o&'<XP8ZOLGQm&ENE@K
k'Pe%#5cGEZc@l%a4tUS)r8:jqi`MEYcQg(r/bi%Kqu.KaS_cO*2f`YA'3T0Dqq[X
o)HiP\o-<<adD,3SAoJpbH"mo`-g%G>(NlGZ-&=;KZdA#9eFRohJQTMPfZ+j)'IBj
p!77/cb"&,)c`Y;3n2sjd"^)tgG?Z-;O7-CdiBCT`mN3F>aP?_P?Z""97M(BpWX^4
DOiYoS2IR<FW65"\_ENlI7_r$q8ln)NtJ^l44SGD/%g)HSiWX[I:Li6$eCfZ[^Vfm
*>*\@a!TVhH?u3HSDDgeq:,50f,[j^4aFsC*S:2cZCRi64QEg&_7;]>:"T2Y]5Y=X
RhHWYfKI!u4c.s@iH*deI1N-h$)tElJA&Y,`ndEGk4./]jNlX8i#W#T*XUZZ!,T@Z
G!2G7ILG!2)iO[piF_E8GgYNb/8fnkbWZd%Em`ZFqq/U(Y!,)2*]pEO:ZHmXPY`N*
SLrrP/`X(RWI4m24uMCALYOu%hHVRN0Z=t\e[]N5i]Y'=Mjp-kLs]Ogg0L\*$gZV3
5+hd@\:$m15'>9Oj/j>\VRL?K2g=Ig;jfe0GR*R!]nOu1m<N[TTNucq]FWFM`TCJC
m90[;N%NTYQe_T#cPY:%Sdk"3iL[U%]"KDafuLp8_;2i1lTO4iS->Q,LZj/Uf)9r`
qoe?Yq=#FOn653^*+Zj-'8/DPV-WhOID,1-"7t8Db'k#o^K'6b=hEQrcb@fX?;bkD
++SiLp+fk5=sN+!kN(NIpYJ:#^.7AA:T[g@o:D$:I_2c_Mtl1NXaco+hkB,DX87<o
i9YNNRGYh&(O%EK6^9V!h1>HqA*Nk4R5d^Pgg*pN,u[n6nGG`J5E4]qZhSrh+:mZ,
iX#^76(kGQ<$iCeKL6o&#Wt^('8jaQcm[+E3?=/Nj:@$pl9c/2^1=O;<3B@UQV6HS
)3iE\24DVGZ?aCMo/hOf?a&)s%K/SU6DX-RI4>U7MpgRh)MC]l"/40nobu@]X#@.P
W:Hr_I`Z0-=mZuo<N[u=Uebe\\^e]N6D@=a[n0"\4V"M_.WK4R1)4&ke?IS0j?C1M
^Hpm_$na=\1UfqlG0JNU3M"K/jdC>3c7buh:i?#cee4SaXQqO/)HJ4'ZGCD;FQd<a
-,&%#n2_MK@eZPUEVUTG<51l!P?]_DMnL%j`PlV=qq\[kZa7F52AEn)7]3iRpH,\j
'SA3bpNul]*8`]K4L\U=4\L9V.DP8F%Dr245Yk#]f<NXW2X[N#UXkL>YEU7<6?&Ys
qE8_;7d2=^dXLL,%Fb7I5R\#MhE4V-`/hj`>,]?S$#CTB64g56)b0:L0&a^o]JcJ$
XW0O[2t%t1&jU@r+NM;ne,o3_;I#+ra_?uMNlI4"ZRngc>]eE.WVh-p8.TJ'aha'+
Y;8<T>6P,7&S0>n72'LqhbMW^I#Tnb<-It+;WS!H:iksi5=7*AVS'LI,;e?%Zh,>)
;7*/M9.Uc6^E0Q)jVIgClTH;s9$$(u:fR*UD(eg>4ZOV5d.L;?c0q2J):EYmF'Ue+
>G"X)22$TfdBt77@G(9@NF'3(r=mf81?FCb=r*s7Zrq0mRnhZ1Zu9Y=p?fb;-8ree
\kGgu)0*O%rRH&HpOYJIa>VRUDI+uUgJ?]Cjl:X6(IZ@(c\t=!RGc=af6p[YmMgjM
E6Y_1e^GOk1;K&j%i%>&VAEZLf`f!;bRi>SFPh$G?^.DTqgg(tf_%t#k&ns>HK)EI
72R?(CDubK=cIEiBQXMrM:`]ii=aF7gng9-R;S]3.b]!6>!eYfM61C"L.R4_3Aq#B
UTLE:(JRS%c(@T`1u5(cQ*d`gCO;l[UMLi;gt_7W:<rlV8C#rUaH7NF#jXRU'2!08
DY')e%CDb7E."E,2t@q6(TYDX7hs?fg?^PW;)[;'hFUjG1FPs4']Rm7Yrm$OoDPRu
d*V_4",f4gUMDjRg8hd+GIo^#\*Fum9=ac1A)G:"3tHNtooi`;4>GL4%b.eQU(cp.
^;^W-Gr@UNo0RnT9?1ItVKB.me0eo#rbm#0dU(\VAb[gKh$*U=8-!YeZasK(`Qa^)
%]*P1!J,uK!PK<X"'6`.>&[(A)9<lqf_cP;A?hOga?WImb0GJjKU'?_9aXe![o6!B
&i,8BKqP0uL+q0nWl9AoSLcIL`-rCffRXR,A2o!6^%N>Q+IUK$i\1o2-6nmj$"=<A
?;V1P[tp"Je8qN;#UGKrfD;eIN')u[P_d19G7i#.Ik^6aPstml&*#KXN=Y#((7-dn
);7W>n]!<'W95:5X#PS^IAs%eZII9;HZEt#5!>gHp)MRj/Wn1@`#/d$i]G,,$0`n+
2h9YG9,j!`C"T`SSKHk@Q]?)tYoSUIOr]+V4Dk>P..gDfglqDr:juG4fj+0GUpHD(
]qrnd%2WJX_O5Bn-pd$_0B%l+>E8W[bZSQ#S.r2OZ7X[#H$M4nP_+e91*&ktf\7Wc
+d7oe^<.g_.@V=28eX=PbN[%SVPC#PY$tt`BhZA\9Au!dJqB9.]0Y)kaHG$7'[O;W
9-g9STsQild0Tg!+I*\9cuP(;[WrPCAK7JL>*%!cVb&<g%A`Sb9M=)F9'KmJC[O)3
dY_BkWK]<;ZoXIN\*6\$bs/-;StR%e"VOuB0W;<QRP&9Y)JK=Y5P.ZL<(`WNl?`)m
ne-c!LL2!1g;p<0A_L+)36u/)<bSlrZVc%W^`\;aOmt&UVhn$/A7^(ie_quL'tmhP
I3,ODk./"oVLbX\B<RN8[@'$=j_5B`YZ;6t=B9>eWgq(O1X4EBHQm9s<Llc?QHM3j
d*e%ufWgXNVPd",=Cu]PZF6>/<-bS!AX0BDW31>GWGPb`Q);"7C>;qu4R_W>iKb9(
:L*bqWi`DBW&A+ffqceUCU,La$kd+,d^s`P-+'RO;?5F:=D-r/>.BoeRGNfY;AMF_
^!)*';(Etr?qQa!QdpiJH!>CZo<l@GRf;5&nUY2I!l5@n"[u)qK3*L4V)U7;>)TL^
B18;?d5Ih-r%3WVh@tt<MD!\#6\q0X,UI]+b?Q@PKQ0p7__g)H;iFmrA(*fb=NtU7
RepQ)Oo;^WprD!0T75\k.EBYeZq^bZi/q$BRoo+)hj't#12@B6p;\>L>D"Qq*6#[\
CFuaFJMV<ii3?>"DbSBZQLXBU^3J2l6)-4po7h(jc;rk7%*Np;VCTs>(E9S?SCLn+
::[o:+\s*<HS[R4`]=k3e`f"?;mig6/ma+c1NQi.m[Ln.O$RJR5nPQKGGb#NcK\Tf
WV&^Rda/UU*3EVFo:E9g33opU'mHhRihtDXo1A:2Br\1f2T'e!?u17RO7fW1UGJ*:
D&*#Vo>[rcgL"c*4gh>)p<_RePAo`0q1l6^+jrFQjDF;-;YF*q_cgO[;B3e@2e6iX
>Ea<u*RD'8i?cIbmbgU`;m&l%_Vb/BH.OXW\n@KsE7+1jn(ls?G*``DgdYI\QHG#a
g'WtgEbjLq+33u=ro72VJF@)'4IdHj0m62Ib$1-A\5Wt"S@;sJqllmeomfSYL>=f3
)(7JOIcEQfF)fAZ/+&n5Saqq69JaB/hR?F,h)D5_4)o2pHO+,Kl>F)s>o0Z1?L-nA
j65oBGE:jG8C"cF3B@u*-bfcN]'H#3/P,O1\pDiI[&^l4&s6ipQLS8DGPAiKZ=:I7
desDjp<Os`qu"=$Ho'"Aq99:kYEl,7pWr?t-gGe4!qQ=Xe#]*u%=IoR\:/<$aa[sj
-b#f?RbFt'^G5/B-aqV$#N5M+#OGf4[+"o\-ZcTBmX@L8pn%K`7Di7J3)=iO?1[=;
:K=Fn?SMB0GF`bKq=`Qua8>e<W*OlR)UT"0`Y6+_H3.$O^M]55rf?iO9%gT2J;nQX
,KeOMagATE&Md2/5*Pr)""1I%m6Hjp$?I[X/-3A@[(Y5l^FTW)_e$M[b.ikI3?'o`
nXm+lW4pBj]2OTGr!,LaSj2OQ59YWU,2Ki)4M2Ol3l@c)g`Et0dm9/>6).I>6@(-h
ej7a13^UK]M`j(`E4p?;35b7%$h:nT.'aMVY(Cd/3dSZr^GJV<_OKu1X$FP6H9nVa
4:D>0HlbXs2j9[t^cTHH)MLEj4/GUD6UC?.X(nSrNPZZ"6Sn6s'G8"<o.@UA6n@Oh
1b?HcQG?u86u5@AA3`)ci'O54ZHPj-9A?n^:.4FI6W8e"'@Oeb;FE>m6poj"$Nif(
<PWEE^XLk)PZaZt>/9^=79!O1`)"@"9e_6*7J]WqgXa8)@k8$r[\R?9XC"G%(e-nm
`>iSL1fHC#<'9MV`ji@h;LM%$D[S+8."$#)(pCt0'1%S!%V0<DjClSJ84IBU7tbYJ
PT`PmD5NP@8&>q[I""RJIj)I@\r9'(r-l^(P/gO.a1R*N'R`;9HU^ti`-d0OKS-+3
KZL*Q87E-$gl;[$O";Q$aU/VN"GB;[P6k3NTY-@X=G=k3bK2<&80ctW'OaG9Vb*\Q
PUqa-oSgK%PtC6a8;l%gXGTUn>08Z@8jj03<#NgU2FNd,8kc0RS>eh;UWAt'b.,\f
PX3FPY9B#q#s>Oe4G-'1j%+9sM]iJO4Ldl1M+A&[95'CtTR0>U]h@")92"9`N4R3>
Nh*\BbUgY)oBSl![S.7%bTt)]e5OP\PfsQU$Ycceki%@\bXr#G9E`>YXIBTFc&SmQ
b1*<2i8RH2ZV/6bbgb(ZN1e=pY0Bpfbe2M^be2.f=@CrF9q_d9[*?j;f>Rm-c/dR&
oYuaK]a;X9:"3gTbg4R"iD*A6c4o6ZaLFokm7uI):@.FEr:!JjnP:.q:FsP`K_%u5
ohSid:Mfc$I/$Krq+mORcD97@[-(3.qG5oG:[J%Qo`%_s!Djd<:b;cG4RQ"P]ZnC.
c?/;634[?,c;8lD:XngZSI.dOi_[ild+o1"/It\U1f4\o67!6W%(O\Z'iA6P;/I+H
I2Gh@),ZqC;6:d7]c9no*DtW6;=,H&r?+uI+\Oeb`Xr_Z*@+NW,uS"q;JddZI4/!Q
.8l]OR"Zb[I1j";k0go5;TiBEgh0@;0/nkE+Or2F)fO1T/CQa=2N9RDPr;QV@FKQ4
du?@FSN8^;37((`9PlsgrBF6Z$dJW9<#Ykeb0<l@6I+Xu8W?0ah+!3#8(<5Xe==D*
N+C)!@+8$Idd5.Vm7\50pJgX>R..K5,*LGA+B7H"eI>Fb79!6/:ej_cY\dB>h(2QN
Zdk%,,ummoF^J.&?r`[!<Oo9U-!JRl@LTYPe_OZb9gd@:0\+E[M`"fH-!^k'mE;V1
7&=d%W3Y!eVbK$:etls&$'lXgD2A^A(g/nV[<ABHFYNa99UM#AigA<AE7TGZf:@$t
rE;-i:RK)aejK)(BUIBce4kX,aB``m-$\&+c.?*&fEf4Cq1?!trRd#JS)X+n<4Z/E
BsGX*=G;3++sfEuSQP!)=*qhdU%6cF5oV'ac0Fn$1(&jIP)B4(=ei-&8^#`iAMG^P
\XE4ql[fN2'2CUbftnY1eVDi>PM!M0=7qq`c#boiPU9qjg)YgseYUl/:tT%efd3SS
oqX7[X&p8$=L/XCA['p+Y<Ps.<qO>2IA]gl=W_r^>>'Y$I@s_KWS@48X&ZE/F+)f>
VD!))gV$GjJDdnZ/5*P7O"IDmoq>NQ8XS5p6%-dYV4$%3K%n7Y;`/V<eTb=9g"H9a
4-<*>7BKfFZJ*/*f^&`&S_)FEdaMLNh*@E5okdm7[G!do=;BUrp!:c4gKa![h9BW]
/WnZ0Z]Z?N?3S+#*Qup>jWA:8gs)q16ioDTk:cMJeRbI#L%*d"QW;SE>Rg.-W1(3?
MVF]L?VT4CQ!7PM3*kq/?a[&leaD*bled)^>ZHFu4n7Ea"$C(U>WpnLL!s6`mTj,G
g4Cu`29T38_-Mbk=M-Y%FoYoS,[Np;h^/5"Xo9tJY[FT[=_abe?2rd[]%2$7@.!Tu
[M[_9'@YMH`1(mXAaQtGln?WL?'TisXoQ8_&mNf#h_#t14sI-%Qrp3_?`!hYNJ-.@
%^]1O?qnXLh/_G=BOR+)hTM0kSe0kcS_TMX=EU%6H]l.H2QJ_`@h@b]ML_ri.U;[0
1K`5/Aj5+cj5R3(fbOkMQ#kk`WaU=V@Enr7;$)hgX(2\%fgZN]2@*UN3t>:`>HR7"
,^3Kf_MeA]jM"&o(0"geS)XZPicsKoll2[24kYiN-68ElhGWA,:u5LI>[CFkc2H_U
jPl1.^30tF[OGDb;@.5C@U<\Rd\>d)6t79:i1rBerOHE5<8\N`imoC9L/VR\?suN5
%Rr_="ghn4NFW69?4J.1XGpe&>\>Z;B5#S&D@;;UHr_![k8k[WVH;rbc0*r&@KaO.
:2sf&9kKtYkRc!P-#715[TNc\:rYNKhK7aBcY/%Xk!jmamY,6_L1KG'$XSir2N8.5
MJ%s!@h%[#V%uaBQr.1XBq5t&Y+&(=OD)&B9ST(\Ln!Z.TFc"7C"B"n/@0'H9iu6o
\Sc+rCS,?jW&WA-C7B_<Y,bIOH"prmdn[%$VQR?sXC/\&lRR0)5#ORrB0"X$CMkp:
7EAhM)f'W',7F_d*K1Y,[7up,ASbRUim6EoS-nhulm<rhF'(&O*,G_*?O"BR!NU"k
[HZgeCjs1T8lBI`5qg4S@dZlp%VLiObA:sPOT@@W2B?LL^H:Ka5IScjd$m*Dbq%MV
CedTbY1DWp_JPK$Z$(feV9,7$[52TZ]NE/5Ac'BnmAN=dDAmZ.2VTUZK=kNrRUWn`
ZhrN5jL#SdO<t1iIZW_>eh7AH_Xf&>IcP?d:S^@Q_\5n:qW7%#Iie4s43%$#[^be#
hE[6@]$B'trh\oaV!Z>i/EMi%UA3`[PMbp!Df3be/eorGZn.-"_(G(o-O7O1d_K1u
k)QY(.t2HTI4!7`moAC"&]h6uT^`^EDuN_HVVsNVl+!VC^b6Bf.n-`s#&KOMD?VYq
h]&p!S+1Z.m(W[?+!<UG*+/#amt<[$(.#FKg[NE6ED)40jPt%DH+tuOE?>*37dmTu
"m^dWn8:I-6R)'GcuGgNntT%N[L&Gi-kSP'&Lbe4`pi0k/nH"b4DTR36SI)X1[_Tg
D=IPm<pFP(FhB<O*p*lQ$%qj/^N<-k':p<:`+!Rb/aEnKFOmU:jZ2i03V<IhCEHG3
7oOOl61n#R1I"o_CF8_(=>?FNFditcY?N]I>]n?]EV6U0ih1GO?u8\%l$$RAhdL[h
l?5s7/[o>8C<LdMBO)u]E#36^-XTi^D0FfSG40?ms)</jqXuPVG8G=E5BM*FFa%29
<&XgN]4=c'GVgLfGFLD_YBr$CI!<aOpYUES(OpZ+$$Zu30Lp_>.fX`XKJ.JRl:6VS
Iu&?1M0PYMG`QU"Iu=$INHj?@Gjg]<Vbp/&^.qdY9ZM>P5EpFhQ$H_Zbf>kA-]?4s
Ojq.0H"WUl^RTSqSPP4"9K/=#PeKgJc"P.OSnFb@5G7fY%s]:gqEL^KT;N%sOnjcQ
Eo3>1-_bp4ch`W;9J"fdeA=s^XSU>`HJl9$onH4A,#&lYq]WQJ1pd&Y[#TOIHXF++
EYSA2\BW?r&e)KIO1BVS&:-RSqPR\GJ%1=WO8NA)HuI&QIu2A8Z[)SbcF:Ran&Tn&
c$\EoI-hsPQ^@U4R$a52r@cWJ5Lb*To_fW!rE%U!J(T11SGd*:0<*A)s4i%Al2@W%
LX4cSaIn=PIXU,1-3)kO#_!$YjF/K9UqbrI&*3^sk4ha6IY[4f(Zp181Oai4I_Xk>
p[EYCnUDYO;@i5G5MuITi;[0XIrG(2J,"MSq1#%5J$8a!^\iT-rI<`(#Qsc("+igH
d!.r*'aoa`@F4e&7O8_*7:OYhF8e$9J&'s(fL,3a,EbW/dWn6X<@aA.A^^C-`ZlUY
a5J\lo]C9XSkj"Jq?7(W6_[Fke9XP1PtRuQC"3!57\s%`<GL%jU`+(nX4M.;qZV_n
A$T6RepBhXZNZE)/_9fQVWDm1?#J8@`THhjJ(u^'a9V~>
EI
Q
showpage
%%PageTrailer
%%EndPage
%%Page: 3 3
%%BeginPageSetup
/N78 [/Indexed /DeviceRGB  255  <~
%1EXR$O[=L$47(G$"8VB5$*\`TDuj]s0oJHAnGZ!bfg%e!;,pU~>] /ColorSpace defineRes pop
%%EndPageSetup
0 0 612 792 RC
save 1 g
1 i
0 0 612 792 re
f
BT
/N42 1 Tf
10 0 0 10 72.21 749.33 Tm
0 g
0 Tc
(KSD/<name>_<nn>)Tj
45.334 0 TD
(3/7)Tj
ET
0 G
2 J
0 j
0.36 w
3.86 M
[]0 d
540 55.03 m
69.28 55.03 l
S
BT
/N43 1 Tf
10 0 0 10 71.83 713.33 Tm
0 Tw
[(FIGURE 2. Cr)18 (eate T)92 (a)0 (r)10 (get Ser)10 (v)10 (er P)20 (opup)]TJ
/N44 1 Tf
11 0 0 11 71.83 131 Tm
(\245)Tj
/N42 1 Tf
12 0 0 12 85.58 131 Tm
[(from the create popup display)66 (, see abo)15 (v)15 (e)0 ( Figure)-250 (2: Create T)80 (a)0 (r)18 (get Serv)15 (er Popup)]TJ
/N45 1 Tf
8 0 0 8 85.58 96 Tm
(q)Tj
/N42 1 Tf
12 0 0 12 107.83 96 Tm
[(enter the "T)80 (ar)18 (get name or IP address", i.e. aocpu4)]TJ
ET
q
342 0 0 504.0001 125.92 196.9999 cm
BI
	/Width 460
	/Height 680
	/BitsPerComponent 8
	/ColorSpace /N78 /ColorSpace findRes
ID
J3Vsg3$\D##D>EP:q1$o*=mro@So+\<\5,H7Uo<*jE<[.O@WnYLb+hjrKKoc0?G3B
>q_R=AlC^cenm@%alQEujQ^q;Q;/i-3[GQ$8#0$mPNi#=Ik.GHC/m<k<ioH)<bk^H
j`\=EYZP^B4!g3;@AZfae-G*Dh.O6&DHAorf'R[o?>ihFrOUlOT0FuR4=1jRLW!YA
='Q4>ZNJ2-E`kN%="TTTe1Zn2hKJd_csC-=-hUpfERN>.H6$Tf1I.sQ+8O`i$X:*H
_;uW9rpmD0\8W`Uc5,H"Gh9]ReK(.JS$^K3q#*82(NmZL9!rW?he&_%e\?G,T'(=&
hVma4INKYiam/S6GeHgh2Z6S:oD0I\VtR(T5#;X!!PQi*$Nme4<"A7[Y[eOD_(\h1
!PP_--MbF#])&m!%V'2N2R(Cnn%qkAi<VSd6nJPA00@Va6.!O0(cTj$;%CN]C)5I>
nH8S,a"RV&o#/msM[Vl^1lVl5E_:fL8Zr6WoXf)oJC$lfPOu;lZ2Cd6aAI=`)GEs)
'cT\`1^u4ZYuKB\c15tjbKDMJT"crMS:^N-0s&J":Xa./'uH)4h(_IM4Sq<;;q!0V
_p@-07mqC!;W'VkFGd'?:_[ISdgu[M)T9#L:J+7m,df6tZLq'rZ8,]o=gXGlT+0*S
D/!:]:CVSVX-A4)gHP<7NFUWN`J%jUQ>N05<n;\qC"eM/QYP7jc*Xf\p>*E#g^:0q
E86d3^N&&\:"<muVq'UIhA;15H/=mim<d_,c1QMBQgOa$i"uq-J`)nJ%>3UV:%oqm
LXG^KiY[\%M;jo*/W8X+c8CUAR-m+uj;AFrOlVo_9p=ZV:0!8q(h6L"AU0;IRHBp?
D4B]+c?5]==_s.ckF)m7U$.ptNMG_UVL<XP3c:Ldl5G\ZWT-$DbF!%5cF'e?RdRkh
jiKusYO%`2c*QdU<l0=PHVWD+mMh2DX#56Ajh't#cLmrMNqVjqTdRt\R3<HG$bbk>
Ih@n64;&NnE;5bEU[P^1-chtVT/4?'I*Xa@E-R.&`T#\1:!iCaG=U!MGiqSQp%g<l
TQ4=.!R5f@=$=k'4Qg/0oUM7:e9Dj,A$U6*[uZLDIU7`]ls.;HioJs>9C$hO2lY`p
SgTAWq]<ckja<SRMt(FdL=tg:]KZMmFhBAg`patgGOKudB,gVf5L93)TC]gI:@[m9
f#mpK"-.nm-3:p''^]9J%t[Rdp;%R)q-U29IZS-]5U\\rhrFr_n/76MVZ&p<qt5Y<
h@IB"3:1-YVh1#5&&T3s%3W!iLCdo1^PH^iSQ$MWnBLes-u/l.*']/G_<f'ARgrk[
'SMSe*lE4LraG.QM!XfB\+ld2U=75@cFt)a.$#+;<*=uoQ8D(0dg4]deqML0%`W/o
*?e*lNA6G%4Qt#/U82[cn`CQH3(V)`1REDbII+`D;'4bmG`%X/*PZ:Olpt*=M(u^A
4gqs8,bu<2Eb6[jGXWMqR157@$7O"3.k)^M4Fr[4!(l<-,$ks;P)aii8JoP>UZ?`g
/db\&M.IEqeAIM)9s`%=9^EhdkC9cM8^(k>p>q6LQ#\K?a;I>bTQ;9C'!<cZaSujF
2!C-DmQScaX!XNf/Wb&!GtZbNo]1+_LpJ:>bk^-MVdrYmF-:?8Qu,&4CkIK7-'$81
JNKP.bG#OP#XTr9!h`emPYgM$`(E$;BY3_cD46U&(cMdMg`E7Enqb&,4%:7oqihe0
2F'kt&"iLhKJGR[0kq^&-7$s:'/j+F3fLu@qqQsl*NrGRR.i()8u-SmY#,P)n7mqa
X&X&?2%$ZkCB\.J9]E8,3mCgn6sOBn7^Ub#h-8QC?*4peMN<Y^?0fITY>t#)=5*U[
lihsE<XuuK>7G$-5knf2QF^,O'4^B_Og8"_b#qpOh5k1IXVKR7<5m[&l]VmcerJ0^
>>8htgC^Z,<lJ4qNG$n/%^d(tg07cu?^i(&[?eDUfo&3q/T&.;2T"A_H]<$#e]534
HIZ7>K]t*8U:91Fc<U(jFDJ;,?,P[h>g#QWY-WJd2'V;@>Jf'2`S@utDXQ8gD_8.S
?bCS\o%XkCIIFus@Mbp7Yj8W9mrU+p/]RV@/*otZL&&PQ])CBQe330ss2#Rui%utC
JCuOY^9N'PdC^9NaUScj\,t[K49JDc"rG/cNt#.!f6?`C/XVoX)A4SiGO[!/]iWLu
h?Il\EEb<>XYUf%.PXBQ/D#N90,ip"23%#Uj1@;Af\Gb!3Lqu>P'E`EZQ+_MmVIi2
n^ZIC*6h-^G%i/R6QKWP8!Pk<V8-%'TY:8#5B0_0A,1Pak8Amf,^s<R<4=_u;C@qa
[G.mQ_]lt<pCK+BF4+4G4Yj\Fhm;u6b^#sXBrBXX[/gcb"5nT3N%'d_<fYT>CK8aX
Xef/YQZCe=:?Hs.Xn$'1e2m!<hoh:go5b_\f[!U`Xc8lnL<8!TUKKZP.i;t'n]:I=
#4'O9W7T<BLmq"?_<?<Qp1:tWfK0q49m*kQ5n_o[f2?@3LRrW`i+P21[VYogU%_=X
,.jt7BV!t?R25;K>DCLB4YfKN0)FO1pBP3QrHkgT!h#PfS8V).]ssh3]f\B"mB/4r
Gdc\nr+h%rrZ<`e#:""HLHfgVNQ1cQ*T\9OYB%l,bo.r`hn7-@Eh77"3O]jGo_3<G
XF$^'(I)Y?#?3LN-*0-c<Tt@bKlp_(eb[<h?X+BkFI+l5R%H(9]h`hEY0GYs7ql>d
F"hZ]:H3'qC?b[aL?`ZlhXEA*dTPJ@kA$p>2>4i#^"pAGQj'$:VTJ?Kn"k7N"gEA!
Eq%oZ@alulZ2:+Cn_OYQq%h*5qra[AhH.\i%l^^Tn"+=OJe2e?)n38B5P4gPeG?&Q
lPU5$k8qqBqe"gT*/D7<54cVg-Je/.oS<4ZkMg!DQJ&uBcXd&7aF,DMoR=+lqOZ=*
[-t9o=V'9:s+.*Hs2`6q([#SKR?VIc?2B%L>Q'R<AUD'1j8L_%CHp)(GYd8t7]>qh
hLM`,M($IFcgLfDWrNL>_e6ROO"g*_N:p"=?LSg40HA1F7]<L_rib\!Xk;fu0*/3a
mE\?*Da`8SFRr;rb"K8AO@El%"U+<n!\cb>lu<3U(Bu4Joo01!%ALs`DX\2M\;U@k
&9t:<140V^f?fJsDoW/<AI35V$*Y&\bU!Q,Uh6h*VQ\;7/0_q"[0pSZ$a?Gsbt>hA
G798!$BWnLYgC6`f+%5I"KoEJL*H5.eIHQg#uL!RNn"[q"V>8N"9n<+VMMZX#n_.p
&Z+d#::CfHgCNg#'!I>,E@hhWTbA"q'<g"$OZaC40bTU;'W.V20hiB0LD:D$'rTLp
&R?/!GnlHQ(8bRWO_km]:DXUc(TQ!NZ$dH9<u7!Q(oG+`Oc:5*5o>`L)69SO&Y0gl
Kbb8s)QR?dOf]QWR2[l7)f\4CdCC.bJJY6tO9rB3dCg2bS9^!_*>,OkaR3OJM&"Fe
'$0L8MI?btE0bHDq/P^5Z/UUsI%Q4,NR@UtdJjhW!hH:\Rjnp\&ebii(Ep($a[n!*
nduo4i1C>6Sk6ScC3:#L,9fZ&M.r'CC')]O0_a!c+\GAp.W5SB7*Q;5-*^)aEJ#Uc
74/[q-W*"pnY7JZ_\COQ-uh[(ZAfOGOXW"B.<:ghd[_iW,q:[H&$i/aZ:-!9Yns^L
.r`T\ZFpT;P&X@"-^"gMYEW[6dk&hg'8b4\&Fh+[g10^,*9Mk(kj]=+8<jBp0!D@E
.02&>P6H")rMXh2Da,hq/pmsg0X%*&&_Sebmj2iQHBT=hOg(^!QR7ZR+"n-O9fU<e
'/XEPUQ8n5#4F;S=Yn:AnFC%QDdM2H6Ak&>+)Q&B8\Zi28K;GK,0^E<ap*!F32Q*R
+)4c?/\`E"=DnK",r/1RblI8IMONbENUqnYD'GM@#kmjFTX$W&Oska9#p=(j4=R$Y
.KMVFm#Em:2`#iHOk,I_+HK)',-PK>WA^!<VQ?a^TdaZO'/YtG8sbO`4`bY,e*(f6
p8&GNRZm<(.>L0pk+7A&5uUE;ZkG`dpH,?XS+Frnk_1bu[m5`&R'WHSaS'Uo3C0`Z
4]C<"Wad'L,g<VZJeNJk'(n2J7\IitT6#PQ;F$ST[6W3M5nk`@PM&7Dila)U7VK1U
'R;`uk=@#A0/SEN<&Y^/Yqp4"6&I$3P<Pk.X[9!@V_kp)nn+)l-u$r<9_>kTPhSn=
h+R<HVXlpH1U*n/a\ELkqpMkG.Z5i37jt\I:f#Uj&]%;o%o;j5'sbYQYSg=2+TGFf
;KWciMf2NO2,eWWkKKu*[6[bL7'[<Tca>u:F\u-r<3J!N<HVSIogIS6Gh@"PoegG!
Y*fdi>uoK='if;=Z#s-1I96)[(0-&)[>@ti;cr^F<_hAt/L+D@>/&O^'\/B;eTY2>
Yna[M=V\>KeOn:!X'9^p>OYKn<Pm=)>?8/V(H&g0orVN,f*$6R?.I\8Q."@49j#s-
<u%9*e^n0J2d!=p?FAqtopK!kj'OD'k4S4TQ'GctY>Yk3?reFUQ-j&`B4<Sg@5]17
;)l.i,@IpoA9G4eN\=hl/E>:VAIC5&O[Wd2<ub54AQE#Eotb-=CKFNH?M8!DQ75pZ
I:i1=@Z_[Ep5s&8k?r2NBi^d=nHWXK(MX_bC9GrlG-,O<Zsd"3;UTnhQG!ti.r6lN
Cj*nrf$/%"T5?L:,;cfFZB&f;i@9$4DK;js[d>S'het5)X7YVIl"s4r<37T*??4Y*
m9lqKb<JqW*7F\t%Z*Z0F`@Ue5.<$roT:6C5ok.eF0d*2o)a'a7)^XUeVA9g'@CZ;
h*s=B1:KhrpHp]K`rYp0RnpjOG?E(K^J%76Dt@$dZSs/Z@8+&fV__M.mAaqL__d6q
e+-n4G25*?(J9i"3ci7s<)6)-;)rY:f#eFl(KtOP^ll%?5?+gHD[CV%5pEYs7EPIh
=!^E/hfG-r7?flSLUD<I\uF2_6>l7?8\$"d<?=*fIWJM9F'sUj4+<NO0a=;3e*TE,
`h;u;kP#][BpCn3,_e.@Irlo,ZPu@??%`O_Ig<"(Qg8pA4#63bK(jILf>*po4%^3`
+nt@dM<RHbiIclaEn@@B\0l`$D/[Qi96A!p'C)FDo6D!_e$kMudlTIpjGk#mGuA!-
.2e!Wdu-2@D[%kKQMBN],CVVhq_CZ\=N^;;fo7VLNHj+=(u:2>?&go+N**b1eR=Lu
oX=J*._,56q#IdEs'/\)Ae@AoR0/R3'X]I*YVoWpR/4j+(Qs%F_92i9p4\Yf#n[\+
\M&9l\MIl!!E]pk%1Psol@"cA4cpU^#rt]h:<?\,9agb%?!0`40YkHM`KLjgA%?A^
=Z6l%Em:eXY.7c$\US%uJn19]]$Qs_&<E0CiKr4TR-$>qX.PgHE=\@\>e-nm&A7F0
;":bnD60Y(<Y_'k7?EpUQ`rC?09!Z-Fd>$TBX*+hP>Rn<./6QUd<X-/&&FNl/Mb[e
SM1WY%d`>$F.Urth>,m"\b>SIs-5Js@TjY6H1=:hY6\(qT^0>H3Ybf.^Qiaf?>r?#
g+/^t0:eMt%Z[:qfcOc#f9Y,p%JjG,q0?N%H_bXCT;qXWRMTS)0q-YVm]OU$(-ea$
=f@Vu$L](8)F^NKJZ4_KU3]\82M%IqXbe^CWm5g[\s9.\O*'(XWR!Q]p:%.be6j2>
A%Kd_]$0gVh5u"fY-AM;=d6Q;\PF%loif$WE+]C*US&#"jq'*o>6CO;4g9k)Yf5\a
nt30?'sW$tc2#Tfn=plU'*Gi&q`3cDq7.EJI%30_N"-)^9M5e6]+*.<[2Fh/;KK7.
-(&YXZS@pXfj+sS_Z)BZ[h*fp3FTADQ+,+M\/A-m4,Ko;7_)@i[MHUgmJX3BV.oH/
YkoWW];N8!SIui,](YlYYh>&+^uCj&]QdY@qor%2FhKlS]c5XJqq\s\c+Z:#qHM.W
XFn7Pa)J+Xi`OTdqb8f0/ri$qA@qK8(k$K2c#ksSB_[s4=MZ`I%]cQ_k\kN`2dg=S
+2F'L^t\)!8*@bE(4,ipc;TG4]J[X4Vn;A2H#l]<No-?@D23-&*u''I]DjL>[sAbE
GnY&7fT!qn)o-Zg1g$QV]KXNJ`f0YncF9c>$3)-sT0Y<*E1D,8;ce>[IfaZJL6o/6
1PD@1`Q9*%jk(_=gnTK]EQrlFLCtu'B<''4iQ:^6cEL9AM6"dUof'PGhn5,n4O8@5
H[V+nc'(H<'^n;I^5f]P6F][?4W-"HBh#TGaI#3=\lY3D<Pl5W1q_@[h(M7R5+jk(
LjY\J*;`!;J=N.BdF[0@\#Ijq_d?\.J5fB:\.M/O&>:*:_*&Tj=F\Xuc$)!Yf6lh8
BU-dt&]/o-MX!K%.P4=ign`P]aDI[o*)S]iS$/($aRlr_Wb%%"E0dMGP\_"kRdjrH
)_ep)_b,L5P2ba)'R2e'EIHdTq8]!TJ]BJube*BD4n%:oL#>,t[GD5JX#8i#O-5n[
Bq?4$q',Fe+-BR$icuo>4k0$`C:2W'bI)f8]<'=b2RC+Ya?DdrjmfN[TQ_%!RiY&*
?:tHn,7c;m=Jr'`\X7$$?)ie2jt&7Jn!W=@!-Na0mX#i7D"ZuG$f_V^c5$_\355g+
e7U;VeSE'*Suq2TQt"pBjXhm8?+Y?(aiO'Xd!Wack#%i,)dg<BlYthH<(tJu:[VF$
MfZeZXKpQIH--=cjm*lJ4C,)FZ>,t^lb#poNT9Gdj6$"9nMD;c?QBpU/+%MJ>A:A-
?>sd($gnMtnXBbf*MY\\'CmQ<ndI\P?B]&OMt7qIo3U3]T+0?n&b3UZlh(>#haimE
9q]mXnnZQ[4h'3P[[Yd`DdPGtN90b_9nloQg),):5FLm#;t%lnAm+f#q;Ls9(\;DA
l8*!=$-P@mb6(kG9rLBj?IefCqX;L_e*n[TbJj/B_QXK9qMOJ4cR\S?$i<F*+:kC!
jp;3=5@:VX<%\abK#?R[(mIcE'oPN@&X_'c3=gL$+n+X]N_(O\8`5[Yb^MnSO[1;a
q/dB`0Ub_6':I(q;*COD@F=:,/f=P[cfl.4<A#RKVGlaoWDm>t&;A?id&EjJ[j%3j
X40_+Ehd3'<9R/J'K43Q[p.`I>/eACDmVs9;p2<2gNS68m8Q_io*L,1gp#G":&6;p
`FJF[Hi4H+7`]02<9j/&0qF54,'g/YlTM)NjK:L:(0aM8ZX^Dt(bUE0+PCW(nJh^h
rI`mDjVn[6QYF%cE;19phH*Rqk=,/Nr.c%2dHP:h>,j57YMFhNqq6FoHbn[eG&TUZ
2m32Bp0i>ss*pY<bLQ>NHoV$3q>L=Xn,rgo5]@tV"$l?D%$dFr9H+4&n:W"m5HWDA
Kf@?$V$98*j?!l>n,cZ&6uaJF#XY^g0%NBEA6Tj=l1=977M2G3)b01a;VoB4`-WRr
nC0$1^Cg[-,=q/pAJIb!7%5Pql=?/'aqCMN.n29.0e:FfjLZ*bP170"9QGf_0[,_K
diV92jOH1`nV#RB:(sGh+NIDCm6+6_"Q_gCoE0(t:c'I*bYVu;'dKLGAK++dFEJf%
9luX@)Gpd!$MQ*/brDXP8A.9[d^3hHSl?F;P>n9A>#/$nN0;.TeYnaHfi@Lp,?Z8!
Z7B7ZoYMa1\5ca):STg'7ZX/7AXd;CMpfVCfda:iA_GXU5uXP%UK_Ng(1V&rU=UE#
ZIgRRLIosoC>X'<Q#Z>5=ms<mBdoBshZ_k\$_(,Q=+pg'?^DC"J0sQ@d+Q/L,<:CQ
(X7M^hJOi&G2OhK,Dfc_^'^DU(jd?Cg_fTROQ7hP'VI1i>/Q"?'_Q*^.dI78;(O49
adguHY"*;;[tX73k*`AWY%LgJ@@O=.6K<p`Nol%`.lj2bWTn4Bq4CkPMC5Li<gLM$
k*J3:2Vg?)>F6dQr[sT"q6o%XC72AIWA+0tJ$/3Rh5e/*$NB.um]+:q]OR9DhmMlp
7i@Y2M8'>-CNlYh>4&sM'uf=J>+q3'2chT=l:J+9c#gF5;:KQrCYQdGG]mH>o6ls,
eTF$D8]kDJB4HU!I#;-Xip2ADNqOM@/Sb%e[o^mlcc8CoGU_0=iVD=(Dr7Up09'g-
RtZ"Nq)uct^Ze<K]mAYfhjDga4-!dYrEU3;k489FAaE#QK6#>IVmuD)]E*OYD=]_b
XNDWZ\phpBcDejgk+@#*.rTRC[Dc8;i+(i"0.=\&\2OHHo=o7jm%q8eV$LIUEc8,&
h`#1%i1Xj*KF\X)[s(CAT$/p4OPU@+omHmLURQ8bJ]PXe?No5cdtmFOHaB(\j-qNC
D!W`Y4t%Q#h(ls-:SFepVN0&-C&:/7-)*R/+MFN88SjN?\@$IDL<pW#N6VUc1O-eY
)<7<K8-UV/#0.cg`,9LSngZd;E4XRt[m6cYf">-(U?%1bF64AQV"lX:UsWmM&QH_>
[#6=Xg4>EmN`/PmJH'1KX-JjF6d"(j/65`MQ;Z:<)B!6@jj^c(ZL2'l3I<FA&qlW.
%V$lsM_X?lE1&L7B-rJ)1Zjj+RPR]S-!@9+k0ctn1N%+V$+i.Z&iZ=:NcRc`F#iD]
Mk)Z,G:'lT46MbaS?pLf*9lcPkL+sR1[]`6C%FRQ&Y5RO%YGXeqU;1P#GHkiccD;H
D]b/;Inba98dRoi@M+<h1c4DmQtm,kHJE$&N2/2.8ICC;-Da?*Bi+ShmiZF!@k_co
1'N_6+k02?`U9$j\oc!T4YV[%p.&%BHFYKITr#-tN#,*88a;84W/M<e5DUg4T8R*)
0.&V6LTJm+RlH>GN]fad#kM5*>ciu@Z*\07dc1IHN%J3-a/[ruicS0o2-#N6G5WI4
<()ME!F<YmT*S^c)QpLm)+1;*A)&$2JrrAK=aL<TX<W+7mOGW^$TCRT"b(1udJCT@
-#-kq3K',>``Yif#G@>KI.*WV)FmL1i']&M&!e!J`nbR8h6a2HJsa2t9bsct6u29]
UdGD.(2e9"HShbb^0(H[DNj-k%m&3*=4nU2K=7a<(0A9IMZ%"D6>T]^mT%l>Ct]j3
L%c&`gK+Du0=@ssFdD=IaBa'EK8m54$N*uDa_;^EabKN^nN^koIU%T8^'t;73'/2Z
/7ju\2T#=.]CaHhbW`A#2=9'9_(05O"DcLiU,?PucJ:"nU9Wgqj#`N:,CEk%=Mj2\
#mDI2h5JA<2E.gUK,N427uA/;02X`\80j`RZGq4o)I0I9R8"!ceMtLhPM_`_d;P\g
;^b4RZ=Y[(@taZ!2J2TFS$Rij06rmFB6/]qZc7?#3U8kAns,cQ#(nQHqa+t?]:lT$
M_OuX7VM`.H1ZiTd5jomBmgqs[)ST`13GVAbrE9_P:"OhL+T#UZ^()NBp%,9(;s[K
Wmq$N2=ni3X3;-UFhR(`)XNGR]lfT7QF)Wl(LO=.K1</?,M7[Q>APUrY#^S0^RFmM
/kqJ8p/]),fLKW?C``"9m\SU5;ePL2^/DC3aOPt@D^qlrF13dAb<)h?mbKCkTH<aU
G$;)_c"4KOrF"Lk)N!>'`E[E%)lm*Nr)PEHGbXWtU=eT"8.++VS9/r62.M>?c7p:u
W>]2KNm678;[Y-p)r*>WenrW:b+.R]f@Fr4_RFSiq-0$FOkXm.IU.m-VUX2pmbhUP
6PK4f.#+4`FEA<RIsF,=j'<,[)u;(7D9jfjh%npM)u/SGc8^;8_\_:FX3N;@??Ua`
[!"E#c9$3;hd!X[EkX,aH8f]t4l9ulh6fY^576VB=0$EL"+:"^9C2P6AmkWT^FiTA
fj5bfor_#j3HImTFFR#/c>D<FG>IU3ccXfX$fF.!`p8&Z[J4X#X8N+,p7*b7HG!J"
4bm;:Hu#^,^D5Mi)Qr>TNj?3eAam:?]PX7<2.Jk7jLJm^p"kJOFH9_Sn*q^j+'[=f
m]5f*\'hF-X4$qfk]8!HBrmT++QU7&+[9OGrYO&6G_b%gl[L+;s3lW[lR&nVkW8l&
Q:(M]ijQ-JZ8mds)3b*6X7j=j^FOC/3c!'L"'dYZ5r>?^Vjn4'K?gfN&&?(C_&O(R
'1Y>M7DUeq1=R(*BrrXS)*sc26*)"k]Gs5*0>CI'%pU*jr#e<7+[R&K6.l(NllRKM
4c_tAO)-",Hmh=<8rk58)=/e=]IZAh.O7RK6;]m4A0+'Z/AiG_6("Fb1b1pE2+(M:
6Tc5"R-R*6qPDCqP+]FTn9lunQ4kN*S'4!f^q<#(4$s,qO-DgqENU4)l9hNu_sBe0
"=kbQ64oUYP=.nWUdYnA7M9f9Qg@D_lPPi`8Wm3H4QF7H4B+aC<CL.n7;Ptk=RmH2
Do>mH6u573jB9BNn2Mj:72[Pm1Eel=`^N9o7<E$/4B=n$n&:EG`M2Z^lg9bW:5MqT
`<)Jr*'(C1Wj/U%`^>F!*,e=U@n'>I/jsa"Er%=Zg;W!e7(BT>\G2!(5fN7%7b^n]
4E*`:DFYCi7<EPgEg]H$F!(8Z7p=_<PZu1RJ]E^Ta.-t_Br<lC[)eEO^h_'4m#4CJ
7gniua$TO%>7qNYNJs*^`R==@Uj<X6D8%eP8&L-Il[h[OR5m"K6q!%OP`J;ETh,BL
8[OXP`03[$3lt&S,!!]R"/&55DonNH8CTR(&Q23Cp+?c8ON]o2JP+!oPEUZo74P\q
KRLsQ#05Mrb%uQgfiQ=[$VI-=%pZ0Y9VAO6PXp0UaGd<lUnpY/\%!]sb:JUq3oe9e
g;kc&alKKk](EnqThCn#7&7FL._J$@boaMQ7P);EjM2I/Jj??R^L7r$].(tZ\Otqo
6nCsBeB?*1eJ/eF&.&faM)!7h!)7i+b1S_rlsNOmh+cDCNbU=DJMBk!g<.pabp:<J
,i$Z"j\,7&c5]PIXA2B8hbBp!4@Gmf/B:06k`7!j'U6!<gsAZP\<JQ"9g%(NI(2oP
02$]_7^5<V/B?$E`%&.e''rB>UtVWopeK3`capm;W@h!;da-/3cG\d>1ESM`PK.'p
:_Z&e'PP45@`dt=R,ihB<<CH.?dM3g[J?!qPm9^1_6BsAa>j"C$73Qo'2`$N;/#r*
e9[A6ER=L5d6te\1o`4AFXhdJ:RqHC`>;D]+V=Sh8Q?X)RA6ghrB<<`%"0'k]c8^G
ON]P7:oqU4&PNURmk+CYWO!7tFP.n0$qk'4b@pKG$9p![3`8*n82VjE9=0_tktR]5
;&pXuh%L<I1_8[)do:0_@hMYoOAX^6O/,n"]dOAho"Z-_drc!e>so3\=]3L0<#%=8
/N1s`Nl`;1<(sJd4Zl?=.b'-DeFHnpUl2GJrBQ4>X/")O<-JZXGYWV-[Of`:F]cXh
;^Ksn(kEW+b]D=1o?aRm;7^,ble@Q'Bo!aDdiA6Y6u#2,:Sj%]53*35]k,8"?-eLC
d^<c98n$;Pp!9"R)'&+.]_g;3:Xerl:Z3R#9lj>Lq,4JXf8=-@'lMRLB#F:e<ulSl
]ma%r2:<Ls;B5+!%7OANKi)E6Z"8)OW]o'@M%K`K&36?7SW$GhK35O:bqp\'$l%@k
5!aUZ-iK32.Xfu5PUF/0=^2J?%@8l)QJ%.>=e2!/;c,O_BWL1qNsqH_jdrm!9bm>:
`[aqij+eJp@'[t=]D7OHP+Gi-a-_RY2Zn2+*MPENWj]mK412(]`E/<DijEp.5,6j?
X,:*:XP12-gFMgJ"fP@ZCKgrhgCt%+X*.\6\LI,fgJSI7d)Xm`]NTa!>7IW;%CZqn
LcuK2]M0\&_gncpYs6tb333(bHk<_JS@InLU^^?g1Pr-e$Jb<s]+]Eoh5&inbM8)\
43S!qKC[f3h)9Z+^5:(H_>q;SYdqGK3h,bH*OoCUo=[egh6j*6URkcaj#31]54]BC
/+^C=h*3^B?5qm.]sHPbdCoFKhQ?31'<5=oW*D4)3dpG#Sa*r>o34B"hb0fZrM<kT
n_ZZ"h`K:LF0`4F\_d`ag2!ZPbD40Pqd.PDhZFh<^"cqj\\1);9U'L&[Bj6S)pLh3
?^%,>q]fJWb@#tlSm-oo[Jf#HTUG-*gS<#ejX/kc#gAe.\tk3J2+Ftu`F!u%g`@2<
mDD&%fA?+1]7Z<XIN)^m'r#HEg>gZ:XkDRLUcpl;50MfcdC6im-XM\^i*F\o/*(/'
(;Brn//BC94jN$S/)OA]@kKB@Eophc$t@\5bH03!$Q33e).9#chE6/.)hHgfb"tg'
^h(Qsp,p-3q)J=V^m"];[QV*@OKqgZ1#)Qb]:6R+g:S[3^P]@s*Lg3B0e'[EfnN38
2?FfJ:Ls8fcF-K`^/A)T;<:E$jN^dQelQF/CDTAsAZf6'T`sPl?"M\YA^4Unra&JN
qW7uk6X=Eg/n@<jA*-NuAl`><M*P%*DF9Ni`0CF$ggEPdA]T%0cdllq%<khiW_S4?
B&7H<I74hsBkIm)B-(i$78N'sDWd=0B/o1SCmE_n;9s;<6p>nZkr2Cl"D?;6cm9`G
/pZYCgZJ=<k@Sn`EB\#AEbJd(B$Q!*5''QgEG1)be9Xl"G%p*9HKV/]B3'b!*8>-"
Om#i*kVeIF5)R_J-0WX1l)'YYN;2Xc*p?@i%h=G18Mt/sON,:nl(4X3k'Oc=H"e%S
C1`fI7ZZ3qR;-jEC*o51^80OjSE`"tl0.SMr8Qq;XQ]qE=3cuoV.XOnK4i!S%,S/t
^9DBplfRWGBs*tA/HG%DZquLYC5g2JSuZWj_!!\jlX$E$Ss=+-\a$o:>ZS.H7[E>B
`U$X;CEBHi*m*aq^!j@ZBfP-TcHoH$"mlfJ;-qZ;0%=_rbA6m_m7u88d-,=qfas8X
D4]L!VUa$W=_1W5D;CUk?Jemti,0!jmI&t"G2_jPRdNr4=iTTAC3*sHkYfF`m[A(^
QKqO7lL)r"DVjemT'pRnQgYFS-?e`o/S]2NoN:P4DdAUr<qgL/j)9g!mlpS$2Q^o3
ipY1kDm&jEN90O>!H9+^E%G%OcMMPF9lNl3'JBZ0C/T!M#UP62n<lIZY6u#q$uj<L
nD=^&B*iPR;fMIC'3>fd.VNf4'GNJ>nQ@SdD\jau'lf,YnXg_=^Dh1-%<9]7E:4if
mgsE0+BC]KnfJNc0-bI0cc.+Ii>\ETHS[L,SDj9k1:2408l,#3JT=u;[;RQ3G:d0[
7Ptu7ij7FQ#:oBU7<4SE5__hLr5h1A#KfLt^eOO\/BG><aZCHm5G'uGA+n^?7Uf^Z
o4rU+L+GPZ1>[WVhGs]l;qPK[hV_,lFIOQ8rW2UjE:c#qoR#!@AQ<.8gIaQc4XMV"
`W]iG;.F,$j'Ehu`r5-+$XRYp4NcG6[LBk[#JKjoF[&]F:$H.H<`EZ_?b8WMX0(-+
>Ospjod0AjJQm;Whr$<VhpU9;:+c/mC39(_o]+.R'9$EG$":O9@<8pM:Mo+sF7u57
pKr%8JpA@7b=g)Z`=-k(A^OuR"a4[AF@6(.>Q1Dp]]=f5A&BX;s*o,D+[4q%nkU-J
>oI0BLD&AXAN,I/pDA.c,C%Oo-O1oAmtuAiO:o!*AoElY5EpFhQ$H\ACVQ0\J!bMB
R<bEim.PPs)H#c8]QqN<ND@Cek'-4<Chs?LC?E9Jf:mRD_<c?gkKfuN2T':\V>>\<
q=gk)KqE[aZME")l"@1XZX_?bKCg5lqVn(r0]D3sVU5"/CC^2f1o"</"7ssI(/@)"
c/,Lf[a>&ZqfL!K\%!mC:t$p%Wb"HDn&,#%^Ds_fp2[!CelI/*rVRQ8I%h&.MYU5Z
1EUJ3ouG8Qf?`:8l26_Fr$pWu1<!5-_FjhU<>W^R<6AC9k^8Q4r#6PE:W$/P`;S<,
rA)iLDnc.(<;e2ee\0,cdOZDM#rp&47ZYo_f<Qk8SaOhXIEU/eeL,XNGlEmaI`LgN
EVoFD9mpsK$@h&b0!T^eU$ThlBLeb/#HWDk4+>ass-A38Vkj@$L\d%OL]coG"+igH
d!.r*'aoa`@F4e&7O8_*7:OYh`+CkGN^k0Gq#fUPrI7CLdPo[-6QMIcA^^C-`aprp
9kMdU<.77]P=]=!RKWnL6_[Fke9XP1PtRuQC"3!57\s%`<GL'1N:)$VI`cF@qZV_n
A$T6RepBi_T3AACm8j+<`oV9Q?#J44AG4i'^0bg1r!!B07(gY-\3*5.'oU(ABc(%8
HQA<mATHIN*^TaOb\)"Mr<@a/SC$MBg3lEA7u,U[FkZeJ='(R;m<764`m8Y:hJ[MJ
XnN'S_o2%(S:3sTiPsu#H//@_NjkM/F?86,`>b5umWX!5^A!E%_shpKhL2SodHgLE
qGuISJoC7:;Eg^t?eb,JKDrWHqe2N`ldOjS^^pP9s$6%c&u39]j;OdZn&-E3^hbh/
I%X4(nHu4VgNa:D:uja4`!tKiS@fFr;%fg)@rE'u:s3\n.'\G@'#ejcdhaDe`-W**
Z*Z_:2A.2)*Q4*T>:)qGFH"hn&lPBoU_9tfP:i"d?RVkuRS'?u9:WO7bK:O'[*39L
b+M94U:.j0E4[>R9_/#WSBNH6p:3nsbhf/AVp*aDcSG@95G_<fq*V:V)PKS`;nAAS
d'PQ.7k=2"Glg>i@Za2Z$4TJ4;G]5"9N*dtd8j53Eii9X<D<'f/Cc5>=]>`N79`fu
]mQg.NgiUCW`AEU/]Z>GUJ]VY"d6N$F9QAYXu:Tm?!=QL@;Js99Q`BWPl8%`=V_/G
4j-g<_'^\?FWE<cPgn/AU\Br'C!h,Vk<i%O*W[tCpT3t0.9=m%;W(VW)+39'`J4.m
Q9<!.iRkQcHe:38oh!iEFr?9C)&<%3A<ueIKO+8Z6^(mQDG,`Fb%=VR@9C66P35g#
_bS)bAj9YcH%j_,WgTu7OC5PpEM;X.EjLeV)GQutAbdCNX(]WsOZ6RVI^>U))=<7^
f\-e:H+J9ER'Q%bY*HD$fP]l1D01f7ZgJLWdBN)nIabQ0qos>udb=s\RI"YkW@HGd
L4uR<49b>#DgP2uaE&4fZbg(7(:B\$q4A8AapS,8dI!:7H,a)i0+18?3mM*\nobg4
Zt!?:Dq3u5%e7_A4)SVnoj."'RWg_dl)]#2hj)f+e#fU1p:If'IaGWD3:2!;:@D3@
5/*HOH4218V.-sKQb.*=Qf6d!T5W$jI4DrQN88kGlbWElQ&1i/\lIL26$2?#qmqM%
?W`2WBEcfbZ,_N6?n;LOAW_,N`lQ)kH#d7$\cfi[DSHVp+aK.B&3oqLojC0$8FW&T
6Nj4ii,gM<0Z_j3=CV`4S198om1.&OKb35h7>T>4,Xe#b'&kA:M30tM72Vj8,'6b@
d9\@laK$(cjB[ZTq4FSk]bocT;*NBn1e*k$K;2C_NNo'67i98`*hht]dG3%hW::qh
iId1gp-;.^<9r9qJrnD#\&\:V,335FOH>VpaVc@4,^bf=dToDc=YV8aiS'JnG#1dF
"SC:cU6O)L77qi*+Jhc4Q-ns2O83?<UkGq;a)l]%3G(h&kkpaPhI%Aos"=W<_^':!
@*G$I0r=6\R1h&`*m&IX-?R"k1L1Jal)Pf$jP?<SIW/%"`Am$+j-rtF>ti@c3p1&@
S^Y;t:Dr7VkG7dBe)#IJRIrc,jSb_"rd[f`"[M8s]U^h#C/4m+6"jg=U!u8^;&U`K
kbT#ge'<)2abrKX>of]iIZRGG77cYh-)B%^PZ!rM9'Kn=V:<5H;]"%TB3cIIj78U:
RWVBijZTNkrh*4/Ki%$0e/sqsUf<e<;X.gfWRX22<>q]+a8JT0_si2,~>
EI
Q
0 J
1.08 w
105.88 437.36 m
115.1 440 l
105.88 442.64 l
105.88 440 l
s
105.88 437.36 m
115.1 440 l
105.88 442.64 l
105.88 440 l
f*
2 J
0.6 w
105.38 440 m
80.92 440 l
S
0 J
1.08 w
487.95 658.64 m
478.73 656 l
487.95 653.36 l
487.95 656 l
s
487.95 658.64 m
478.73 656 l
487.95 653.36 l
487.95 656 l
f*
2 J
0.6 w
488.45 656 m
512.92 656 l
S
0 J
1.08 w
105.88 257.36 m
115.1 260 l
105.88 262.64 l
105.88 260 l
s
105.88 257.36 m
115.1 260 l
105.88 262.64 l
105.88 260 l
f*
2 J
0.6 w
105.38 260 m
80.92 260 l
S
0 J
1.08 w
105.88 410.36 m
115.1 413 l
105.88 415.64 l
105.88 413 l
s
105.88 410.36 m
115.1 413 l
105.88 415.64 l
105.88 413 l
f*
2 J
0.6 w
105.38 413 m
80.92 413 l
S
0 J
1.08 w
344.56 185.97 m
341.92 195.19 l
339.27 185.97 l
341.92 185.97 l
s
344.56 185.97 m
341.92 195.19 l
339.27 185.97 l
341.92 185.97 l
f*
2 J
0.6 w
341.92 185.47 m
341.92 170 l
S
restore PDFVars/TermAll get exec end end
showpage
%%PageTrailer
%%EndPage
%%Page: 4 4
%%BeginPageSetup
%%EndPageSetup
0 0 612 792 RC
1 g
1 i
0 0 612 792 re
f
BT
/N42 1 Tf
0 g
0 Tc
(4/7)Tj
38.579 0 TD
(KSD/<name>_<nn>)Tj
ET
0 G
2 J
0 j
0.36 w
3.86 M
[]0 d
72 55.03 m
542.72 55.03 l
S
BT
8 0 0 8 72 42.62 Tm
0 Tw
[(Using Data Display Deb)20 (ugger \(DDD\))]TJ
/N45 1 Tf
1.7188 83.6725 TD
(q)Tj
/N42 1 Tf
12 0 0 12 108 712 Tm
[(mak)10 (e sure the follo)25 (wing b)20 (uttons are depressed \(these can be found in the center of the)]TJ
-1.8542 -1.1667 TD
(popup\):)Tj
1.8542 -1.1667 TD
(- All symbols)Tj
0 -1.75 TD
[(- V)111 (erbose)]TJ
T*
[(- Lock)10 (ed)]TJ
T*
[(- T)80 (a)0 (r)18 (get/Host symbol tables synchronization)]TJ
/N45 1 Tf
8 0 0 8 85.75 600 Tm
(q)Tj
/N42 1 Tf
12 0 0 12 99.5 600 Tm
[(at the bottom "T)80 (ar)18 (get serv)16 (er launch command" should read:)]TJ
/N65 1 Tf
3.7083 -1.1667 TD
(tgtsvr aocpu4 -L -A -V -s)Tj
/N44 1 Tf
11 0 0 11 72 565 Tm
(\245)Tj
/N42 1 Tf
12 0 0 12 85.75 565 Tm
[(click "Launch" and you should get the follo)27 (wing windo)25 (w:)]TJ
/N43 1 Tf
10 0 0 10 72 520.33 Tm
[(FIGURE 3. Launch Log\336le V)36 (iewer)]TJ
/N45 1 Tf
8 0 0 8 85.75 190 Tm
(q)Tj
/N42 1 Tf
12 0 0 12 99.5 190 Tm
[(T)79 (ype <ctrl>c o e)16 (xit this windo)25 (w)]TJ
/N44 1 Tf
11 0 0 11 72 170 Tm
(\245)Tj
/N42 1 Tf
12 0 0 12 85.75 170 Tm
[(Y)110 (ou should no)26 (w see a entry for the tar)18 (get you created follo)25 (wed by your hostname in the main)]TJ
T*
[(Launcher T)81 (a)0 (r)18 (get W)40 (indo)25 (w section: ie. aocpu4@kahala.)]TJ
/N44 1 Tf
11 0 0 11 72 136 Tm
(\245)Tj
/N42 1 Tf
12 0 0 12 85.75 136 Tm
[(Y)110 (ou are no)25 (w ready to start DDD.)]TJ
/N43 1 Tf
16 0 0 16 72 101.33 Tm
[(4.0  Using Data Display Deb)20 (ugger \(DDD\))]TJ
/N42 1 Tf
12 0 0 12 72 82 Tm
[(Once you ha)20 (v)15 (e)0 ( successfully connected to you tar)19 (get you can no)25 (w start ddd.)]TJ
ET
q
342 0 0 234 117.08 265 cm
BI
	/Width 509
	/Height 346
	/BitsPerComponent 8
	/ColorSpace /DeviceGray
ID
J3>#O3$ZcN#D>EP:q1$o*=mro@So+\<\5,H7Uo<*jE<[.O@Wn[38>9CoO^^,;PQ(3
>q_R=AlC^cenm@9:181">cc14T#tWNW[/F?8#0$s<4ZH=JO,pTAX+aA<ioH)<bk^H
j`\=EYZP^B4!g3;B=(iZ<k?76HVpISY#dMlT'^a7?>ioWjnAY&^gM+`4=1jRLW!YA
=M/6(mUj&cmZ]1*6A"jN?Q#7_k'&t\ctIN)4XQLiVpoI(>.nOW?*DmsG$@,,f0<0U
j_D6hY$0Mni,EpG4o?L&#F0<\I'+hUS^653C3<84;gm$ZG'd9(A?WUOmdiO5?O-ap
k3`"n?Fa-0KtFI0rLZ<PZ].9@f0;HFf9be&^^_%5c+XRD31iGi9BLo>cb%Km4O<Pb
nA9*1HL\h39JV;dOR+Ip_GGn.r&kV8.hf`r9;((G:b+G.`Y!foq*e/]L?1o;/9MH4
d2Z!i_pE3Q*Q8W_4WMNsduu(KZ6YPX7.8oJ.BMmQk6F&)oO>:!P,,b!8eQf2+3ZKN
LGR&X4=r<[dp/:_9MS";2Snt^m-[5uZtCtmo=Y"-cSH!c1rka.o.eM]Uk:X'o/tVE
`7(6G%FB1p/FZN=_VSM+P3jnuWq7#6&ku=W1EY+eN/]_e.[3Xo88):5.9%%a>uRZ,
jZ'2>e`s86<YSP66,XFYis<NKQ%JR/dNjB3bgpobC">&Y2-d.\or2.cZo&p1;`'`d
C=3fu=!L`<,nY7C;#QSMgNDmp4[(fam'0TO/Z!gOP4duS.e_EiJ_Y-kdt2!>:&ccF
3#30_iY[\%&n(!W8VuIEc8CC9GhtTEj;?0(OQ;f^9kn!NG#aghR;Q;sjr'1jRHBp;
#g6d2[WS/(RI5KqkSaqbU$.pq;$Yh.5*_u/P,7;jJ/X0=W9T0;V5nAMcF'e?RdRkm
ll-GRZ0[r4c*QdV:=Zc>Rr7&kmMh2J\a:;&Q)eZ3cDS6lS*p6in/MrB_=3sJ%E%KN
ZdHJT>)of)EZC,damtt*/^*^t;H(5JSF82YoGnH2dI`t^l-1*9me*XNgjZV_lTL!u
f'Qb/akLTZa%b1ZS^uiTCV@c:YBUun'u;%6hj(tL*9S9SnbmBWl1Op\H`hV*#IEE2
T'ilNpA?SCf_X>%Zgmqm2p&E()b8ZIH%1k;k5"kW=mp\YY2S^6^Me/_T9K,"0%KV[
#M/BP4(WodRJ4K6*8Fk9WcQM>]KV,?m@'fuG\ob-[5^#0@,)QN&7OE\-ogqXKH,XT
3Y]E_1BJW`\q87/&]2UMs5&\jHitbY6)Y^rh39REYkfN[LN=#8;pgD?p'80Akld\j
'o*>1.R!!X$=]MsM\0DI^BhL^h/l8=&Q13pR(XB3N*V=GL)n5M>5FrB-AsTb28GU+
o:n,EJ'bbg]a4QJTNk33:dt5o#UpVNN)km7c8%]k[3K1/EehsN1;m8[%jTkZP#$*\
6Pmu:A5"\>:EEA"Gn1Oa,_:To-1jKk=Wj9j:QVd9f1Hnq-Y!QbP-N^A7X7-Diu@fD
Og35&=D8u?7%BH=jml&YR4b8Y#*fhp>fs$A-mb\/Q4A@171$::-6rhMZ%;Sa8Tt[*
Co3RT[V\Q[b4F`5#b9?Er6'oEq;ApXT!Q^]:+;qFkFC4tde[Ru3U8TYb3j0<(44*#
CCh[8aI2R5LJ\km6f6AAUCa!u`4A)Ri^Aj%d,&e<R)'!i*@$4o;AdikHRn'/-]PK&
Hr14%9'AWqS$Xp29rGs+WQd_JF7m^KWeB9+PS0^-cB>^FRo/I'JZ8<3W]!In2l`u_
X&X&?4K=T-.Q(M5<K=@c<ngX9SS#!(Y-qB^_cPceDQ[!b\lMGN;QHpFY>t!m<sMf/
CZU,O<XlrJH/W0_7>\9Kl@h4/GuF!7Og8"^ZIilLALtfgZV>JT88C.sm0/l_cE>OJ
>>8M,lh7OuT%7*!ZY8ClY-qBVZ!*S"D(W`;W:n),gT,a@i,uJf1i^Fe\(u&(j<9a(
+no5cM/t9OJ[^hkg!SEp-SC(b].P!>bKD%EAsM8/'8#W-(Ai'IqgO=pWOZ>:0fgrk
mCUe1qFms6iGP4(T[@)77B2u#kd3j@Z*O?t.VVI'Hu>g$169A#LCKpS$&-m#(#8]k
mk?@'P#,?c?L.&kChoNFpZb^cWU3>3>m?ZNP6Fi$4WYr_l]N*Is2Rf76"WkPR.B*j
:+U)bYs&YbGk.S;pR-hC9]!0U;B8>bol[.'2j&=LJn#([email protected]^A+;[6Gs+Z<QI
E:Qk:=beN,7Gs>RHQtFqd;AHUiM>-nJmSf&RH>fk`fn,HB,NKQY^C64R1Z\s]Ycu&
[Q;[$[C"h]<9tn?!QXf;F_4mN,UP^<d$Y+c9h<fIZ0$_0o_V!N>bdUk<9_&!0t6<A
<GZ9M0#BUV#[\K5,\a]-_A^`1l5B])Bq/GPReJ>p98TqCG.s*lhW81*F0Y#%XF_<7
.p.!eO`m!Md<fKND+mFi[Z9.u<hjD?X]N%,7d4_-]6/#Ih1utuk*m36hT%*!Tm&Vq
D43'HdteaPS?CW&mIPL2[b\W8T)cmBgI0D8lZdMHfR98=am^ner:_d*hlXX8n=Ddh
C'P1-q+:]_%QVKJNrJ&+:P.[(0r-^T^V@-n>/Mt(Yp03$fTWb!?p0K$E3.OMoWt4W
NL`T/T!FqMXjCbJ=c)K/K8,bVU3/)>e0k8:gCp/;C91K$3pmEr3c]LgSPRmaA"i"p
i\S'7LU-,uP0=re+@g*:ei<r"J[>Zgjc,2OVe:RO\U1U'Xuk?BVbZOV)U$HuV;EQ!
f>r8F`c;N.0X@<_R_!"AH-\WJI'90,gfq]Tc3rR=Y,CDg"''!uDa,p7RdD'G[eel]
m@h";p!gI_ql%n5?5KI&]Ou;$X`$XM=+Bt5fB%>7?^a!627L,JrqsH\h'#j?cn_HT
I*VE3i@gDi?70YkO%EZm4-J+*s7*lH(&N6Z.c2>aq"!>,rU,a8ru^[as)7]4lX^#l
!<?n/s3M&PlTYAG&HQYr!72SalPBRu+TcEa!RN7slLt?V0`u1R!miq0lIc895m1rh
r2F<,0M)Eq9*A'k"feO(cs6i+G5-t:kf2ij#;2IgRVZjf#"lK!mQuE-Gi@gS#=o]^
E-hi4[cu.XfhOa<Vl^6F_W6`j#tiAH%Z]Z^ZI^LXqs:oW:V^t/(?l*VO,X/GDqM^!
P/C+tYHV^<brVsZ`:GMGo'GZ*Nlpsq2%/o\\aKfukkPaLq$jR`C$iY0bXW35f(!XV
lGnMh9feKBV$E$0NX'J0&I>sEhZWH.Wt.Q1D_CX?rq%bIbm=HU&Jj=8)\X`S"Nlu+
B_)G3@0t12mHKqYC-*2F<hAcuhasWBd=DQX=Tre'Y7>OF;#^pF5)ZKE#q^o@."Li#
[1]Sn%1t$&&Vf5+>c\E6$>o?PZ*>6%)]5]Yg@+*A&]5S],mFt3*N(ImOkh'+,9;p.
*ifYgNuK.foPkK-+*%4knaNoJrubqX+0l1qlH^S)@3H7#g2RQ3&fW#M*)A4d+AsL0
k1(U&0dCPHhC^Z1P!Ej32'aqC*YM$iP"-eg0dOrq-*)k:Cb6B@r=?.c\d>V#/*`@Z
*9<%kg$QZYDV#/S%il(b(XdKf;6(YWN>ZU^paFlFm[#Bm9#n.onPWcUldZaZTd\4R
-SUS#me2=;0[k%XcNpV.cQ=Wu0_FdQ)!kYUd)a#jPgg8Ok&HjRZHg-t!7.j1d]#kS
;!>cQHS0@?/MS%BEibn\(rW_r%l$8nkO0Cpk:o[@j=DMeDa_5+,o888dOne9d@UiP
cN+Z1c>MRc13Ul;$PmWl$a6#NBlu+,XUaRF-M'3rDq<9,Pnt'lRF!rK1JJK::@q=Z
(N/$WO`])lW71!t&hZYuF*?&n4Qe;beLj>mo1LtT,;\i>30/P*ND2Mhml<ud'PVrX
O(?C3CuNLl19;bH8e4%(K`R7kqlum3Yu:H3gl]h,))G77m@as6@l]Tk$h'i%9BR[#
HLtn_pb!9XMH(ZKd/qc,E0MX*C<%&%<$1Te-g)(.oJZb)[]VGS7&I(4PYE>W;^P.'
$4G#7;au#]5hhN#-rI_4l@2!8;+6Sq)q9-<E)T2G\>V-e(TXSB;SP`i-O$km.qaP!
C,WijP<^huqp(A]Ng/r'T\#Aoq[J_-l%MG\!78&?cnK;?<.ue8%/+_?`mZ"fN\&XX
md(CJ.nQ+dm_;JY6@:S'7o1X+Yu\N$s%7<RmaM1sO)n+Ha\&Q'o<PrjeCsLmSP_2/
_\85-E*Z0iCqP`imk_(-e)GTCdo7"9psX"3NlaVojQr,!+]AD3YAj0"=SXDr5da*\
NY=P?)c_#B.WnMPojjAPL52s`1D?qlPr2IhXUI(R.<=pSXM5X[`=8%'SCGeK:q96,
0^(-i0<L?Vm)9l![7g)B<RboP%HsEWAOZ)Q=XY:[CKXsSiD:4e+I1bhZ0bk^Pt08X
<YbR''";3\-:9GE>r?U?eW20q"(;F/.eX$RA+(VI(2YcmX=a6>1mZo2D.2S_?KjsP
npJ>4#uHLUkA\Zue@a[[#td*Y1fdObL>cK65.dtk9ZeegWKQt`5?;lW;Y><JeJ2[#
`FIC84r%j3ZI<E%]S]JE;XP&-au#BK%o@G'Ai7fGegd>9OY\jAcSK]VN_9%h^@T`d
C98FCCB#e!KadJCp<rnT:@V**+^J.-;3l\*f#qmLa(AA6V=glmo&e9"3r+Y2p$S#S
0ZOQCWGr^REOPOVnfJO%[mHtl2qA"Lk3HdL[73)/[hagAYa'-n5nKAI6dVrDdJ%`Z
Wdf&NiYPlf&mTlE;'/hq"Vraul`V9Chd^g#F&i*AQ>]rDN.d4)fCc*rd0"VcVe""-
)M`*>Ff.isRpJnlG-%(LdiS+(R97uXeJ,o<Y`STO)g.J$DYENApJgrEa':7q:UAk[
c^SG;Yn.D]5Kher'pV(M&M7(2E\Up<;Q">%lY.dc0t,0so5Rkc?O$(ZB[_lX1$*gA
nP/OhD:b=?GRYHak`RSb2AG*$enEJ)JUFjOHB7N:[@#X4V$iU/^fQS2QB%h!T-e;/
E&LocDMp-WD_<uHL%3]F7mD$[eQnFihcN5OZ2\n?K6)hBM3/m5f10LuI>ToLD%/dg
Op?dXcU`8PMAVk/G@r0[90BW]\X8&K'K(el2.:aKMK`IR(NAHDl&Ia68=+TI\?.]W
hYJ%N969Pq'[KPB;0\AHGqB2TG+W^iUMtI'75uT/1<3&o[nVh2P8Gp-0.`0opr=&;
G;r*EQbc)!CDPS6-BRH[[5UTo,0Q=\K6Qp$p^_*k+_l"\PZZb*b]NRMaa9(7$COtL
\%;(0jd/utCfmB:\FR*'ja;1CKW7_F\B`QKRsk*0J^^ApfL_Pkq',VUl1k9_<sstL
!K4%8qR$cDdc5>7T3POJS["GF(JT;qP483WBIFsCa%)Nhs-Dl<SiEs^fTi)u8W-aU
"F-2;2_(S!rI.k`Ni1ut1f^0($"35b7s6\V==1#)Kq]2!HHu+kb,%.4n!)?kNnE$Z
1-G?=OV`,[)!FHPbEYBAGnr:bRCO,Qq#GoRTq,8]Og7iUG`*C6F-Dd]/G=>SN7/uO
s,rY"W4;SRGs?#qgSHT>AQS&\<D<!:X*AqZ;:AH#2s[9.Fd=uWGk^s$2u=e]&#F0C
DAM&sX1_'V!sk*KQs*.5=fj/6m<4pEB<PC$),FLY.BZi12*.4X)Y6ogZ*5.AYArBn
feJumEL]'=LG+"FHP!ebV4J*$VjEaHop`;AELlp9YIYg\e^9D&o-9\*jZ4?RX#6Q>
@5n%6NE^$q\u?@pIo5n5#;I;)3V<KdCLG[W/!k1NG?]+])7^YZgf_7fGA"G\hmkgM
Ng,*iF=4SCLU3DrD=kN'g"V,NX0ZXOkA/tff8V*M8M4'X]Gi:lC72ASf!ekUZ'*Wh
)5j5JBmfcb[23;ralU8gWDNCJHs2.32!L427=W^qOZ)SgpUJ#,9n.C#cWR;0)rZT/
.)UE[_ARb_%g.6K212qf!4trs3Bn:>ff@^3R(B-0#=C&p$J#kf=DPO0>A^+I;ZFA:
GP`?!(c=2D4W)D;pUAtfg_Do6bC8+JX4XTKR>Yj-ppPP84&r]#dna\&CN%`jVmdCd
RtJ":hNDV#qqO!5bpR`GO)]I$S/&]FRp+`)Ki"gSXV-K"RYKY1A>m+H[FtMT)V$#5
(Uik?$(U8,OKC+)9@4\u,)tZHgr%O(BudmldSS]Fh&"Mn%FUdXdp3o#SK@EO,Lalk
d9Q_$O<N'n:Xp-Ce"&;FO>#-hqpl;ReD4cgO7CPEE;t=Gf6q_YrI"ehHe:4=fH#eu
]R/<05@QcCfi6AP4e86oNS6Nog)[/\)flKpYI9r=7%LgA*??C'^YBS2XaS5p]s=g^
cdk7]h0l?[1F:l5>MHU8hHBU0&bFl.8_q)Q!<%&tXiK(C!RcDd,2NP)IKeZs=l92n
iI1O\]mntOCZ5lhiBA[(rYa_p1#`*gr-gH^X+B9e5e#T7jEp.OSkSC?9BA:pjW7O^
ITPY-!Ti0LcX!I2]<g@]YNHs,k5KYaSHEn=IcZ#gk\EKF?Au6TMs3<5k+8""hBc2$
TB[JMJ,ZA.hP8+TYN<K@`u__R*C8Ie^Yh;Hlu2LYhTb,QbO%LDlTIc*MTtB,i3>J4
mVU)3]CkUK6gYrfk'lilT)6R"h=)tTmU$8&55F^69CUgQY.j5lWo`cC+n@i2np[(s
r"&AA2t?o)X^<CG^HM/&5okF+oP6nf?VI_35P6OBocI;?T3(^TQhB6HYWlXkWiP``
EVD[jpO?WFT7-7eHh]gBp`G@`T/#Y=Nih2]q.b!Es.#R.S,+iIlF\)4T1SO%Z26bf
gY]L5?]FsJa8-mrIUB#NYNtt5dI]Z2rGX:c?ekk"g\r\ur1E1pT?mN"8,hE<+:n5]
%LE;k6/`BB;uN*-!(5`WfFS)`'T5Ci&P-/E3?=/Nj:W=EN_(O\8`^SQ<3B@UQV6:6
fRu\])4O(T'+*1VGs.cqkS+pM%Z)I!9Y_5h]e202Vc2jq)O4's<M7b%E@AM<F%r]:
lkUNTNlbk-6`Cd"jfZjF[p/8:)jIY51o=!F2`oRXq0g"XDQs"<hJn%_@IY2)<.b9E
RbK2)ls<I:Q-3D%\3,K.0:gF%oG)^AB-2e`k]If7<j"lZRd%&fc'H[iU"=*;qd%eA
H&(/B10`TO%uF_r4ZOLA`cI'_kB#ilSkM#/B%,o;4V$(^\L2]G%,L\s>Hta,q>DA%
hi"Q%lYo!o+.(%(mcF.kJ"P=#leq*9ceJU'2fJ$%krB6L'*U[@A/bb>n:W"m6?&_N
$UX@$1CZ]jj?!l>nH;2k6u_c/"@1=Qbn<HbA6Tj=nUtBi7WG5>)aSCQ(@]9m7!g"G
ncXRg89,u6,=qAnP9ie@A=Fr<nq<be8og`..f^1*'ck,c1p8Q*o)urc9QMK&1JIC.
`@ShY#gG;&o7YRQ:335s4&5Cco0"8[Uu=NHa9V~>
EI
Q
showpage
%%PageTrailer
%%EndPage
%%Page: 5 5
%%BeginPageSetup
%%EndPageSetup
0 0 612 792 RC
save 1 g
1 i
0 0 612 792 re
f
BT
/N42 1 Tf
0 g
0 Tc
(KSD/<name>_<nn>)Tj
45.334 0 TD
(5/7)Tj
ET
0 G
2 J
0 j
0.36 w
3.86 M
[]0 d
540 55.03 m
69.28 55.03 l
S
BT
/N44 1 Tf
11 0 0 11 71.83 712 Tm
0 Tw
(\245)Tj
/N42 1 Tf
12 0 0 12 85.58 712 Tm
[(in)41 (v)20 (o)0 (k)10 (e)0 ( ddd with the vxW)80 (orks deb)20 (ugger \(gdb\) for a Po)25 (werPC tar)18 (get)]TJ
/N45 1 Tf
8 0 0 8 85.58 694 Tm
(q)Tj
ET
0 J
0.6 w
99.34 692.8 m
145.42 692.8 l
S
BT
/N65 1 Tf
12 0 0 12 99.34 694 Tm
(ddd --deb)Tj
ET
145.42 692.8 m
157.3 692.8 l
S
BT
12 0 0 12 145.42 694 Tm
(ug)Tj
ET
157.3 692.8 m
163.18 692.8 l
S
BT
12 0 0 12 157.3 694 Tm
(g)Tj
ET
163.18 692.8 m
211.5 692.8 l
S
BT
12 0 0 12 163.18 694 Tm
(er gdbppc)Tj
/N44 1 Tf
11 0 0 11 71.83 674 Tm
(\245)Tj
/N42 1 Tf
12 0 0 12 85.58 674 Tm
[(for a 68k tar)19 (get, ie. frc40 or mv177)]TJ
/N45 1 Tf
8 0 0 8 85.58 656 Tm
(q)Tj
ET
99.34 654.8 m
145.42 654.8 l
S
BT
/N65 1 Tf
12 0 0 12 99.34 656 Tm
(ddd --deb)Tj
ET
145.42 654.8 m
157.3 654.8 l
S
BT
12 0 0 12 145.42 656 Tm
(ug)Tj
ET
157.3 654.8 m
163.18 654.8 l
S
BT
12 0 0 12 157.3 656 Tm
(g)Tj
ET
163.18 654.8 m
220.16 654.8 l
S
BT
12 0 0 12 163.18 656 Tm
(er gdbm68k)Tj
/N44 1 Tf
11 0 0 11 71.83 636 Tm
(\245)Tj
/N42 1 Tf
12 0 0 12 85.58 636 Tm
[(once ddd is up you need to type the follo)26 (wing command at the gdb> prompt:)]TJ
/N45 1 Tf
8 0 0 8 85.58 618 Tm
(q)Tj
ET
99.34 616.8 m
112.9 616.8 l
S
BT
/N65 1 Tf
12 0 0 12 99.34 618 Tm
(tar)Tj
ET
112.9 616.8 m
118.78 616.8 l
S
BT
12 0 0 12 112.9 618 Tm
(g)Tj
ET
118.78 616.8 m
219.64 616.8 l
S
BT
12 0 0 12 118.78 618 Tm
(et wtx <tgtsvrname>)Tj
/N45 1 Tf
8 0 0 8 85.58 600 Tm
(q)Tj
/N42 1 Tf
12 0 0 12 107.83 600 Tm
[(where <tgtsvrname> is the tar)19 (get name)]TJ
/N44 1 Tf
11 0 0 11 71.83 580 Tm
(\245)Tj
/N42 1 Tf
12 0 0 12 85.58 580 Tm
[(for this e)15 (xample it typed:)]TJ
ET
209.06 578.8 m
222.62 578.8 l
S
BT
/N65 1 Tf
12 0 0 12 209.06 580 Tm
(tar)Tj
ET
222.62 578.8 m
228.5 578.8 l
S
BT
12 0 0 12 222.62 580 Tm
(g)Tj
ET
228.5 578.8 m
295.16 578.8 l
S
BT
12 0 0 12 228.5 580 Tm
(et wtx aocpu4)Tj
/N42 1 Tf
5.555 0 TD
[( and got the output sho)25 (wn in Figure)-250 (4: T)80 (a)0 (r)19 (get Con-)]TJ
-17.465 -1.1667 TD
[(nect Output, with the command line interf)11 (ace section e)16 (xpanded to sho)25 (w e)24 (v)15 (erything)]TJ
/N45 1 Tf
8 0 0 8 85.58 548 Tm
(q)Tj
/N42 1 Tf
12 0 0 12 99.34 548 Tm
(note that it found the symbols based on the information in your ~/.gdbin\
it \336le)Tj
/N44 1 Tf
11 0 0 11 71.83 528 Tm
(\245)Tj
/N42 1 Tf
12 0 0 12 85.58 528 Tm
[(to attach to an e)16 (xisting task \(i.e. a task already running in vxW)81 (orks\) you \336rst need to get the)]TJ
T*
(TID of the task, either use the \322i\323 command or \322ti <taskname>\323\
 to get the TID.)Tj
/N45 1 Tf
8 0 0 8 85.58 496 Tm
(q)Tj
/N42 1 Tf
12 0 0 12 99.34 496 Tm
(from the gdb> prompt enter:)Tj
ET
239.09 494.8 m
262.91 494.8 l
S
BT
/N65 1 Tf
12 0 0 12 239.09 496 Tm
(attac)Tj
ET
262.91 494.8 m
312.11 494.8 l
S
BT
12 0 0 12 262.91 496 Tm
(h 0x<tid>)Tj
/N42 1 Tf
4.1 0 TD
[( where <tid> is the he)16 (x TID)]TJ
/N44 1 Tf
11 0 0 11 71.83 476 Tm
(\245)Tj
/N42 1 Tf
12 0 0 12 85.58 476 Tm
(once attached, depending on where it is you may need to \336rst display \
machine code to get the)Tj
0 -1.1667 TD
[(little)-245 (DDD)-246 (popup)-245 (for)-246 (tra)20 (v)15 (ersing)-246 (the)-245 (code.)-246 (from)-245 (here)-246 (you)-246 (may)-245 (need)-246 (to)-245 (go)-246 (\322UP\323)-246 (se)25 (v)15 (eral)-245 (times)-246 (to)]TJ
T*
[(see an)15 (y c code as sho)25 (wn in Figure)-250 (5: Attached Process Output.)]TJ
/N44 1 Tf
11 0 0 11 71.83 428 Tm
(\245)Tj
/N42 1 Tf
12 0 0 12 85.58 428 Tm
[(you\325)51 (re)-222 (on)-222 (your)-222 (o)25 (w)0 (n)-222 (n)0 (o)25 (w)0 (!)-222 (this)-222 (is)-222 (as)-222 (f)10 (a)0 (r)-222 (a)0 (s)-222 (I)0 (\325)50 (v)15 (e)-222 (gone)-222 (with)-222 (this)-222 (so)-222 (comments)-222 (suggestions)-221 (are)-222 (more)]TJ
T*
(than welcomed,)Tj
ET
showpage
%%PageTrailer
%%EndPage
%%Page: 6 6
%%BeginPageSetup
%%EndPageSetup
0 0 612 792 RC
1 g
1 i
0 0 612 792 re
f
BT
/N42 1 Tf
0 g
0 Tc
(6/7)Tj
38.579 0 TD
(KSD/<name>_<nn>)Tj
ET
0 G
2 J
0 j
0.36 w
3.86 M
[]0 d
72 55.03 m
542.72 55.03 l
S
BT
8 0 0 8 72 42.62 Tm
0 Tw
/N43 1 Tf
10 0 0 10 72 713.33 Tm
[(FIGURE 4. T)92 (a)0 (r)10 (get Connect Output)]TJ
ET
q
468 0 0 603 72.08 98 cm
BI
	/Width 606
	/Height 821
	/BitsPerComponent 8
ID
J3>#O3$ZcN#D>EP:q1$o*=mro@So+\<\5,H7Uo<*jE<[.O@Wn[3@'nb*.l=>N6,V=
>%WuBAlC^cenm@9:1mM9jRt/UQV3:e$4O4K5,;(j<4ZX!SPQ1`BTu[@(11+D<bk^H
j`\=EYZP^B4!g3;B=(iZ<kDqOh/Bf.DH3^-#-13L?>iNZ<VHB@^gM+`4=1jRLW!YA
=M/6)*KS9PE`kN%="Tc()6]C-h&;-=U:i?b2J.#)VpoI(>.nOW?*DmsG$@,,f58"P
DKf<uk4a;=i,EpEWj[CA=h<1+(HuIjS^4j_qA,*VO/pUmo_Vq.kAQ>]XE&(r^@.E5
d=fkT?E[(<)_C@-rH5mZKBFi]r4]UX^Us42^^pnWYWM,+OKUd.*#/XXY,el65NZK"
#/W'Y.^)0WoBcFj.jR1c^(@l6&&FAZ9^"aD/.T<LaqRVf`U:BLs2Juq3>"U(A9/\W
nZ5(`+VFWl+%L:WK+Q,0/))@:ng'PA_=>0`)9DA*B_oZ0KXC,+biDgQQLbO%WPL@F
bjrm(]PTOJ.<FMl__CG*36bB<OZUU)PGL:^;Ii9Y__O(I4O:@0mle])4VYH69@U!2
W)F>p1=:3ERl&BS*&TZOZg;fs9p=#-9Me^dM,;3W*<Ar41c5S,e$Mh$=fobK[k^iS
[:rp['[932:\?P_-eHeZO!rEL/W2%'&u9;?<YA\B:=^2?O',PMbP;(HX0HR'd[&G&
%o0L^:971`V)MK3QYe`o;jCWcB$1uZj^?GSSZbr+1<mjh_\V9"Dd4+`%-pjDFf0Rg
<c(i_>.BS39\pHE6"JhsFsTON<de+I@/12pJLE-D`Gjm@9W&6PO6h4Z<LC^YQqJ27
Ilh5M*KarGpH@PYkBVf%-J6p&<MR6n-3gX7)Fg9qXnVCmW@g&OWMjO]ZKVL-)Xb8H
CA5WV-g=h6]<+`khOCigRr7&kjZ>hof5;P1mCVg%T&mWRS*p6id<jaO_=3sJ%-VJ#
`tcS`S8TFgnf3]:amtt*/A\\598Cd`SF8VeoGnH2dI`t_:"-S^S[$**SSqfcl>N*:
g%Lu?D;4e*cZS(<SaV!ap`9s"iV8utNT9gU:R1&;So:1_qAt]ol(%]M=mC>TcaE0;
T'sA]r#ZHgnbesQh<PrLR=4c,T5WQ[rZ@3_q>R"imJHo*ch78:TC;^Xhuj(2:_!Ol
=:G;h6j\E@+?)K+XE@lL$\D2M$:.cG"lR<:K2?Fq6.e=#?u+tX0RaX$=A9+\6n*gd
Xqj@Ui<Wh:qh/q")FIVD%H55cLJ[C<_ZmLWiT*:\;%=d<=H*pMbW^2;Sg6_VSJ1"9
;2S1R,p(]i']R&6Mc"@E6tiT_ik/QU;3!D$=Nq!nr"+^ISi0'jh&GC,mu9$D288Vq
08M`8!"]-a^=`$!j4jBj1$V(jM!k\l6l;#(r.Mep(E]F]"d-$48\YQR*+LgXP4CY)
^KBXkj/_U0no?od3=@8]'S2He)Eu$+9a'Q_WKFKh=MO*)#3C3uQEjsP8Z=d(V>KkJ
n"rq'$&pU8$h]^(c<S+EI3E,pKTH`0B?<0/*i&q[PERm#8=?kD-FC7N10/A<RCarD
]\]28U2s#md5L)3fq"<.G/#K44=4V3Q]XaMc&(I<iHu,jo+lXH3TWH"[,mt1,#M+G
_&hfFe=H3nK?afG6g+XGP4Ph?OP2?X.'0_Ao.k#W#qGo;"V.,'IZr0Z-V5ZGqk'+)
P>QPa0]NTnUp?SV:)\=/hi0go1JV(JWI[k0XH&qFmSqQeO]1<=9;lt[U<aaS9kktS
WYJF2d427oj[Cq_<-G?D=631*-"3beAn=X3]0rNu'W&4GEQK-2,O'n]VmSRtenQd@
lXT^gec*<c)LGVcNG>=J#'\]k[mMY[7]nTeXN)do''s0SVj00b=^)D0k\YCC[5tA<
b-u!KV5LN*Wl/$IO)$=1S@*Ai`4rkOC@$m^Xu:HHer)=]km`6AQC?)s>3f@mgr?Vk
R_dIR4\M\QPdRt=WSJJD6>Oio]%4ISgr_-a/!Y(A'J@:-R%%XT,dk,0>#*R?b<;Xa
,deDJ<)%Z8EGSY5X#F5A>Uo,Ylg<Pt("VeL=po+XrSjE9)SBFXD1/T^HG%WhIb]9<
q_)7hJ2T=q@GF!bm_0RVn++HW4AC\%V$P"AUAn]H?&R]c+gUWA[*ag?4/KY1+cn17
6>UuZ0YERhE,-QU$>5B+hCH\#0.(5^]99IC;9E$:,%V1^Q1DptKiqV3A_atci2p[D
\W8LX>g8].7VU+MY;U"Jh4+"jER%_53bM^bSb'jHcWT^#BAEHXoEKln:l@VQ>n*M"
7Z#Mr01KX2*M`7]OjB)`0POfEV;P[Edi*."C"N$T[.^3C>)uKp4\_pJY,0YeY?#3t
<NBUfAUunb#%gSBXgP<Af)"];^tj4<U#r]ug:d>s/WI%,bU9OBhdC60(U#`=$JHE\
C.F8cZ$($7OB8b-^b)Ih-4ok*>E<fB?-TqS7d8`5YBFg>h7NE9n_C>")U"%Q[GPq@
J%6%*_*.H9-/S[Tp'L`f.Q+pu[.WA2cF@_<UBYsLi2lh!MK)rS`V@Ikh0[Tm<3?mr
\)]Nj&CYOd:-H_\B-61IX,h:'rB6d^&uPSBRWDePc1o=!i:no,o$15a89=p'QbO/1
LhfC<7k(EC,F;@N5LXF[A\qYQQqskr$i.hGlWnG2F/dL73[Y'=r;V2-)#;ADC]qB'
"r)0>Hd^r`.G8YM=n7SYgU[?/IQ_!tFjBsCr!)ZVh1#Cs%M@/MI't5>gUPBYl%(rT
h"!WQ6Zi.E,bVf=jW"?Ro,(q0+4+o\?iYNL:BTk[7pPP3IcFkN<E+9?<0G\q`d$f@
Nj(H7lnkKih`ad%4AS<71V3##ma(Abhg=tT1XPPc9tUCSWVTstF*bIWDWGGDiSQ#f
<?Dh/r,'U<ID3bE?]iNZB9_g*]<ZeN[sbtL6CJtgphK]V`VtqJs'J<(42:X.mLo$2
]^?:%[a/Xan*&qKUppqipFdT-cij:8[e?p3!A1>?:^[>ci9lUFrC?##9J5s57fRF!
"Kg>VVf:84lBq&V]'6g,n,i_a70*q/pPQ]"Y(6VX@d),tma$Lcb4,A5ddbV[lAm@p
WpL&\55B,5_h!4=:Rq'<U*1%:+RbimYO_nD[-',>IBA&(E#>Qm>b5nfgMb[D/t0JT
)[B&/^CEa6c]INIE<_44""LtP/!1*Vb5"N6\P"F[%ndHfUteb<$?2aOOLGfU\;"t:
\dJf/%asOeC:Xo!i!SQN;"FK7%ej\-p<Jj.%\A5i-KU>PrQsJPNCpqS]\Lm>$S`(n
E=id[ADTi/Jh<H#%X=QRFTW06m%PWt9D&r/3sVu5'X-Sc0O3s@/GJYZrK*'2%`'#q
f+g!0_[s!dYcA,Y@2:R"(3."Cd;"Y\DSOQPk@upnX@OMuK,HC)po?b&OC]>*eH^"Q
"4*#,0I%2a@0poL[HUa(&J5Ro]-),#&@&tmmPc+;ZPNojm?!:p0^QGLb(W_6&rKlR
/e7sq2',SF,EQ7V/rLaTmcG,V5&gG';#qUH9d%im+E4Y1&mucYg3.KPKWee\;1Tpi
>8)s7^+q&]Le/it5*`F&Jl/KU8(Sjq"XVNt-'>_anm`g2XO[rInP"hQk\hh>0a&&'
,r25GmVOFoW@V_\":GYG&d9g!eDedYZ4Z[@DXSVZ4W)VJ,LRM.1@!VV-SK4&pTW+"
O=l/9!ljL:`p`9'ZI^f`2(c"Lo1r^0Y@T?4)[PrT!cg]>O`^Y?$P\TimE]th8c8/J
0/*of1Xdi_cCEt`9+=g"1U0]hZK29%jYfn\mu?on;fOCEk`dd_1XdF)m]-Ta5qZt(
#LN2YdsCH1KedT/p(H0_ZV'`Y>mA]K1/OGVP=[eiirX8\r=c:#Dmm9AD&%,54KeoI
F+jL,\NNaG#.$5sl7!B"B'^0O3@nAlc@%_A?U$6l1R%8de#a;0cRt;co5jj9NV9*r
"$"V>43-)<ENM@Q,m<he5]bUD'EKTq;Z%*r4&_IIZhZX[m5B&@3g6BrOX30\pGd7.
6rZZBZo%Y9_&8H#2K8I;aHJr4FPS_+\EiGAWUE!VV\dgHU2qn"X8`ED#=\.B4,XU5
Btm3f#k9F\kc)esF:CgJ[`8l'2DIDt:m.5'+Xne^9XN#gcBTrF@kSPGJ@*?k[,Fb.
a%c3f::0AF2!Id-ohT7V:GhlCo`0`RrD5?X:oI'9%?XLF'iB)k;7.EAoc[3b(5,Z5
;RJ)SoeBB&2,eWX;l?6aFU_;-74W>F<-:o7kg7T!-kQ&S<OH+4ojLlYAQEqf<jcdF
ol4%jF]W^2=1*HXomp4&KiiJS=LF,jooWB7Q!&6T$1-AlYaJXZV-8#@>.(J9os%^Y
[9Ida>ID.FTnupg79juT*;.EY[@n,==\!Vf?+&Kop#040/f9kjJ[NfNQ1&!69jMo'
?a]i>p&SPV@pYG>>a=heeau"uI:&9D@C@1bp*!lt1LQL8>o!b]7qYh1%q8R"A%"O1
p)@Ikh-h'P@l:#kG!T[t<Fp>V//CZ`dZ\3b0ju>g@<PKsG$AT;F_>lBlZQWICb]O&
9jLe<+I7@fp5s&IPhahrL_];jFn]RXQYL]CC:7>\WJbKaBKES=$MLT;p;(Q'!G#)A
bnd!]<Z,^SeSTK_6?^Gp<mPBddjc-fDRSqMn4REecYn!eCR3Ff(BJJ6"SF[oGIBAE
f*?:S'leBZ?D-(tG9:U1pM75UEjmW@mFcHY")kXrDKdgVpH`eC1pY^moG7IK2c4]U
m<!4:E]4LT[oIT1ASQEl$eJZpn4.A_B6SQFAN+C<2bNn4:Ns:)Gdi*@aMNM;K6!<<
H+0>SQ[`U+Q[!_HHFL"_2ksO-VeT;:Hag[Y=0m0R-$7bLHhYd4o$r+HDePKbICJ#^
2q<8!hgTe6&Qe"?GD1FRl[O-Rn/(P9p\TJ#"_ZGKXZ+4L(^GUO']U#0G8M-Ip`SE1
)h"(uK"*Aepa9f908"L.K/V,,=?2$o",#1dKG[.2pZ[?srIig#Kt#H`=$),'?&!R8
L)7sdQuRQ,D1=NdLUYN`GF=6=KmEHEHC0JDpLf;lAVh7lF82#W\=na=$ZgO^LcD/e
pmm:d8W($;M\s-HGb9oh`Gq9_N-NTd=NcZueTH,EFgpIlGi<MLduHEPC\[(Q\FF9X
muKI(B=R\s\H-I?gNM6,O?!b_3<,*9'm^`&GSmuJGo)W%a-!j-Ong;dq&+N]%=NIY
P8QMlfb9SF7:"S6P^,u?fdW+e&X<)o7sRam\RBnH;h4W`Q8re@3FA*JFW9"TQ[*ue
H$bnRK`?=MR!F[1R:h_N5FD87&NPc;\Y/7kT:.d=k..CY\Zp.b22[f'RlS.I3NnqJ
`8.uAS9`?7)9\QGeD,>uSU&bV\_We/iLW'KSpBRig$PC,Z(F&LR[NuD\Y5Yl!L]A[
TQuNi\db$1&YV45Tm@TC=rj=4D5'';Q5V3H\QP['0pLBLUNo;'\il826)6LoUj>Uq
3_cFG'r<rkOP3j6\H/Q'@?6jgVKhX.\o!IrEMkeTVg<WJ>(*=Dc)<[WN*;(:\@nj;
Oc'"#WHb,9\t+\HTrL)5Wd:Y#>-4h"H`K38LDm_(\7_l=_1fJ>XE[OB]$5mhdB,Ai
R5kYWRO>5j/Zot0Xa95`3pj*F+0R`uJQhlQ\-K57!JGd\S%Ap$>76b/&#9"8Jt!R]
RCA*$%C,b,Z+2s%Rh;qch6))ZP8a\3\95+1Qa@Z(Zrfu.RnL(j$+$*uV0bpjHX!ef
<KZ#`[Q*lbqe_)"?\UX`OSa%,\#["8JU-"(\9EqB]8_')Oh!Dr\U0a%>A',2CUs5\
\_F*+>HPL2;7eotF;qd&[kYMl_/e;L]QhQ-G]17KLV4OM]j%PNR'"'URD'NM^07SO
R3B;sF1f-XE#\Vf[dV!/!H,OR^inDH]FA^_&]$BC_0d,\g[W,TOhog!C7H`i\Fm^$
0o+O;_fh0[]KM>228hIg`#M?]>YW04"hH]oZ!:;1r("a(@E"XKZ.roD>Z8Z96,u*1
A))@M\MJV9\]*?TK"QTS[NW`iOd$hqa`nuN>b,7bTuo7mb'^0q]WK?NZ,sYdJ6]G(
\Oh=Qe#iPaYa;b8)d1CoqeoO0@2l,h>=4TEH-Q9GL%l#Z3L-uLlcjVoBGYMtI-Jt$
^M=Wicl@nh>iT:l8'tSjd2`m68F+Zo"4>`&Db&>e]a`!;.=Jl\M4HBFSMtrofGsiE
dlT544RHVO1"<\A?CbBPrF+8?A_)9Df"GqOrGgFPFk;%ef=cUarINTaL"Lg1fY*9s
rK5brQ.^SRf*?M)G%JqKUY3>[g:aWBrNY*?[G-,?gV(;TrP@&TF`JjN<#&9crQot+
YC'X!<5$c:rSW.\f&:8t;&(D6rUJc.p"t2nhmFWaCt2FK4lCbqi4]ZYrXn*Gc\m5+
+2-^nrZNV'#hp`agtj:8o^C]HdplCmj1[\:r^#U/7HAnhjL)a=XP]0>:$$h,jh>$^
raFqQAQM#cbn\E?SK$)q^!qI%?Tfe"=,Z74UX\$gkSSfq[Oou-F6MA2kn\j7?@V4+
GA$jjdN51K=(UZf,O4(q&=7MT&RF_rg[%t"h%6R'*=:'j5oYg:-%=,+Y.<nYcgFT,
$?<K?^?5832siMUka_;\T(VOo"`Y$YmZ#EZcVa-$=mVaEnJfMf]Z92!_sq'Z$;k'a
65:FoY7SFo$QhD#^B#*71F:p5mf,H>n[7r8[ijP`o`%MKhc]BnoCdZ.^=M343t:n4
_<`7JFrs*EE3!t#HR[4g)]m]*rq#bhJIq@`nUHhs^PDQUQ0j]@n9`!rSD3Me@JB>b
qnJ9gs1.Xn@JSfoo+l?4ZI7QYU\u9Y+?t)H*sMUm#q@#;\::d.^=W*dVtn*I+:hQg
%LD_-6"%J6<"9EAL;BNZW0B%L#_U+UO_Cg3,n5XMUJVmCME;3)6K'WnN(tN@Pffh#
ptX//24I>'':IA<Gs.cqkS+pM%Z*WCYo&DZEOeM4Vc2)?G<7OI,lgp]aE0OF@ig_&
j716nFu(_/asJn.UghL][)9!>)\mtZ/[*n[2bV\iq0A`Bn/*,\%gds-@ITM=<AL7E
WDtFuMUZOUGa6IL'5Jq(/XF[oYI?UUMSEcJh6Qb_<dsYB[cV^WNL%n)[G,Qm'J*6;
)igoJA@X2GF"%O19.mbH7&No$Q/ulVkiJS'%[1u1Fm`K^7kj&k,'M3i?WZ4Aq>DA,
=0L:=h;^H$gj]Ae_O:,k2SP1Np[,B'ciaFO5]@tU^V0)nSGBH;@^=t!:W(Q?5gR(l
$UX@$1CZ7(6kZH-n73OK`,R%q'1D@Y;Lu`i9GZR&XIK@k`DNFH)b0A8%2M,^F6aZ/
m`Q0N`bEYQk:fdjF!XCuA=@hbD<uS*5044rTh<GnYgl;XFLs2!n[tO7b",L2/\9+5
^@!u+K:]G3BY1q`c&V_b3[=6LesST5F8CpAMh@tP:G]Ao6W!DA#r+B_KO5<J9.ITY
0(b#g85MtNM(R&u,E5F(m2\&[[4Pr7/Q"Ao;]ASKI)rA/oX-0t<3+g"f</*_D+rM;
m7+i]MbS\-fMtq0@nG3]'bF6iNGVhOm;2f-aE@*S]%;%Wh.s+cQ#b0r%Rl!>gbq==
F&csJGn3p(1Qp?CD(DZ%<`G;6;98D42aLXu)tS&R(A6")?uVs*q,q_1+)Kd$DB!Cu
GK[s&<#D0u:qW)<E73YRL+Q1^cCP?)A8RVA&(.m]Rip%CKhXJP't[rngb^Wkk$BVa
nHlf`Q(79g3=\?KA==j&UL_tf@1uW,5+/0[qLk32@1o/s%Hh\rCT-QFjI*"/)QjgX
m!C)&0C/)(_j,&mB%sd_qa<fZmJEdH]0JH;R36DEk52n\QV69YC6L9P^[V.k&u';)
:A;_Ir.cJUnXET#a`@="&^#()(GjBYqmSLco=YB%dqjFIgXGhDArG1.h/?fV>hsm$
g%PB`%GL5uc[4P@?/I6kpjORK^r+hhe'<0+L7PsPhCi0ph0^S?k%bUT[%$n.jKFjs
?KQX0gU_UHIett%XZU2O?dtG*^5L\&dpET)/GsGJE?bDqja$ft"OpVAdA]mAnc?K=
f)4Cj(OYSNLaN7+8P=+D9aUK^5kVp,ebftQl]HV1#UK/nMKE1HTf"3"1:SJ`'S4GA
HU10T"s>/m<\KmE(^LiNQP'7"C/P!f#!@021ceg?eTWb!*j8Mk!GHHnHblOm'+G?(
?4!.G_DlqeT+j4C0]jUr'tY",_tJYD'nr\7XV)h8cAE!),oUgE&/MW=@?A>=`?OB?
=R6P[O_-A@R(4#>ROrigWGb/6mhB2.mT=:*N59b9?(WB_Lf#'_`"SMk,\&r?lUbM9
#[4^`1c/8'?4b0PnK:Pr?B>dCHq:(c/"(.bOmsnYb8G!mQJ=$LCYi@;7&l\M!u6^;
H9JM^OXB,lW]&;2AWt3i&n97gJ1Bh@98TW*jl6-*;5!l`BtD#gI*%aoqGP3ERhb&W
Q^O!B`OpqgmA.iiAr@9UcS^>1+QO>"$pC.JL0hj^e*rrFrL2&TaH0q<"e?%\H`;5(
5c6`rPk6_Sb..`7gB5WD9Tg>lkiYChXNmV9?38PUs%+Y./#@q0Pu?=E9M*J^VGu-9
&6`dBl.%Pe2"$u6\pI6<'^_hV%\lC;Mc&b<`'*3SVc<Mb7c(NnWHD5#eCpTp_fYEo
Q!1@QqQMWR'[email protected]'-A?83PZW<OR=<%WFXd->saB)eTCX]DfFgAJXM</(1
';)J9P/#Nr%"W*fm$nT'm8uB:@;?m=Gu[Q"=L`UqXNCI7Q8Zuj$=dVI[;S[:$1M*0
)*O^jT<o<@d8jHOgsR/i9f*GG8ouFJe%CcHn5eF53Q,4]q_kqu7Y'4G")I7uEcKMN
HJJ>8)<.`S?kU9G`L)$cUUAI9e#qar)jO^q7<uGq=b]XdV^q27F1h(Zf-s(^*N3f#
]C,Obg.9m6c"*E.fCERogFisg.^LVPnd`d]/Jr-foo#0nf\G/b*G1kj]@Wa,i@+_R
Vb&/F3+>cXS/GM2R-1W\_XY6PUOKF@\M$o'>=dCK]@k]V^f[WJfo/8Y0Qngin=b.`
kZ^2Q"#J!<ki8uH'Z>preWN=m+=jumNbW/N`4%>329^')X%ka^[O%YZS@)Ghjikq/
Q+CQiY,X4qO0t1=TOnVdIIh$`.#ZTjk6cX+*,6saE&ThmR9oWI_H(B=Y$U8gc(:H.
I*h^HS_8k7UGIpocr\SdkDFJXW8\N/&Rl>9em/(CoJ3nC,((c:2aB4t*)FpMDI?+S
6)ORD[9Bj>kkV9V.HXU4\Q_4iD*&hY8`3oQJY?MNc$)&U+4Lp5)I^mU$rThL;Ko$3
:0@II1t@oE&#KZRb[Vo1L+pL>X(AO"Mm]34EAQ@Dq8hsJNOHJ/,T>s:mC^+4%diVo
1-t8A4?\@9p?pinX(P5P$,IuYs-NN4F[&m:]sZ\#b.!9]f9?FoFs\`/3P+Ko/]j(D
D8P*bVU',g%<\LaW8./`Lgo/I^,X.NM>*nJ6oiFApFa_L>+kC,9Q$c=3MG9<b4tPK
o>@B"s(FNqD/7;m`Npa(i649ZW#Kg)oh9@1E0Htb-eU&E>fFe\`Ao_:k[j2;jCA.r
;DQJnE]KD9CUq[Bp+7_.&Z9fr`:LOif`Tf*57BPXor[ubcf)N8,OlX]`V=?iMJ0.c
jo.J"q%Q\RAZk(ahI!3`DP`e<<q.D.AaN<a60E$=Qp@*`K_fT6bWSuMoq&XQ-lK^4
bGQ!HFL0]uDfP#M%I6t`CYnqa5@j^&^Y?)q(3"AV[XLB$pZTe7E8GR@G":#bIoh&7
at7JD5"t^CE`IPT3VgEi0)7Dd#GOEXqYu_9rOA>TpJ9uO;6T1g^R+mJ'E/Qkh'\ut
YH._c_`U0U!j%=V[IZhuTf8da%?Q4e^frD+CZW?YDS<qL(lN\cZjT.2MDa`/[+l,+
j+J&npV@3Q^c;!'q4G$7*l(_j*fLmG9GfE6'dLp@X4/*)^p,XnG9U8NV;r\tX<59o
l8pJ6('F+o3j_4I-pj<n6Bird\n8apr'J=S%r<a*\o93I\?rn$WO+=<ZU,`"0o>N@
6Rg3r3828C7]?5C_f<c8JD)Z&3%-Sa,&5;ue2o-*/O+Ul[1b`kK:X"1)+4h)6lR10
9GaL`6^XA&0T4H!@k#55W5@3gXilF:U6)l!3lJn"`,kgg!ld1bIA*`=Z%Pun+hg=]
]=4"f\dQ!a/*KERX2Qlo]bouu!sLb+>DhJh`R<hdj3^=QAIpt75%J6EHhKkVcpZr.
7];otOPIJmc,6>m0Pk@:dAsh$GFuNcTL<T,4(CA%1.Nh`7f3oX"A^W?l_QF&7O/>]
@hD1oj[Q$270FhFnNjtdL<%-ea#U$(%"GL^m4dUQ/!PHHF@X-"4eF!L7(I!MI"o9r
G;eCfVE@+3PMIqJN1J1F7@UNJOsdr%+itVT8LVHS6A6S'!BSF37i[g8"ID]m/kO9X
6G/m]lm^'O_8sQ88cdA_&cSY[pp9mn8j&*BbK2]1^e,lLQ9:rRid\7%HUI'16?IRs
WQe%^RE+Yo0[$pjR`rL1YT-WCb*k+EH:sF>(!Bi@b7jdaCP+\]>.gAV7b#!gm'a8&
>K\dF8IW""r)1U_qaKib]t<W(Mml-n9$BVabHt5A_GIlYKJEt>8[QVr4Ng-Gcbh<L
bo?(F/CQdFe1BYu/R6fKXMmGHGEKg37c`1GK"ngsIQQ>)1dp)gPgtr/>g1t;a9"?D
r84%Rd(`3;^oZQR'SXUJjNL<Q_'IjTlsItYPFqX"8u1^7o\cXCGbD<k85n`NN:4sn
jhWud:FoO=P$-*&oU>FF`Uf\0F/m/WOADChc&<:Vil)D>Xh+.mTS/cK"TB?fnBafW
:gF8h7/p#q#JjsV63L?7jU'44#fJ!e_c543m0oJ,$Ha<K:qOBf$+!JJ8$t^V4[W5p
1F#Hh'H6?R*s7ZkPY)eJPtX=YRcPI5ipEX"Wm,U2dHqNAX5H;`]M]\b:IQL*V'JgR
Ro0sl9U,<MH%Joiekuqf6>XB`2(VYM.(IIM/F;njggRfg2:Dl+;Uj;s@b4NuZ;ZD5
;jBC.<B!JT__ND,:R+#&4Zq*.a$5KUa'Cop76o6]@S:c7e2]or9-Z$i_5JjA);RqH
CH5-Y7hO!::HQ%OMK-shEC(pD7(l<W<DLNO<P%P&\QpmDrBF:BP1-eh-JF:uI$@)8
;\k%_eWCMF8o,VYH,N,<d_,A*o^GkVbY_k/;W<L%"WbH;A.oD`9>dCLb'hg^5Ve#<
cp_Z871I=tDnYOG<u_3@X`H9-Ef;;%]]F7&'m6o(KNE"*f6qmF74D<''%a74*Mn-L
H@RR4+JN*1eCB$!9lS'6d1DO-;HmYTNDe;dK;WhV`8(o$9.3bF-;sf!=I@lFN:KtO
T30mUdWLTkeUQ4]kLgk*fSu)[9or,u<)tRK2cZ364d;DXj/8neae[t@opaImSD"=[
fo;^H`M6U!I+YN7fXWWdV*/!^S6/J)&\Qhijf&msUr-aT>32j>eY1"*g-*Z*2'k)P
FNN84'\SIB;H4^X%?f#%[9=<F7SS9?FSo9V7bI+=N"*3T*;7^$BiO`>>Nli+ARN,[
P09(2>VY/@$nt,H0#7.igJ,^#*MZO^>uNg1cok7]]sZXLcns"p>oK3dh:#+&dZRVE
>tpC9=WH77f0[`n`c5KoQ._Z2g;a<HZ5!FC/K%j9A6j`=0H@GpMDAKM0&/g7>[uUH
;+03aJD;-d<UK!T4lShe$/Tcd?G3>lA:<0R6FomI?>].;qRb#&nI_#13rQD*Q)J%Q
<*mc:hiXhm77CRkHemK1hpp.^jT%O\Y?!DHhsh(ZbsgEY?/R=;&2jY`/d>])#2hZ@
;qb#D1ddKR(f\c<i0jCKXZaW,CS@jN;Z6jXnClfHLg_<:aKp%u7L*?)Qf/[li9X<L
JHFe/Z=0m#=`tbr(*+b_N_)tZ@6Pcqeeq&*3AP]E4JiS*rGQ..5[mJ;*G,.XWMngj
/76+@/MW5k[KtmFs'jE(`NCF^r\7]-!(qqjT@/+E*Sb.!ku<iE[;a:Dougi?']SLL
,aBgTV.eVL4V(QB>K.i<jW`b'!+VTf<n/<q2FV)H29R"Ocb;cj1_=2WMI0'C?X<N>
<L-.Wo46E=A)sW9(#NPE;H$UQAK\fuelPrH8^"hMS\A3;WFKMPFCiHijdaN05mXlY
#\E-U?Nc0e;b8`N)d;Z=.)oUr?<u6l^tq6b@I@ahIT$S0JA%.TiAN[TXoqDPIbs3T
k.X"@I#c&MSD4<B.(41*5&e4F=%1CVB73qG7.rVm`8<(UkI,a"1r\4URPnZt^D1YA
rdS/GCuLt=hHkoY*cL7V`TVc-)^XWWY)8/jMqRsd5TN.(c>7.3qcp.,:%jYW:5U+b
XKVGLBKeQC31X:NE1q]P?:G!1J=C5_q^=mB=QZ,e<fpM'mCNNRjG':`rgddCFl\!;
C-JG-9EJq"95!:I@m6eTVP(lp9/8'$id@lfNiVE)W+uhsC<j+>f!4O$F61sZ9t%HF
(:.ZpGA#L*l["ub9g`"E0^G=BC!O@4c1]UTS_,9U<IV5_%?Y1A&*+2\lgCif"PI/l
I'B2=k-8[bNX=\Pfu"hn?:HV`50[;l(?[#<lu<d+raE@k2cB@4Bthr27_gVQ_--.-
B]atb0dl@Cgf[+VmG/4fK`C(Eh]$IA1`kWAL>Ymm!ERL@?d@]uISO"QEBMFmC:;?!
#2O$'E4NEom<5mP9cQ+R\7rCPCHd".Q*P-TP\t`6g.8M<Y0PfLcgLf!TA/OFVKt[S
p'IVc:dY9F?@M@qMXTs\%b@e%"o)YH]4H`_mIi;SDVa_6!?9&Tds1QTL*,X8)!LA(
a&`T752Ohm,4'3]E;o&OVG?QNTf\"ojV>.=2TK-5eP:"Nga;K.V\%(j]Wq]hgYWYM
7DJBLBkM>omN3<]X(6&oVXPAj3GloW-M$I4NP7/sDJ'))-O":8$$#eEn?4HM%ik0>
/oq>NE5il67!ge,b4?D(o-Xq8[8gV$0ldW[R?=RGL2-2',BEErB+sZKB,g:u4u`X@
VHb.uIl;+3`@a#lEi1qi)ng?!]i)<fns;mTAhu^VR`SnMDf_u!'&7Bn5jH)gF([,s
FnTr9?LCQaF]%CG6r`K=$03^=:b+Wts&sKJcK8IHmq,$b,:-c.[H#:EFXKi4<NEXl
C36@0?U"IVK@<T@og0GSp3Yf5*M?iU=nY%-d\>[\7ag\E).^@Jk3ggmY)M5$b&"+W
miO[LNuW:T'm4MpEo21U5C$j2HfE@hCYZaL0-9Au>g^"0e*e.Jm"@F_2s]p>M'Xbs
cIk9<;0Hfjp3cf1dUH_#f(c/#pdXn[meeD4m<;$)G.)N,mmfE#>O;*EGjeaHN>s1o
nS0G6q'K5<*lThAT(pncH#9bZ=)oTFQ2)4HnRmAa^O(1]J*r;npRe9"-`$Tf,^F[6
q=W8/7gj>h7duJ"GQJ!+%r1t.>[&t2B4mtM+(B@6HYh-s9R@:lh&^YSW^b92eQt`@
+0/ZOd$1(;<T4O5#'Y#nZ$Wmp<1doMhZnNJC*j)(H06,n<d43-[B`;rV!k\gLST;>
WHDRF?Os&^fn'!\ctO#<g8Uioc2Djo9A;*[ErR`RVO-4::AYfDcKj]hT1AdLaRU6+
lChC07IP.Z`c\GVFAL/"I\l.BMtK$fDd?g//]Ra5g-30,nTQ7,cdM"kZ>HHbUn>j+
[[;1jd>UR#ru^fZfCKHdd;CnrrRP@pT/^ufoQBPEFiVHr+1']TmqoPdL]c33"+igH
d!.r*'aoa`@F4e&7O8_*7:OYh`+CkGN^]=o7IdnCkB!i&dWl7\cHKl#-.;Tuq$r1?
c!Xoc]F&X>SkiqE=khMO6)%1a'M7rNPtRuQC"3!57\s%`66l&h,be'YP"R+m#%Ykj
<Jsa('A=0"d6jGAm.6)lP3$br?#J8@`T@t<Y"<D/M-RL'!1;"!:oaF+NJ!m#nMDb4
3o=\ij`9%%`b./M^.PU($MFu<A'J0I)JD:>JWY]Am2<Tla(;U2CbrJgrV&ZddHia?
SUU_b_ocO=p>&3iQ-8<2H-qVbqR*oND_*kbo`!g3Qd,E@lsFXQERaMu>lR<lea)>h
F8\cR'<e5*76I2La63-mgIO!$H;r_%$PW;k^@3Zc"Mmo<D"fkB$`a<?&7d3s_U,qL
M*]FW+S`FLj:7,:0[**$`6>kPPWfNik4Q"I$9&R8nXO;3W_lBt%`OMSeJTU:oPG_l
;Aq[t1XLH[#c5oF9&r'mCDQ>.cMNAHaHF3@/?a(ME=PPooNKMIcP3J31sRmU-VUhq
ff%"C_G(cVdH$alb`R:r1,;aLJN$BRr%0lb&l[mQ8ZO\Jqn/-YcC[fF"X-FRZkVU.
5)d_Y9[,4R(q$kQPsJ6]Pb`F^_K-Al.%o*j',`b#>t%lH:2NQUa)sN0SCNj@4Ro,.
V0?(p<Z>OPYVQFl@Tc`;R(6>G'ULN,[[jC4_6W*t'i_QJX_unEqBKY"P%?>Ye$fM.
FMh.t!F&OQ].Y:&&WP=ehT3s\A60S*>1Op"4n!pZ2pH8c1=J>/f@U_-'3JXEINO/I
mIbeb8aL1-hr#?+3GRPSj\]&5fPD!\A%=cHO4lKdio=&+;C'BEGt)LVj]!i+KAsFr
@?S,<Snk"K3PEMXAbk.`=%ue?Kr3Lk-)GXm%P4RKW3uUrTP<-8[A[Z*k/":8)YS6W
Cth$_Z=)EVfs\2u<[atM.k]Yh_-;UjXCH?PGnFrKrC;$&(-W,9j"Z7;`8CIt)#S:e
b)8'g(qfI,/M'p?a`4uLBu*Ht-7?It>!3OK@9M`XTC\UXgWs)*G!SLIRH8e?2127t
4*@+KBue[BZ\=OSgRPA+nFUn3hK_u5>o`PU?HU1ZSduE-<IL;ZNHp!.;<H.^hk@IS
>$G"]:GgpPeDf7R\b=_5o`onm9@[$rXu`a:i+gRJoeV$Br44uR!<Cs2!e?@Q`kZ7"
!o'd`JWN%$^h<0?+JUfG:U1>DQ3@H8>JiQV-4N9UYm2@R`-e_V&OMaK#p,S3Ki#Ju
^BH+^?G"^/V5=R:#]uPEA$p#imN<nP39]6ChM<m,+i,GNYS*/tM%Mlh5j4mUeeD#>
O^4Zu-c""LR7o>t@PAkEUncGnMaVN90ZK:K"-d:YDm%qS7i+3o(Mf[e0u:gOF@-rk
P^P*E.PiqKe6E\ja,eXh[)Jr8(EZ%/;9&l(8;SU(j90FUX85B/3Ab<CX4W0i-;;Ol
6s_/);j#Ct7`m_jqr=H(=qWSiSZ*\?i5C#.EnlMB&k+G7jGR]UTiT$DQ9o/i\<t2o
gWR^((?PH`Nt#L89R3F4bikdidp?ht.=BW=6tAL)c=tQ:2)T!ifpci-EDDj(8nT^;
NmQ3s:Di4bVek"Umm_RuP;75O,lO@ahCd-S"WGt1s!3]O=AV$mAgXN`Hh1urd$bb=
kToMge67[Pg*oMQAFuT%k%dd#3Cq>pj@ck+O]"eN<G*U"UXVV3dAg8Ab#L#D1qo4'
8p!u\Ctb`X_/[`BG>QB:4WO+nJ._XC;X.gfWRX22<>q]5lD7L\eR#=WR^H2]j^"q;
I]uik`E;FPAZXFRZrK^-5GkZ&S^bUDesb]*l_Sa,e_[r?Re:"QjaF>_3jm=]"$+U(
Ks9,L`)rKD@dIZcZ.;+[=W8Ytm%ouQem?R'Rl+gEjdia/Hs]`l!FT\sTX<:Ae68>A
C@,T7[FW(E>8pd[M%tfK'/&'ERrrW9jh8.Srnq$#KlHH+`OOM@jBS1>EpdM`\^s%/
>oTV]mA7Iu((T\:S$dG-jk[Q#IdgY_`H^htjh03:oNn$;HLGG4^":!n?5Ei\.Li\t
fA?F4S+V7!jo)sGip,96l[SCN"i/b4"CR`7K'[X]Yh#-F@2pSHn>6r;fNuKmH[\QU
JLIm-@h<)h7>UI\-*aj!hjl;Z8a8Jd`RqpB@iT'3mAZ^N\?=3<M\8\L^]5Y4qSctQ
$]qH57)jKo,\3F1A[/4a`qU&[A#g-%Z8Iff[Nd;cI'\k(?<tb-IkWIT$^9.2;1&!U
,%La\O7QJfa-j7cA*eK2ZYj[+\\C2gCt4u\G'_FO^GtEsqjm>5K?Q@u6ti(WP=jD:
7sUJdk(<W*1o<L`\f4=U/M3SMes=b\HV/"S1T0mMQd2%L;/1LoWqBu+Ze@2G@]Z7j
[>(5&>$"SeND$E1:8QOqG>;nD8Z=Su_UBF8A8Ig%A$r9_dE0^I/Y/B8oet@M3NlcT
SNX0bc@4D+lVS:Rg/mr:VTsNAFDdZ!NcQ8Ibd]`=mObQ<pSP^^HB29Ec+16*51JH$
De!Xtf>./.M;!;>!TTCdOS/nOfNRlnn/_>5F["^7>46t/?&uJi0-0**]Y<#<3-@`h
-02Suh;g]e`O,nLb+%EVEnr+6ZhA4]HeY!&?+\C-If/7(s.Ee@<FEp5-KN+LAd3$<
D_K+7Z9::BocBsMLSmZOh,K\^X:)bDVd/M8J$<leZ-mt@>3gT(,5.&7gA>K<m(Jao
pE&GOn3:jVh:'#\T(Qn][oqqMQ_\jJ"lT;+L%*q@`-@mhir!GKn_QLOGon?nr25hN
hI"KPT/Gd/kFM5$?bc@GrS`AfTCh!4e9[`elMY@tp"mI9HQQhZ],u[jrfHpPT69T#
kIpWHs588HL%,'h`VA=4jF!Sbo)<:Hq;4F#I35<Xrh3]m^'i]j:sJZ^kM?$mJ+.n/
`VBH\jo"#.oFh2-i-MnFrSPBbI\5a"s/5Phhr"?]TCr%NVss`%bTJ#~>
EI
Q
userdict /pgsave get restore
showpage
%%PageTrailer
%%EndPage
%%Page: 7 7
%%BeginPageSetup
userdict /pgsave save put
PDFVars begin PDF begin PDFVars/InitAll get exec
/N157 [/Indexed /DeviceRGB  255  <~
s8W,urr2lprVZTkqtp9eqYL$`q=sa[p\4FUp@e1Pp%7nKoCMSEo()>@naQ&;n*f`5
mdBK0mHj3+lg*m%lK[Wul0.?pkND$jk2tdejlGL`j5]1Zio8qUiS`YPhr!>JhVR)E
h;$f@gY:K:g=k65g"=s0f@SX*f%/C%e^W*ue'ldodaHOjdEp7ecd0q_cHa\Zc-4DU
bKJ)Ob0%iJaiMQEa2c6?`l?!:`Pf^5_o'C/_SX.*_8*k%^V@Ot^:q:o]tD"j]=Y\d
]"5G_\[]/Z\$riT[^NTO[C!<JZa7!DZEga?Z*:I:YHP.4Y-+n/XfSV*X/i;$WiE%t
WMlboVl-GiVP^2dV50o_USFTYU8"?TTqJ'OT:_aISt;LDSXc4?S"#n9R[TY4R@'A/
Q^=&)QBmf$Q'@MtPEV2nP*1riOcYZdO,o?^NfK*YNJrgTMi3LNMMd7IM26tDLPLY>
L5(D9KnP,4K7ef.JqAQ)JUi9$It)rsIXZ]nI=-EiH[C*cH?sj^H$FRYGB\7SG'8"N
F`__IF)uDCEcQ/>EH#l9Df9Q3DJj<.D/=$)CMR^#C2.HsBkV0nB4kjhAnGUcARo=^
@q0"X@U`bS@:3JN?XI/H?=$oC?!LW>>?b<8>$>'3=]ed.='&I(<`W4#<E)ps;c?Um
;Gp@h;,C(c:JXb]:/4MX9h\5S91qoM8kMZH8OuBC7n6'=7Rfg8779O36UO4-6:*t(
5sR\#5<h@r5!D+m4Zkhh4$,Mb3]]8]3B/uX2`EZR2E!EM2)I-H1G^gB1,:R=0eb:8
0/"t2/hS_-/M&G(.k<,".Olkr.4?Sm-RU8g-71#b,pX`],9nEW+sJ0R+WqmM+!2RG
*Zc=B*?6%=)]K_7)B'J2)&O2-(Ddl'()@W"'bh>r',)#l&eYcg&J,Kb%hB0\%LrpW
%00o=U8"C#`5IFdL\:?5^:q=!DJnY#kI7q0AnGZ!bfg%e!;,pU~>] /ColorSpace defineRes pop
%%EndPageSetup
0 0 612 792 RC
1 g
/N47 /ExtGState findRes gs
1 i
0 0 612 792 re
f
BT
/N42 1 Tf
0 g
0 Tc
(KSD/<name>_<nn>)Tj
45.334 0 TD
(7/7)Tj
ET
0 G
2 J
0 j
0.36 w
3.86 M
[]0 d
540 55.03 m
69.28 55.03 l
S
BT
/N43 1 Tf
0 Tw
[(FIGURE 5. Attached Pr)17 (ocess Output)]TJ
ET
q
450 0 0 621 71.92 80 cm
BI
	/Width 603
	/Height 928
	/BitsPerComponent 8
	/ColorSpace /N157 /ColorSpace findRes
	/Filter [/ASCII85Decode /LZWDecode ]
ID
J3Vsg3$\D##D>EP:q1$o*=mro@So+\<\5,H7Uo<*jE<[.O@Wn[3@'nb)1p"<n(D6[
>5XT.AlC^cenm@9:1mM9jRsrOQV3s8$4O4K5,;(j<4ZX!SPQ1_W0CI+(11+D<bk^H
j`\=EYZP^B4!g3;B=(iZ<kDqOh/Bf.DH1GB#-14B?>in,jnAY&^gM+`4=1jRLVuFG
=1U7$q-'%UYo,[$="Tc_Aoh+f-9E5N]%1lsbd8H&VLIe^)Q@V[^TOeW1m[Mub1F),
CUIB+9DZQ<hb,nnc5t:t0@/3+22r[rYmR/r-/C'>(?`*`lMEX!hS6\-n*m"jrp1u6
k3dK[IMsj)e^<=JXM6A8Qa=@$Ge9T_T<k'/3=<B_Y;rf`i;Gm"A$G75bO^7l4j4RV
"hJW!HNZVf]Aj+*DaY0C_[WC[n3+#(ZM_TOHi!mr%.j\6-1"h+Tgb(oq$Y.r1iXHs
:OFT!_,.J;*5*u[4V(&&b_%1N&o9h^6kDH*qack(d-4+79IhP_&i>:e_U;C!lq/n+
T^U"N/@Qfo1Mh1-71>qR`OP1fpH-[cS-p7XdFA%%b&P)G-H?[n-SIjVg[uZ1FA((I
d&lsNrQ6p$GsFah`)T:Tnmp':92pm%fMhEQh[NI_73,;rmi;j+<)$&_33b#>_P5@T
_WsA)YuMrSb&p*t:"Bt'93#!^4T-@&'oeb*f^sP@p/I?Z`Bi1a[6m_m'1=c/:UV"9
6!>!,SRu#)D,4TpeWdU.8%#p\>gFq.iH8K?X2t'5[O'0D8bOaLF@7N_0k]?$eL+,H
=$,Fda6i6.L0uuoeTf]u:()7'oju7%=4d.#&E?l/q1Cp>&baT'O_-slce)g*LK"qA
8Qat4UpSfbe31-TgN[$dJPu9&.o=nZhK,>Q<9?cDkP21PV!3"#9jYn\L/jOGpGJS(
A,!tLUtZ\ss.)ip*)g"q)6RI[l5O"PVe$XPEK2u'^(2`.=HtbPeN08Q]=#%R!o[H'
7-^+!H#*qkne_O1Bu2kG6&TD67(ko\D\".Nj&3lWMqB#_'/su[h4]ecg#kRPbPJ<V
IW4d=SY+uNFdq.@F!]Gq?Mmb,Y4:62fiiXj)fOhS/^KjF4aqac#^TG\Tp+e"`!Pc,
R<P_"r#ZHf\Th<+\`3O::Y#.:T5UFoWmR0o`dQaJmJHo*b6drn?gmpmhuj'K8S.ug
=:G;h6iqk"-3c`f*<Y$^$\Apb$:.cFrnbj8K2?Fq6.>[V#LjoM:lZ/T=A9+\6n*gd
Xqj@V>moVE0nrNM)FIVD%H55cLJ[C[6eHetiWMJU#6l<h=H*pP6qN54/ga!=SJ1"9
;2589+d0o54sIpJMc"@E7G,9iirieL;3!D$=Nq`D6tqWXXu8c%h&GC-EK3oA3_*<>
*TN7WMN!)87<n>Ej91$q;@Z#a=UcP87#@%(/iC\JW]t"cN07(68kE/;-03"4P>Z9M
8Efj]#Lo9.;N=XI=\U@,7&c0/H'Cl<<@d0aZ'J;5>"_u>.h7fHQI>2-9A+_Hjofjo
&;!a&)3$B57*1ipemY/LFY`*4d@+!/C.J)h+(d(SRo=3B:"d2q-G6"0`$g!EH-/@H
Ba]htRW_G^brM[anW'r=9TY)=4<n8@M\G)mcKO@RUf@DQZgr%Z)<!k/h#<72L+>uc
[ll-5l(Sj6LsGhP66i#cP4VL7;2QqhW5Tg;FD=3@aKnF9/B=FU.[/<%_*]K%%\L,R
Q."m867E'bN"iF?:MJiN@m)rI'`)mrg1s#he7"s!*hq.F8Pc9":8ZPkMp=q]<N<0"
Vfc%9;&YEpBl.%3obt!^R`.m1jZKKLHD3j^@5I1;5caRL/l,*E73a)CY&sYb;Mk]\
.lD[X2=uW&)Hg)keV17D$@u9Hq-tr:9s0^Ea4$LQ@k2A*W)d)ter%pclm7gQotHhp
)WbXJol[7b7b$.m2esuS+0+tAfMP9BC+Po3VO$5qcH=gYD2kj%f)F.MM]HU$/]>.W
3oSf8.qb^gM7==]4j)MPF7"[LVY2(f>2(K<lFeIQor@90>Dm^-V7XCK`m.f2f,Cc^
9t%OF1tt+<5Hcs.U9rMF?)sZ3lXfe#EGj3"3Yc[F70L@"-E(<6`H*W]laE05O5VW+
L$n?=]f9Kcd;,"pnHFZLG]Ni.$X\SV*1a[Hk3LWW:OfD#K<dHm'O]\#KJ-&oY4]gD
i60#n0n&f:phLpTN!5=02DW<tlGhMWV3#^E-']:!-s]Cd>VUC"au2knhqVppkJcM@
\17[D)rlbD(%of%hY#MnJUFYt_T/!TY[d"hRdOHL`Yc`XjD<_<YQ[24PeRsW9`Z4`
k(h>f/oB=4$_o-l:!sqU8k]+'Tk8I"d^<"*l+K6XjOT[?ppS''NCt53Cj4Db;cUuB
,onjZpXK%kcf"TEU\1Lpf37TRl]$1np'/@!>5M`E?&c,M`l-OL04o%R"_f44dFqf#
C2I7Y[J%VngKST6D;Dn7pBKU3>E<fB?-TqS7d8`5YBFg>h7NE!=5FnBH>d*V^%]PB
hcoPuDr(B,pH4Mig^f!U=R3c42[SGJ/i%C+)8l6)%,ou3MK)pi`;$eZj')&5EOhjO
jqcD+4%GFRY"Cm'5:MW*JlQj-n],,M!9RP4E_0IG(V(f8k<+beF1t_t\^s*jF-iVB
*ehr97.7>UFuOL1@8"YU;<hF_Wc_XMeb[<hlWnG3Fl'g`qZfuW>&$FfY)@iaL:3"'
-_A^8`S3E)6]F7GS+_;fgZ/T]]63hQhl,Mi3dmdi4qGMT?Obul7p#&'Z@2N)R=Vc9
V<q0!a4[Ig3od\so"?Z6ptkCc.i`'g4QFBV?VTe`7tgD]>-Q=;4l7K(&ChZa4o,[:
-+qg/o)@d$pO>EonhnFc2"0>@^IMMA:W`E>0@Y<]3SjY;9!"WU8Gak-jtJo;c.7*o
Hs^CDX0!92rbd2>md9'5LVEZuKB'qeoCG2%nbug8k@r0;p\j"4T-R0orYcj-bP7ZI
U9?6"edm/,DgIL[%eJ"UcKNFLX9e)Wr#Y>SrbsFjmum[RSuddsrD1Z.WjKMOqZ#k0
eB:Pdbi8KaD"#_Ao'\:9aRHs+3;W,M!KYlsi`Oe"VZO$7#EUYFn:9e#1otM1"cupg
mp?$oQO+2Ls3)\a:^4`i:B,9K#qp,qYd"=Ld`1V<^5UkE8p^BU\DsSWrU1+!d";c]
/0>-r%?+u>/:?ZbEs*$F%WFn8lqjH2U<IPaeaJ7td,bIm_$b3]s%g`;Nm,l^jSFsU
AIH5PE6RT$d1&r%'!A,ALeQmTaMMod#gcobO@8Iim1_7c\ZBED&J"PO]+`D/q_5&F
CEEp<PlL72ktmKN:o+B>EoRZkY7Vu\:aZLb&Ju+6!g+iCd?*j2Ya*Lb'5N(3nHuu"
#nQM5$h3T00_W/!;Tgcm(=<^-n>QoDFRsGf'JW`+O4Nr"E$)-&cf+C1nUgn*jW8F+
*hj/X;3N(T<>,d@)/Pi?E)RQ+f+lNZ,#6q7EONn>;#IN,ooNqNnJ)Xt:ngh8d4uJs
:+"1[f'9O#&oig2;F)C&7-hq"O3WFsb.@8M)[gYeqP#&+%/V2%T$f,_U(OjQDhSb-
%d*>#&9.^QY;I[=`uT0RVU=?D;<&9dLEnVE.C)Gmm^"1<M^7fep@2t8;:?4R@[-E/
&IM5UWWt(("Xl&D(@j*dcbB917',r8,0;nkP*%3A5;#j-0!?!>:6-\6CF?<8,#Sdu
cRBeeLr&O(m]f7gO`;.WG8=&Z/5SC,8Ad$aSt$@9/hed\P33mKO"SkRMb$2g.44u=
Yn[oTUN3rhOC]Dm)(%rSY0jhBZR$M%Iif;e(t37QF#Pn<7gNuq*"VcoBl,_e<A^ZW
(Qs8'P*n7-PjoE42m]$A0mL\M,;ulp3jFp..NGoNaS$03qQ[!eZ]>91$OP:10QW:;
Ysgc/Bd#6c"tDt_:I:$0aK&6P3n*IWkeT>79##BO+>2b<n-KlqR1M.sn]I7+CngO)
dlWIl(U!X$:_uA-rBZTF47JdTPJ9F=X$-sql&ci2P8OE7h`g[(57#"g:gH/E4[6-,
+I!0Ilsi8@oeD[a"nWfG%ck<fEB@'H7556@'B8bND\k2tm-KQulDGH%d7I:_S8_[u
8BjP#2ak$P,a5JQ'VP::I7SE&99bo4FH"90\Ok5%68;b:oJK'9'2*FY9XM+8oN=%J
O$aTgr,T+C0Y7>r5tDU%p[k:B'WY%cUIt$V9/M>kPN,1f[7Jea:@uXsFC.p%_&N$6
oo`Gh1t><Bk<P4I7WgRZ$I9GA#g7<q:%K#on_[/C<A*n7+cDsde/oG?q`QUXW)Y-@
l\;A1]hpX);QfaZbj)DI5>)_te$=[+Z6<)0q*m,<#h>,Amu(0HnqpGH>,Z-4;kEcL
[9G'D<>E&KotZtQ]j*G:>cDpPFj42Le<Mo=?$4t/kqubSiEgZjO_Gm!Q183=oj;k;
?a]i>p&Nso7p=IM@($MPp(:^k'k)8&Lt1Tn[NT*9M^Xl;@^[iNXgm:Tm:1<"A%"O1
p-E4I7:^R5A@>3Cp/,BZ<Fp>VA[YlUp0hPkAS-+"B!uPgp2O_'F_)0AgL9bb<d/48
KkPXdBXWn6p5s&IQ"bE0Bsp8J[X'!\V.r<hC3HRhnqgk!=)2uiCUUolp;$<olY6^u
C=>C`f!,h<[;7bSD788;p>J'@a(dN1D"d13,GZCsf5<MBDmoU_pAjj:kA7T1DLq#)
2M#g+'leF8EOPmd@InC2%<3/h*nMEQpG$_J2*UaXE2gZo2\0g/d;N)<F*C?#pJH&e
0lsfjm<:j:QIU)a9/ee0G.2=3nL\g]F_nNqD`7=U17'FkB_=<>*k-uM(Qiu%CNiB^
GF(]\=%MhE0eSTPGcqR&f9L\A[;IoH1[V;g[mtZ1^NsrXr`=_$'/1R^Yo#Et*quTV
;1X(<jaMC-H`aQ#(SQ4QHR(PlI*d'mo9/D5h(na+I'T;l2sGlQ'ie=<C=jPV"&XA'
V($Wbr\JPE0!0Mg2(=lsJTs>1o/VB3*H(TanG!B9c^BC[%tIaWKt"%7(h&.TQ\8I2
F>up>pg8X%.u-)e.C_<lQt;(5Kc)jaKQnV!3$ied?%ifUKij`-R"$0%$%j&MLj6%Z
n)]A8+*mW+Io(KLZY]d=SW#OTMHA+FnV)k1_2B/`NOHfBQU-A7YD2d+K=IV8f\MTJ
o]iroD&DMXq!jDj"d!W>O17c%\I"BY'o#j#Nd24V\H@P2(Qs%WOgo7jmg"78T*!WH
)#5D?GVJHo4-H"'Eqq;Cn8jN5\UV-@#PglK=/D1-99sc<Pk_eG)-#pH2j="aJ9TOg
;2LXf4dE:/1:Yl$p]Z8;Oa&hDJCA@`3GFp=WKu3:Is;KjR$B9@GF@-nP$#mEfR]Mo
Tq$@QMDtR(=j]FdWKS-LN;5Jd2qO9M1@&&5Ge#u/3*2X'e":hENYpl>pL<Y1k5H7S
Nqh.r)+0nh=d=6JR!K:4GLN$!q4_hXSU(Bkft3gNo7NJDS(\UPRB:_f(SVedU7+e*
qCQpCAF(-`U02!$H,C(-Z(AGFJ3$2MP!+@7:T&1_V)Q;gH<H5R?&SQ5R.G6iZ8n;?
];<*(RJIA[\g)Y`$)+qcVja^V\p]&hJZAN7Wk,aAm_,Y\];p7oXLcXhR`1U3afP?l
Xgk^0g&I630<NsmY-41o3E*&+)3$\jY1ii;RdhDdF.SbcYIab<q$4,`PGOYGYo=^`
q\?>QZ\#bOZ26,A>9g=SFd$#=ZMQe@>;MpU1UHsMQ?tuo)_8;-<KarPTD;?g>;`^2
QaM0SP']ug3fU,NCU\Pl[ek?ZqRO)iJ[g#%\6Fg"q=hDJXeFD9Rld/>H?/Yg5I7tk
U3_`UpZ8qh]<@W2[!=sG=YlS9gRd+l[2YaMq\c1Ic$#K#TR(1US)8noT:'tmR2Nhc
=sK".(Rb,t[l[*Fqm3]?jgFt%VRV&J2uUD"?,52D_-<nOgVK4Zc\bnG.9Z2#49)ru
0nnC%]i1,l>S!;$*Q'p"_&L(5412q.-,KGMQocaFR>n4o>;i!_`S&G1)=bZ96)b`U
`cogt*,V17ahi9uML4g.>UdX>28bii]pfD/H&]`>8$TV>[61R7gf(GIQ+@pRVVI*@
3+%r`6):$Ib1sh$1?HaU=j6_2VVHgKZBLVrWOprD]XgVI;eaE[P9/MQV7`_FF#V@6
X*IsVSt"KH]W&phn'PB5c+Iu=gl]gJRAQMAaaC_K]]4^UdEm:8c("*N]:$Mtqoc7&
^=Z<->MIM+LUU?'d(*`9pf#``a.&UBes^$i4JC1D@FEsZdTmZo]YU#L*IrKLcoRAW
rB7%pe[diqR@S9BSFP-7Ff8Rjf6<A-gf;BrO2RS,Uq1K>3ciq9:"9+6_n@MIrPR@F
_8=h6TR=5e4kJO'j4Bh$1HeC^]b?VNBA@j]H$fdM]EtlKF3_G/cCKC%]t_hJ,N,)5
gjTpT>%?04pVK)JfY/<NS]T*=5MpmKhOMXFShntZ5M]VQe\2!=fl+&Jc`3L<dCk%/
g#^92?cX4jP?f->rBKDtOhomu\bt(*f@SZGQ+oENf!m0IrPcOA-f)LXa>oa>h$)s>
$0:ljR^Tup;(8]_UZB,sJp4E5E^h4:X1J/>^c)_<IT*ZjqrPQ8%:7_]Rur@EZ0jg?
OIkY'^@@7Jn(@T>mlp]n*iY4Rftc#&mJd.Tp:p'F&+JHgn[2Hg>WpuZ*V+Chnem)2
h^S.U)tM\&llS+VpDNRnj7FEbE'HA%s%E#D+7M;lV-[6hIoZ2,'D7b6Y(($Vr_;bY
!UVuWpE+g*s$c\^Kl-jB<ISe:fA!5c\_ir<G(*Si5G@@LS,$A,Xe/%r^Q11="5Vf_
hL!`4?bc12](&!nn%>^\J%LIVXmqe3o_W8bs0p),UX"-RgY-#_=pXd#bN,;\+:i]1
h>IG.6/`BB<%\IcK>D!D(mIcE'oPN@&X^bllM,b@?BQ0?NTg4e5@:VY<3B'mHTe,Y
#].dD24Hkn:aoWf<tLWlVpi3[rcJmJ5q%qQ7-4kKUeYXr>*R1/:7ft4P^7`^[0`V[
C(j2Zo".#\<+cqjD*""aUfm"Ab%8`=2nNAa(Rro83?F8R,a)k0p/N]2b\[!RhC]m^
WT%deg0MS5?H1PI=c+L%.@7&F1&;cZIl!IGe23V0(6_[\a]p[U\96+dSBYU9\BWUn
H+ejfA,$H@Sl:<[9I;Z&Y53!/ctMu2>u**o$Kl!d(*0fOk=O6GqgH2]Sf-/Mp[qLf
I`J_Cg[02'Y;a(]p%s0r>RUQ=6\=<qXu^If57=g[m(M]]Eq69Re-?./:=@q-W)#cM
`BgG\.`FGA,Uh;"Y?Nd36goo<og>o=@+N,UA6Sjp:Z=eB0Sf9%k/=NF/H\>cHU.$e
08rgN]J#KZd5Nb[/G-Oc<&kR[E<M[A7$;&X'1]<,W>s*%[email protected]^5n7``4lqFe(D
VUrm]X&gE)Z4u*h4d2A^fe)d-i/'jB`.k8)d0up96#pdc,-`pdd7$oNau\J)&Y"`.
V9VC^#-F,"aUZEfF>kbg0(OK?40IosgW`Hgg8`\?750MH03fL(eM(8(:!YH"#2%F'
I9t@N2?e\`9C[ud!)dVrKj[b5;U]2B<dg`W>'?Zb@R$/6=_(F=XB<'BF`k;OgfGfF
F'R;.Kl"!%h9U:NpP%XQ??Bc,^g1r^g5T6t`:fs-pS*4hi-6RVJmQ_A#>%gMXnaD>
p14<6^6\_1E+5.D/FhZNju\W,pd.Ju9TaH2P@,"\Rd*KXCYMQY=T2fuAoVu]),+.<
P3u8Kj^4T1Fe%o*/U2Go>t?u)="S*&VJ2rBqLWXT5InaoL0)QWd`PThVI;Sqfk+0Y
=#+*AQKbu@e$X%+:8]f)>./PYfsAm[LXZ,7hiqq=2Y3^*f\Y;tE-k@9Ol'0imCC7K
*GrOWS)0LGEdX*9U@=\n1O/ECXgP5"4/B!u2;90LQ"`BO+f0"[?SBZHrIq;tDB/B3
Pjr%nl!O0(jor"[m+4\`<uqHFiC$sqA*%uVk@Xbf[c3'%q&Z%Nl+.feL9t+9f=@Q$
hVY]E<4Ld@k'[1s]B;k87[EpoBW',B3nT5R:g=pZe,=cFD&iMVLH<$eqsHJ*ao4PM
&HYV[lXqk?"[Mi+"BV*%DD4*X6$P*g=TeXs%DCr?-Yu4N]?+51Opsa&:mU%7cnPjO
H9u:D$t5:BKlDVO0BA/&8ntD?.1i5C,-;7sS3r*OeU5.l7!$rm&o!>AZ5o<d&L*Gf
Ls1u%+\!rcQ*[T/n.I1hpqT1iX6kVDojtJmMXF^H@?$DVHcA%,V47&%ER%`?]pRUs
@?b_a/,g>:34Bol_LcPXl9e(O32@Z*7usJb+N5#`opPBrMig=na`sd/<\0/dd)lG^
M*V(#j>W;YQ;]b77k*P!X)N*UE_6(0/7k!(0@4jZ`u!a:-%Z;dEqWiVaYa&=Uc*q+
38[:6IkkMEY$>]_A'CpG0BQ_)OAe>Vc$<kWik.s8ZQa3[pbat)P[6"!H>lW(00#hE
VD4:'FADTE3haHP2cI;4:NuIoPMFrDZf6I($2#;d[/ZeZ_LU!:&OK$"#GG*TLJYsT
,bfU<A>X6MaZ6=[i=nSOd7T3Z8'*u#%.'#ZSg_4.1HObp-(2j2Nk62nf]+]uV$6)Q
9NjqKf(=Eh1ocnQRUY2(RK\iDVB<.ne>X0E>A*&72EXr;%b]UoWg-0FQq)VnNH@:/
;#-hbH7)M?PsJ5h%(jPYUt69k8QIJ#ZnheDLg"P19!LCg[!HIk>m#qdDh>5HqT+O8
m+,7;8O"MD3d<2-FYWR3^"C?L*DLBrY44B^enY2oX9lDC$UMS9`pjS"]!4Tfp:*K`
]^b@r<36K3b!'$&A)j,JYS.1_8]]"5m-QF1G-\EclUPK&15<3fb13)Q>9PH]?$rp6
P$:R:D3qrGQP7ZJ)qs1mCZU@7m'YZ\#9@Q\4l<&YJs&Y=ku!XEd'g7278,]Z.2<"0
Ya6QO>'-fUVrd!DG86e-=ttH0%*"4T8a`Y!]3R(!kdjG7&)S-c7EqA)VY'7[^GNKS
YZdI$D*BMjFE<2@g^qB5NtY*D8s\uF>/JnAXC<_V.<-m`IJ!?=;b$F?/N*aO1Fis4
A*W1+PlmouZQ7n=HS;Z&MPO8]ZmTZCDV1LYX/S4m<TBD!1/+dkEW"Zu6Tg4R6]tBi
VX*0."SM?:>Er=7YMukWNneLg]9sTE\@\4?93q;&q6EiVRTl-GrW>8@PsAqc+K4Q@
;l;Vh5=1nAO"nXabUFFA8IWFHE2hj?3^4ouejX^,CO45$:,Q`Y:nLj,`fQ?b)n_.n
Rrnfl^(PTohb15)np0"F`Ig/%M05#Dp"i][``)+;A##@[6%:s85O15,X_l7M`Z%!T
&KR"Ap=,hj&:*tT=S813h&F(h-%9_^QUNdENlKc+kYi4#Xq]1(^2-\(B70N8F]CQW
\b@-5VB\j1:+XGmIO8f0(VMcEJ8bucFL(W19&`nZh-=$:9?fUf/9Y?jZ4<p;N=e#l
"\R(=>@G4*9i7M]^94b*N)mm&>H#"#b)hUV4ach"WhEYJ42XAQjr/*;?/B%/RZ;EH
7<>cOrOioSU"Oatn78taYLb5_E"&.ZoCkH!*%N-j?%:2Cj2/JGMRW*s[@Xnc;7Kch
SG(5Oa_Hhs]q'4;G>2,/H6d1_SVt,5F;!K6ar'E)8GQ!'-dacqQ-<>FdWZ+r?i.<Q
Yam,odB<MoofUOI<e%J`KTdMU9QT`P^Jt!hUZ=MU[.8Wp6$KIpfMHm08(tLA>OHO%
F-fMYHF!HUbQVYI8qkm0;K-nBYI/(?@u:**T6\pFJi^4>gq#2<q;2V"Wo<Q^4qWS-
]$p)Jf:L9V_rFJiZBp&*Qp@8o+MLY'`SVRBgLSq.iK]c,R?HP.5EGZ&,Q#7R!?BRJ
1*[]#>Qd$5FfPf/^8prQ)[ntM$n%505LZMc.u>(sJj=[Q2o<Hslj4PeE=@sf2flL:
H[ZQAf>-GN3$T\7$PGA_>GLG>/deefLq+GQQPI'fOFj4,j-?a(Up(5m0'jUGe(ZpJ
(a)ciZeF%Qj&\GZ-p67K6#j1nEmQqs]JD;Z'BBM9A0ml/$69J`U/A$T.pfl9'>=l+
*?.-olnh'd-U@S`Vb@sc')<u@3O#QU/a64kg&jYj'bH",1g?]h,.AI(-Su5mVi3^G
PAhO(fL"?0]aQC";TTq1/Am\!_h4a!4>4Wh(p@sS`.Lq)4AW:O5<?ub^k7HK*%ET]
<i]2#3,9R#Zr%`_j9aN\ZFfKko,9gG3#,p#Z[<!I/"-hblpL,N6:*Q</6o*s8$I>E
5P-hJb7);KH,bK:`eifl9Fr"nE5qH95R_['3jH\oDoFaMVeZ_Z>,4+rU.7O57GJlf
X:H\RTFtKG\?la]gj1.qFWbIC4dec.Ck+LVhSDm685+Q-MiBk&IC]c_WcPem]4"%T
i#`>4N=(c\Zs6.LDo`h(T8ZAt$AlWWi'd-.SuUf`,MfM5ONA-&8Knp/jA*!rYWMF9
Z^UqP6cQ.<XMH`^72V)B1o*`;Ur>/Qa^c1#Pb#DPV`tOcabr2:.0R]XU7jRF8lVVl
bSeQ<j2rS&8rLHd9MRP%X$s&Wb1*PdbcZ`JHqU!@$hU[F1ZCpC.Qqk1`LKn!;)_(g
?-@OfbI"fQXLZJ94A3S#&%P%KgVC))n[.A2baPAm6fH&O_FcYh9K^6e<2Lh/RCJ?i
9\ccmn<6O6`6@SpVtAB]1%`YJeP%gNc%Ogkgsf$i]$1@m2OS;61^KL"36a"39"YR-
,\p,b?qlm9:#pH?&RE+kHHN7o^S>tfI#5[%J&],tc;A.JAC&M2hSb?W9B=,aFG<5+
o=+T9:>COkA9#oaM9c=\cP5Q/oZ,,u1;WfK&c/F]XN`EqjMj"r9T$&N/36*;N3bW@
c]MX3Uq0<CJk<n7[51(K>G4/V<^tP5]VQ"_A'_4BZUDDs:Q5T->hmSp#tZ]U/n8/)
7'jI0jKmh%94QbKbUGXd,-/mEd5aWlK[n8Z(;WEI7Csm"&`Z\6(b3K:[;+bdoWc=Z
>u-.r0]a"oD#7%tSPhi,bcN,%gr;C^=AZZ;[8a1`h'u$F.Zo-0cOD$qgc7*0PWJ\R
;LK^c2&SbL^I5-Z:otC0=G0QTg.r]3/VOYU7%^ik9@?Kf2n8I@]Hb,k:J`<J^5M59
3MT5i5S(h";-]TXiJc7\]u3f#7cSsIfbW*)/C@n)eJ.8u6?(CiqU9jp<N2G;PmGoG
:RZoX:)oq)gge.AC8j<!\_ICg2.2]KO3N(Xe\rZT>SOt7*@Xj[OVub>U^gDkZIT`U
\n%a0oG3gZ.G#O0^9Wh;]6osA<E5^_dlJf$gu,f(EAuDl=/3j^`4\[bm*C![4$1r_
;:NOLJK6=o<H-gH?"bp^r7B[7Zm%%R"Cir>,t2*1aQumQ)_<Hj!#<\FZD6cF[/\4T
O\-?bdZ[bNb6]/^ef:fWfkTVL@K+J.'ii[k;B8IjS=V3p)Uej/`WRp$XUe@,312P0
:s%9l2,(Mr5fL+uRf%FQKrA)_Jjls)(`e9(WuS43K1D3"Nf>cs4A8EEc9kQC=qjQD
<B82A6X!.?6ZnUI'ZO=9J6SRqg81p2eZ71FkWShHYuR=./$`6PAhYJp]K@-9'fo<I
pKL:N8sKq620i%.\1-OM>H0R0"=0?tB2flJfsLGg%%+t40-2!e==q$N[2Dm_93f'e
ZlMujZ>/,_VHmu\gpP@/@E@,EIit<,eFf9ZKuTm^mEDA7f;`T5bn!]pY1e$\;o=/T
Q$K^:Pr`WC^+C0`FR'tkj4Omi6lA>Jh,BYo]\Mh(<g@+F*6L*,`Kc.c=SqF(F2l&s
ke<eobd97[>^.[XAZDlq^6;,p$1L0LN5$s%i%&&41j%E9/6?9A[l*ZAQ+PZ,K%?pu
+3"[iC&?i-7a8pV;g!bb<Gb:e#cN`M:0$i4eQZHV:0m7U0S=*p<K<<NGJM)kiDL-C
m9/BFI#_'K[l%W"r+k(&o$9pFMS()o*XKO['@g\&hUPZQeO8!M6t-hR>;dEt7N>FR
#$D#s=+2"547'%@-n9'\:5ljG"<67+"1b`'VF>\LhB]OQ-.Uc]14gNM/[MKl\usL:
]3XQ`_W"C01T:EN@sJMnMdp7fhqH?Mf6u,]lo*.d50H=A4nMFWg72V8pL:]g@:h+$
E6jZCC#jOa__$kR6f$eq,X!a3]fJ8c/l3cn6pMMV@<LKlS9F!?d60W6*=0ro$cQY`
3aLI)ijMT$DGO]kYgIH)>[a_EL$Vd)?dmS5A?I??L/Lkooi8G(`i7d&k#'$T,oj5h
WMp:ilgRA:i32Pk;[HDHm/Y[+DU%_Djdh<)'lpPhHT9;]g;3_r%DQQ,A!X!;cR+5,
30!+g]b`:6kX0RX<Ur*N>s:/pk]14t/OH'E373256&(=k'=Gj10'MX.B`<3L`enIU
-0[;5=%\rqY*C;nQ=[b!\AjoO*gu)"7TFo,i`:kD7QT:(,3eE/l-:=%Y*%urU?VY(
<Z[WC;e+(nO6W=:AH&NB,d-F0X^Q*cC;-1X2"fcR"CQe/Rfu@@EcU-0Hrk)@i@8-s
Cq*'F7I!#"3::S:"tC^An6UKs:NI:3$]AI=XC(:j@'..P$<&oB2ns3Ylcm/A/o4bZ
CeniZ_,e;:.m)d/^,;-Q-5M;u"LY*hr_J+s=IgdD/S%0O9@l(GX_%3(>R4]Ee['[j
m>8$co`\i8\4is;[7sA1H,2X]NTs68aP,0M7?_8Q%S>b,;`'`^gSsU@8+)?bj;-Ru
rch*FNSp!<CR/1=e!/J/'',=hh-FqMDJ_q.W&TOROE@*K365Z3@-3G'4T&FNl(UIL
GjJ2oC@+3$NNR1=6:<q99SLH'bS"dHdThMok:42G-4t+*%r[bL7>pE6o`W2R9Kf8>
DuqKV('%>V%,Jnf>,(3/7h/4V[]EcqAi)I:7S7Z+-Le`SBrdW_D"KGOro^.pkt\k;
mH##t5U!r3j4>'Y76Sebj/amXnVNQCAnGuqiG?]EmcNs(lJ(LnMVg=PB3F0[`V74Z
nEijs_jmDaqUXP89#_>8.QesF:CTm;j(p=.D'f\X5:\XA/2!PH(`_TV(:YcqO`(t'
i7bNH52[A\YYk',F:/QM?E[6#88NIj5K.*#G=Kh!7(tl+kVdH\54B+!]qgX*XR_1^
<Z5(MqWq0o[3maT/Y$::;^0gm3>Pji,`(?t7QDgu<6Kp4=V,FNf^1U+-_laTMl!s&
_/gq%G#J=lSUj0Ef&_)dC0s-.G)5Do.(O1-Ec1!oEV_1;UcM9Y*B.?p/#2_YE-G"n
]Y(sh2`#R0F7BFo79`4N:B1&C9k(Ib]:BpF=+E=-MH]s!?;7EiG3emh:3O6GoBo`A
`t%f0e83T?=P\G:43J+g5BV7k65Jcp++_cT+PAXu<`bDH#/GDcCD;.om/EG$+g=i"
MisWf>@3?`lK5RaC[tf&PQ-]_9ffcnn4Eo#a%(G*+.04o,Ai3cg\sG4Sa5G740MWk
^2KXrc^Epu8k@PR`,'cqh4et?Gjom(^)&b@Ie\0E]PA*Z?9V)P9*@21;PN!DPhFXW
?_[BU:?^"rTBCoEIa.PeU@al^oQ5:**e8"?_K:b*HsXa=A5R[QZGf>T7F,"Y!RtG:
b3?s[km$g-?]KNjO*pAZnIFr5s3W-"U\4p)rD&XV-C1Dce9uC6pg[KQG47I]^jW(?
I>=0_2r7%haaIfeILA&]FZ"V(D>m&e8#PKuDrH-;?@4N4r7,YNIBEE:Zh7%Icc'Ii
O5\YJB%Ed+F]UTFet.7#`U'*'q+@,qmqPoY"rPDW=%9WJJma#5B`5p[#QroNrdd>m
:e3\a'aoa`@F4e&7MQ2c7,\[?UfIp<NQ.[^Gk?_J)3II#P$(2M<=>#1AF_]j;I:r8
b[ReJS0i@fR8%=8C&G7E3M+U[O*@YTnG.IF.Fe3HdId9a^LJ"&oi:MTHVNP*f`_S@
A$8=teTa2_eJP"6/5s`6%bYR#9Q"p^Q/3N@]\dUK=>g*>B!Y6M;X>AMmr?.j03?5[
`u/6Vj=RZ1FVb(;XBm[W>>@eEHEuWWQMgFDNN1K6FSA?9-C7H*e7s,0`+$,ZO('J=
$RZ-'^5_9ZF,C15+YD78/3KJI!q!2UB'fEoDQ\9=dUW0ADUp0ER.0]!]o>g#;o\HL
I8hhR$[^k-BtKSt\#5GNoB^0`@qsaJMR.?ZX/Ua>d(Bi%K]5#V!ncQtY*6=$YtoHk
otHKfdf)7'e(UN^/UTV_5>^D#'Wb&UN3fd-Hling%'2AK`j%V(r'X7pWgYhB"9PL0
n05+>5&hQ\#"_X5AE(Su_Vi0q&Al0P8l;o&*lREo3tJ0NlV.mVNF\]kbS(D+"\!>"
_(NEaF!W_3P8n^+b`UZO0242o2'98i$Ddd4.`qOh_!N]G"j'CWR3tI`3n6DB%V-jC
9%9'gQcrFPh]t[47/',BZ:iG>c>eM='%@Pi=T-P;`:m>5opdg#6ci%#5Uk,%#9uX^
NF>8QP\Z=M]Cdr%j$HY?=$8s3;u%fW04RRM\e^!L3[chl<E<%\$paVP<Ea"Z\9Bb+
&)'djol["W6SVF\[EWi#5dW%e?a/lCKmqd"XdHh1%O1Vl7J:$]%Gi`>>4/Y=>rL'c
mi:GC@^<qpcf.cs>o-5?Ag*-dMp=N0iH1V9a5PY3dtHhaSlL$sQhj-s:`$KsHr0S2
H(Mo&(1j+O=rrNpkfsXuP\D[AQNc:[q]i"IRLB&Hf2N,tHdLJ1\OL<0DO7Nm>9:nl
V-=GS[-7=mK:FFap=6\@>Ft)jmb>JG]V0[_"1L3lf%%-G>TX9hnD$5?Y4%@QrBb:D
djW?$p4!auo%^u7bk"A\(BJ;3cQB+N'_48;:H[N3eFd*S=e]u;LE!`mbXI?Te@fd?
h"P+3H-SYGrnB_S=3V=e6s)q_hYCJbRHEm"I"gO$*[;nIiKh6Lm/(,H\YAp8hkdgO
*/A=NHbVemo_h>T^T9tu(IRK;m;0o;rnkK\o_lIaa5Yb]/`a[6"T[I*LOX5r^V:G:
[G6uSJ?V3C5o20Th#$SeNH,$8-oD4ej#hpS^')8s3sadj-$N16?GG,e$K5MIEmUN=
ZaU:niH-r3cjCUQ3+U#G;al<mhB53&Et2Tb4(,4NQF#e)&>E]0F"n:=`+!QM*@sC2
d9\@dW1`1E&bq-`%OK)]`>I@*>BWh'b!m%k)P\QpNQnT_[<MEJU#N&1&\^@tQNnD%
<+q3[hE=CI"PTX3FGnQ#5Y*mM,2+l-Mm(]"1aq$%,c$\KZ8sEnQt[kBjIKnf`Ho=U
\L(kZV3K9.9M0S1.cj'kB(Cg8b/n3Ggbc!XM1/$\H#kP`j;aK2M0HO#`@g9=`I\a$
fu7#>^J(sd2^jp,19$6ii%2s1`hHo_1e,De@H*,";K+h!XW:3Efn#$+FA+.$3oAGi
GVE/HUj1>8(g>?f;lY":Qa\s84->EG;L^"#K0H4Y]:Y6PA4W-VDpm'NTX6lE:jJAI
B/F=2b`[^d8g-[f2"#:f_EP_k2b,;AR%dQGPYh3P8nhi&V.hQ>db872BmbD>;dPm@
R"J+Fm+klAd[a>S9heq[q0M]@UdJ=1ZY0LEWAQkSdH;B<,W,j9ZN@(*R=/&)oH9B>
aW$g4[92_K<g5DWYKM3WVs>XGIhaQie+ZXBX/"j\&2KBs)XC_b9hR%%NkSU3QX?g/
KnYg*_cW9r@OtN=JlUW&f;fp&gW_ilE?`P.RNklSKiF2sNb'Eh2/)=sS9d&e=O5HE
A?@/[CmIA&>3f_b/V2eQp<MGkCJ=LT73T'=Y2%eL%;t'F.B9aMi*7dshQ<ei\T^5@
gdpU@mY02IG=p1R9<EBn<K+PVId#?s?Z0gD4gg8!^c7&W_$MmrL\ID000?Fa/tt.r
MBPDReV/Ah2/solM6no^bC!i;o;gH<\64QL:L,^E[?pH6U.5B;)Gsg_fL#A_77V\L
p'mZ!M3tkPqcaYKkq^^FQPb*>\a`r``=0S&R,m8I=NQ,@(_N@pe>n&&Q8Yb`1pEN^
@as!1YVld+E^s->SFR*PW!l)c<[s#f*qffJf@G6&R3Q`-/EpB=cS$gOgHI,'/rT!l
q&s"jRVI"F/9pI]c:lYinVRZ`L2o+]M?:8d^+)n_K/4<r10p>lKZ1IlS7^m]S1$g#
cS?YEXg?3Gf"u-2PljQgP\$Y4MC?p=1%T(TqkGOXF!oWa2pn09\91]+`j9YslBT*J
onGo:)N#&:BOe1"N&6&Ec>Bh/pKWnC&Q:WjP;>*)M"LOY1\e-`1;_DRZ<R=[)NS/k
X<Qd\S6<`HipT%d]=$f3iS9onf56n4f5Q!cg\[^Cl:+3tF(G7!eJia5X";d:EYcR8
_Z8``gV.AK)N'eAKC%ipT6OS'`#.B`;m#/pd@unHH&"s[?),>_QKk&!X(P1%U90j_
ERfGWQLR+oe8XDT;d>r^Ef*`:PNE8(Boe8D%V8>EU\*^(AS3NAmEYOj*j%*kPOpkT
dWQ]'@CcE4ESJGon3+M!c0KTH)&]urf3KT6F0Ba"*S;a:N?m/3Ja&/=bP'cZBH:`V
nuHZV4#9.FrOJ,*MV.=nXqgEK#Inf6pLZFC%8i\R[IHkY^g!*=lqIk?=r^)8=V`]T
HNQtZh3FYa2LWPD0,2Xe(@@ZdCR5lrcZ%]Qj7H\J_&7=9q*if7B0VqB\Mf"O]YpU"
r5#O7HR!5f"mp>SXOfU1O5EU<k'KuAp3DfB?g-mGr*$)`:DliGL]39Z'b0r]$]4f9
5eDHA+3tJBO6OWa4aa6bjLU])I>aXYqrcj&T8.=GkKBa5DO+5&`qsQlp<VgLca6f7
?N,t,rka]q#0t;$+O$\?HI"k1X^(\gHH*/K!%H'r0GOV!I.bddp(,*F&%^Zeg12b%
`%@YUNMc=:#l%):`_K"qn$p`*R02K$m"jN30(>6H#mW/,"=qWkNo:5IK*2^HWc+./
&=SdOL<Btun1^Bo0VJ5VCrJ%($B&roBnHLAV[I6Angd--&A\c-B*un.s):+0lWX<!
0+?4]UQ0[$YiN?6kc"";\5;\B0_Dd"hU&M)\1i(OY`B>g$P8F1c,BN0E>oM;*=7iB
psBrknJWj7V[Dr>j+VM'@IY#Y4?sK5'2MaEJb9]H5Uis,'Q1iqOZO9cGj;Mi'lG62
YtYu!MUui[lc*cTUk'<k[22TM(QhE.d8_#9U2>JS(X[]fEK:tDh&/_6'*=@9OfKDJ
Y8\([)c='`Oh2R[^Dmj'*)X`rOin`lcQ*VH*DtE/OkUo(h]<Bi*`9BZYoG45JJj82
*c^orOo$6Jru_pV+ArFeOp`D\%iV_<.Uhol8EU]X+!M=B,#Td4Ot.a)0-_)c,>pHF
Oujo:59pk/,Z7,XP"R(K:F-WP,uRehEEs:K0-RC<-'DmfP%uDmD^Q0=-W5.9P'\S)
Ij+Ag'B5E(Mg?h8O!t^*.8lK]P+*oKT.1JK.T3/oP,g(\Y:C6l.oNi,P.N6m^FU#8
/5jM>P05=1KbY5j\$?r)P1qS:h_#Q%/lLjbP3XaKmk5=F02hNtP5?o\s"G)g0N/31
P3!l#@3JN[-kdCOP8c7*+#4KS1/fPJda0mmM\\)t1K-4gP<1SL5;X$@,82XY&!ST.
:Giea2,dR6P?Ton?T&R-2H+6HPA<)*D`8>N2cFoZPC#7;IlJ*o3)bSlPD_<H(Fk?L
37F3SPFFS]T/mX\3`Dq;PH-anY;GdE.:m\'XKN9lSC\@:),!%(1Vi-O`>VCU4O2rO
d<\UYNBM8q4gBi,o@6#Z2O"hZ8/'rGmGShdL,P7jh2r-6OD=0WDa9/HH#VcD0hW\[
6U&bZB9':YcH?I8?ts6:!=b'!biM,)19<*#m12=`<#m:T;aN/:lL98G<#%ag$qHO]
VlG,AWdaJknkJVd>qKUEWp(.ZRm9qtfY\Fl%.%d>!<q_XA1u_MCf!_VSF[2U@-nI-
mrli#R)7kK7\rZ;c$WM&"CU]=!)7;r/rDQ.[4-3M9B2P`jR!G]!6Hd.;CW=#8ZtZ[
C7@UK"S?s@%m!^t[cbu,p.[_UAPE1>q+S#n#ueGP0DmmA/OhEM9Q0\mm.CI#"&[;;
a7&t&A+")kWr']9%jj&:eNX6iRoE#q&sD!3V5?=3+\*($j=QKbeE$Ofo(s_D98sMO
Kp>[m#1h,K@^Ppij[fY6-:,sJ!&&f&F]TWi)+?,9;RK(s9q+RNf`LY&V\JR`&"Qo8
ADg7/=9WVFO,2kM/nGd;=nTq@OXVJ0@9'D?8p)^^<A=ES:rgp4qc1k6NF-%XCs3UF
=RT<sQ.K-^]1_VU:,M7=[G<P0TjBFZ89M0)F:@$q>t_Op@YS<#bQ))3Y/Re,g/Z#p
j?$l?Y4k^YY;SS`NIih14'&dh?'ZCQo.<Z/U>=;q$^PQDe/r-3@Y@&0^\2cY(*.&:
q.Nf^D"]AmM[a@L:HfPW*qkj"euE]^B`sJ(g=D_'Q?cd0IlkL`C0%;%cL`qcf*'Sa
;/`9BY*SNW[-<[XKpLV,WcMnH!C0]+!QDH:.DD6N>jY"uD3"!P[gMmf&;>7p<_=NQ
nPL!$ol!MS?%a?:Pf1^e1m%@(Ot9q6ol!G2lI'M/!jlQUFGEDHf_>ni7W]K,[i8rJ
Q#[Y<G#l[JG:-+gKj9oVOptg%05sS6s&1TMrj@?uB&d+g'!LfUS+a.[2dK`*J1J*=
E\#mDW0($p#e&7LqCj9pE6.mOd(]!c7i,:7<u"/@8lJg4N0g)O#\/0^B6%#XG=867
Q4!d)QLct%rDe2:/f]3CbC*BgH%_M\99XlSZ[J/^IM\mLf;i1,'71OP>S&1Z(%HXT
2Eaj=qmYYVXp#*`$KkM$M\m+?(`@n5"^!T>r`,?9[l7_SGl4u5nI@:!(>"2Ya`iZr
I*)bKQ/dPL$#J`rj>I]Zp=/HrR)R=4"c:UYc<SnD_er;%FLZ7HFtBQBlDAfQH3+h:
pBbVo'!HPfCcJtK<gR]k^9+oa;5+GAR*`I4eJK*]EAk&k:LciW8VC3PCXsRm6lBg_
m.[p>L:FpLLPeoE"P3>FHV<;40]A'@23&9;^NL+:%teiqPhrgZm4IjiL762$EeMpK
Dj`MH\K^)0-\>DKHe$MK,qQ5V%:b)f6u$X^CY)J0'&UqsFb;JAA^QJ/5/b!6-FZ9m
BoA5$O+u=dG3'fi2'hB%4?U*#93IaI[t*phiFZ]M;Y9-YG-tOuL;@"AOm"$Wmp>MD
4]Kc7RZ0C2W4d&4Y=qn_Hj$d;/oY^Pd9d\CB.Rt"'rc^t/Y'%6SG47VDY&=aA:D#9
fME(LPU-3f)#\[YT\/XhXu0!Y#k.Qja]ZQP)?UaXpIe31K:1<oPu3#j;-[*s>rX^1
q7M=cVc-R#QWDJi\OW:f9947WB,"b"Q&12p0(0WcK!6\+oa#+\*9FOFRq\RjR5DY1
Fdb6)PkmNM/_jXc+\@YVMV3I_&1r]W?'^RVM7A1\<H.$p#An1L:)S&3[TeQS%uV-9
S9`[email protected],b$KNQnZ2=?=,uB&%\:HTM7g8QW-qR??1aX''P6
2[;\F%e2/)Q>Wt!qO7q]s$KrDAiah,Rd4l1m]ZIHS>r`K,il]ugAMmMi-%7^3-TKL
ktEK+%lM[]2"QV"^kKBBR5ZitpF<O"Mj"i7hJHc*:huAoA!ZR0V)WT-2`Sg5Pf%cS
S(i.7G>FT.D[)[KCUS.sq"m=gLf)[dRIFXl=ePK\ab'0dV(B*"=,LrWV4$%MUb(s:
f55Xf%0]f/W-_6YgJOVjNCS:p]m)7+O5Hm\04^J1qMbBJ=JLC(\ZN%7R[bm5$nhQU
Ml%FaXo&KJppW]G0ln/qV!O]Ng(mXK)nBg4AX#`bS/HkMGF4jCBpH(!2b0OBm,Mr^
YA)b(R/+PPoqXPh#+Saho](YV&\^57!#9j2\4+2;CfkN8Vr_L,4B&r%%#*GiJ=N=V
g`*q\Bt`&``#9-^HB+'`pi&2iaEG$#"P7T2H_c$2Pab=e\ohIArMoLTX$"4[=W<26
2i1!]J/ZG!cm-DtBo5K;NgEJP)VrGg?dL?:AJW`(R3BM8T8[c4]N]dA]g$qTitd&4
W*I<GD8F`Vbe4jQYrn0!WB&M!ZaMqJ:jXu$ZmF;9#LC!Kchh>E%7>)$8%r65fB;VR
pku[urNgeh\som1>h*fLQA6JfY4spUA_><tUVZcacoEW&IB\'hDe0aGs(sd9\Zl?.
/ksD+eQpD,rO(9q7f<#LA`Ub'1m)i`l$/c^hM0)(]"J'Un(j%IW7Fna=UX/$#N3(@
h-4XVrUn9,l+S2\e(oY`rJ*u,2i04id9=IKg<%anA`H<Qi]^:S^$Wbp=LoPTjq.RS
h*]IL&(Xd:[3rGG;+]o[f<$lfPFEr;RX*lAmFQ2BZWN0*RDI<XKW4r^U`4Th*AIg-
e(FV>nNO7Z'Wp/t/[Mi0_^[V1<iq*Z<P.mi\l>`@<(YdbRG(pRclK/RYAMR3c\a?u
hmnZqIXflfa1WA$!ub=9*=9tR]r7M;>5T3)^(lu_3kaDiW_h+'S."B4&!_7A_-S!d
Dc_[@V4N!;_KD-OSr9i,?18PNbDMMM^3.C6UW<uA=^2ts*QR&TT*2O#?MY>hqCCn1
EIcqqV;D06>DL$6Vo+jV[I#dD`1+o!6(6E?df./W)#WW(Q#WFQPlH_H<O;;SVbQ%Z
if8T7Kg=aIm\7_al,b6o^H7K`/&]/=kVc]!5Eh_1@bL`IA([)?@K?CW4lC9-'Aa<'
KL$c#fN]mJ#DBpf&EoWf0c>s?j,hop-9EB57UtpYPX[e`OildKflXr:0pt_q%p,gj
o(d\tT+foMicP$G^LE9S)r^/WRSrC7g3#TQ;5mO[PfZp+Z!"20jjRrImXIEjcKK@O
ocB<%[9Ds`gNC6hEOf?BOt--bH"!o'W0CLT.dMZ%@.9Og2BNNb]?kIt].NjU8AJMA
\=#0S%3CktF*VMlAf[DfB_7`q[P#CB]OTrfqPJj%Yg-finm/A(S$pR7[e*]DMClN+
n1_JUVW1#kha@%kg_QXU@Fa7X\Jn78+en>E3'1rrhffKhnKT#kjL8dcO\36706`TB
n@/:B][(\tSb]hg0tfY)>jOZ#U]clANN:q5TW\aEi?E5&6HqZN]0QJ6Y]:Hc_C6_U
#X8_*^>?RqRL9Nfc`=S36r2<5W4E;Z?Pk>SU(%)P05Lk-7'SPe#J;`W2]fWu_h/Ii
;>^_B7e.em-:tI0@h1>X>WAguOk`#>2A2fg/h8MA@5')]A8(9aC4kaS8heJC/5#K_
:Fj\n1linL;epRk\8np=Lq+*qff@CCUV,Y`ZjaQ7.nj+17T$O4knu_W.mG&f1S_8;
bAnT33BXUt%j=9"m,lL?'f;gJamu82[FCCg.1Nq479N%0WEg<1dI`>>a]8s?Bf8sH
$oo;&%lH9kcE]:[email protected]_@6;mj$AVq2[.)dU%_liU6k="TOV8[_"F
*)1TNcSo$I1Q>ku=#B-!_t?IIEaEfeQ$ur)&n,]_oRcm1>].HEH+?k%JUTr->@`B=
Ylm>dU/tQ_"X9:[email protected]]qDO[O`28OrINkSkjB0"K;S`d#-
$ZFfV-5E.d\i,VFBdcH%>j+d;-`(Q=QD^`I3b<H&gf_5Q=tVZ0p@Tk\mVu'<]/&]Q
dFrWeW*sQgAWU1UX']#9Zdqp^jE$&W0'oUg"h\bOSMRJ9HTGZDk*$jYU+,i=K%`<>
<!o"3)ln7sUb@pOL0-'OkJ,@@HXk/r=9f>=EAV:Z)VXq=3tag*K=<#NQHiFC=jW0`
Q<hjZp!5oZACF37RcGcM@p('Ias!7(.FGl65GKHBh*P>r@/O?a`i7Bf:$>mVKqZ0"
[mc-dhp]R3A_b$*?fCQkLVJ36mEIT!j(W/r6U^p3f3>>pI'Yb4elj"sEQe.H4;?/5
h@l?/bJ"997#:%KCX-h]/bL`mW8nfn$%m,,NtOuQkEpoAHI)YS]pDjU?$$TKCUg]*
(0]SMMdU&[RL?.f6LH#WK/m_S_nn@rrJIq*3!X0%W`M1`iDO!4:_E(>2]2Z<oEp)p
I<_r/+T('&qL4>X(dU[P"CPuqCQ=tC7<\[email protected]=d;<R8nsp.21f[5rJbm4ER_I<n
'95q=%4$/B':jei;j!Vn6BcGQ(t/4YNJ[5?F=MnY1h'f(d@\Ap#n()*hK,c1*Cgr[
`t(PZP:U"%.X8u_OX-W\BfY$26pAR\\sS3akrZe<If,Pek_E'A9bfYSp>'Q&R1gn[
)p&sQMi>W4O)caEl)?OPZT4H_->C_M\Mn-l<g/Kf:JJ8iBq-_m8.cl<6i"JY>X[OY
duHQ#kEbO8[(DRJia#(,QA+*&^Q&qkdQ.H`VIZ4'S]2^eZYASIA;WTl-Zt\B=M#\"
jVFL!#k>K(;'HX8L3%?dO&2#$6JBs!SPefBYfEX-U<O3Cd\;:Tl4Dht>D7C(-C3*F
@UQ17C3DAPSk+/uAZ7KkV%QAp+=3?R)/VC)/]oXfQdYA)]_mP"Xin^#d8-^aTm.8d
U/Y&';<,O-G)mOZ7k"Zo?R8X#:T`<tR^0ouNDP3`IWQ<,PuLZ"-*2h2ZV;p4T^&(@
Qnf![_dtta-#+5p;)YZ)CF"MVoJ<[fHEX/K!un;#JM8tlA&cK;9BFE7N3s!lf*M[`
._UnG:QEb&Q1\uFj-cMS[a6phi6YuIKWPjWPt7>s-=jg$Cpi7h_jFq(Tfm@_ZoZF3
kSTC^4hE`JoqpL@7joW]'LHfJ]2,2O.N#RWATG*&hN^`BeeO["Z)67jLMZ&?*5/s"
n=W3!jaM.=gn)"SUKsb%0qial_&+O'1qX+JY3#u*GXi'@91=LbeE2#m:A@\@NB8ha
mD?/WqnJI>F5@q&T6?a^Z-*/MZ#mdOfP[?X>JXgRr(t.KG6d+WPoT16nWF^.8tNTj
59J^k`Ub^i=L3nsj$l8K38RBiRDk3L-&/C55*f8*5s='NI_Q:S]&B!&(9,4\:=Sj(
h&92ZCk_M/1d9N&r2#DkQ9)h6o.4--R?=+VQ@eZ'^XG1b+Y+R8HksiQg73[uS+9Rm
G.02=;R_I&]?F!2/`P;m+TLbV7aW+r0%WTfIGlt5^3Erj2t]ZRE:p6ZKf;Y,>qq5<
6ADbr-F#pb'a^->q/08cnj1Cr?7CHqO4d#Ej"2@SAgRt,;b$3'RaZ>#"^7nt<pRAq
eXZ?P<a=?/61&^u"g,FT[WIRC'YS-uBSMG2<u6!4Lt?.t<bTUE)g#B^-#IhNE4HRQ
HLAGDSarq/dcc]fbUctT[5Q'YMOsFSejFbcea.so)Y`SWNI6m_s0S,V11-%b_$Q_#
jP6Q6Cp$d7G(^%X)Uk#D5%p[97lBHLkF6MeV`))KXZ<_[H/gH3l8EQAB7/MS@nC(D
<ZaY^pUT&F<(5>FcQkr-*OeX`=UEk1.)J+s4]gBFOE(_:hcV0XDFuFZH7$2EPRjL3
3\]crk1f7T0<n\UdYW#$C!N3bKCUS69m-E4bkc6TaGD@8'H>,XH+GNi<Ft8(<ciSW
j1sTUpN4%4q-=m:=R#-mMN7T'62+PVH6hRnm^J3'<)^b39;gJkld]k[X4U,741-OW
c)l>BO1b8FYAIMagts?WaVW(ei<Q[LXkS_9gY9Yp[D]Ge7c!ssHcEKP]%`^,GutH<
`@nC1VHuo)3I]b2r'0(M(E4a?].mQiVChD0o)>iKX'"@;VmdSZ42^a#H1sQ[8?/`[
^^CT".Q'8N>/(aHZ9!Lpe)r&NmPERq5(e*f>R8,LfsM37]pjkl,AsUT$QR(?(42#s
g?P]$Y-L]O/OR39djmHRR(^X>5+CmQX,OT!<"-s,Z[(H<ZGjZglF!pbV?nA26=pm'
>:$od5at_73Dm<OgaGNk]*oUgMki]3*'3F5\0MJLr%c/D\jI`!_c/LO<&D/g$pr/%
5_5ZHe2A452a[Z[(:/cS"+WZ&'r"'r3\#V=i5@#fK">AU_>H2Y_s'6-5b-l`]8O,9
*!a)[TspN$5kBI6+jmS89uF2i`,$-oj"3L]`Lt'e0F8+DR[lPsb<J=tSb"MK8rft$
aZmT\1Q*>!`)&l1"u;ot_6\>O,,W,]k![D@^,&*l'@ncK0gns;\GEBfOOpju'/VOQ
Lu_FJUYiRb[_?Qg^+2N.iB40`]"V<\OMf[*FD@tS+foJ'_PD#Sb\fb:ml/*17U/2(
8Pd*2aM0h`3+K0_;bf_:AA]'@+G.fZr,"s1]"RuFZkO=p*!*f*!ld:R,]X,H"A:X@
F145C5R`=QUkd"O%6&r(38BD,>`6U:&&BIQ/SfaU,7[125='CD7J's/1@hUDjMqYe
\K%5$X9Cg6-n2K\_E3^s*%ErO7EGmE8L/hl',3G0H:dIL3$bFpd(;X)BeZosb7q4L
KOCqS0$>NIb>=;CbP7%fW&93L6]n]9e?t8][]%tE8\<E],cdH9p-P7K8)pSTFMCIr
^anK>O'JVEK<N3T$;12f2fdrWMiPNaL<GNr73hN>Wf]m,O?8rG9`3;Z_D3U9"O"^a
2Zpf`4B0RHs%FYG7jQ&<Hs"-?Qp!5]8Z]n-;`DoTbUenA7G1j$$Uq__mECHB7O3#o
1h]#lR7O,b^e,b,@rF26CX/]fV^drk)6l`tQp/'b`-dQK7+@ubf#IP#8E:@UjMXU=
"&404a#$+Km.A/Z#0e^rbT*<E]NidVL9Ct?^=*Wg8s@JhK"P%YcpSMelqKA/au1.Z
ZODFZo]rLKg;*jT2uC!&Z4NDZ"Y\*k)$JO3PkMa&j/te"`d@lu]5YjPRCcsi8OXK6
S6eCT9J&s)[/.Sc'Zr[^E]m>Pd2\J"<,BqS(;!032*<C]RR]YKrC!^Z`05,fRrl-8
)6Uq"XD/GA!`D?aH-PEET6qn;@U?6CV8:<`6gU_qg!)j:Ue4&!Z7O$iZn!Ho>US%$
;j)(Ie@RE!Y"I`F;sceK,FR%%6I\CXcmkh\T[M#:i\PAF<"26ubd/qWZoZth0e2]\
m/bE?)EV'-6ki6\Wu0(f1X&ik#jk!po-c$I+[PKD`2"[&,ofR:nC<4k9]?l:9iX]c
7B8NL9j96r6gU<^=@Hd$`H6CP_,\.$I*HqE3dioS)pH&?ftE!1^U7fCoi=l1fM69!
.=+W^MaC1-/^b$4`cBWq,tZ)*GrA6Jc@&Jf9lD.i9g0!o7>4RE"H1@Fps<1Oa%Y?V
X_om?GYp=-:ZYqVARI+o@7/gtcqsA^"SYh@Ij-1#5=C'gXUh?f4fSY:8Q8tQ-&,E*
LGkXiaGW5b*JE!,,#VC!:31g7&joR5.9Juq3fJbq1i:o6Yh<#p\/f\=gne(]iDJ-p
;*C;LKq'bQU:lO&f;1l9np=19*Pgbie_2*DJWhe3,.-?68n5k?lCh:!CW3#S5d:lt
'qU63WnV[+XTc4=Q+Eng\m)STVX;#qr3sfh82aX[c2G=9F\=D>YVXbKbLH_kCq)J7
:b;!2:Yejt8V'/rW&n!D=0r8q.n5Vc(fj!JeY=DC!g)4@bR_t+X%U'-29jP`ejf=B
9nO6VPbUjM#.%Te9uC;MD$uo131\ab*NNQt$c&-os&SNZgeFa'HdEiKO?\oX2loS'
;c-AnRD\shZu%/,]8%P%SCu)ua`UfJ:"N[7i%ANu4$+?4[!f;UJR4$*U1K%i`Mp7U
M;Q5k.q95bPo86Yo%m;uhp]"uK4;=g"soL`>%NZI/I<u)Nnlk#fa[l4dE:,=Vc'qu
hM\1:2%j&':+\>D;O#F$j(i!of\2Ud;Lkn&D@4do$mkl/6adK`<=I0TV:g8Afo29(
oQ&63)PgV5;]V@Nr;Om(Cg/u'g8l:HjIk5WqU9MB8htJB"+"/d1nm]%\n0b7't%:p
/]$Do4["EI/\YI7&*"js@l?-lrYaW&)rkNid1/+bC4Y.;\_n@#e((baOLAV'7+dM,
>TFa!A_L7g)k2gJ%2sT3^-7H])H%UZ\*PU%[1:+Q=]_HK@1Dd8S<7?$\)`40]DFHj
A+`A[_A)@j=5@LpefNm^:h!)>^]PNdrPH'$@8t3P<ZGD<HFM]u!)C?SdTu3BQ(#g#
SRmZTjb1\9W2aB]ps6>m/<"RQ-/2dR/mpj;:](9+4+ANQ,N`[>k'_c[_LkV\[^G61
8-OuD's:r!']E8;k5A6A#c;3\c/:1?:+f)b:*%#PiCT#WB80/i@l%a%HA\"bdJI-O
,YVB:CG$Oe[1.!/V(Y9D7qaf,BLA!DT[1rj)X+L@R$BAB-7R[EPg_fHV1pPRgK+kJ
ARc40MT.O<QC=4jRVB4#QJS-Get/&mSm<U/A%^(CAj&[3T0mLVeBTdZ%>:_Z8DP</
@(o#t<SHM?NCL=pgQ$9_*6P4L]=1g68Fn*B'IHnQ%E5r"gu^H(2MGLe;8koHAs:'B
_*d<bI*:nhSecCDhR70uP3P0X94#(c,mYu?Gu&"kg,h:Qk(`4TJ^nU!cJF.JoaYf6
Y33D1iRKI@*gUE?1$B!%j:1ot26UBL+^b2%:=Mkc<cR:_FmUd`CIA-[<L[B-0OT()
@N>..oigBKZ=2"eCs,ST4srm;+^]C*hR+V@2>'`4e8>2b>t*"Q<aAlEimRJCBR\<'
24.t3"B!9RD=5J*>aF_N?Xs#+]T-m4IR2>On>`@Ldkmn8<p/)c/aeA8l`R/<AtWm-
bAS>gDta5#+OT[#!q8O1DQJoKG+m_-,3h'uE(U,c1C%L9<*Wa2hcARuL-k0jj?&pm
k"\\<^C4/FbY(^6>ljb+rU-33d;\eICFWLW`j@_t:?u5Ee>C)*VRTb@ptd"C^J=34
]kC(l]lFT*Ct)2sIeO9=<N;#<e0c:\NGu"K_rok?Cg:R=2LoH>JT7aBj/pBcVUf:k
6LGd=kamW2mNPBMRQaaHk10uQB/hY_G>!,kE8@O5>g[C,*:8]5F;98FNce(1#-hca
@?(WVNVgu-S1gK@EDJd2op+j^/9$p9F>dV!^?0P*Irci7C2(7acI;AT8j2n6dKYf`
\j5oE*[T+Y^*Xt&Ig1$8GJsJYn_[:Q[ZAl)(hW18[M0le]f9gc0;X-pE=r-?*r*mL
G!6(Fn*aS%RS@cD8arcoba3)<iMCKXDYF?3G,5%TD;]A^4;t$,pC2lNbEuO(!CP0H
otNZYj;.CsKQGTOBcbdoa#k`IHKo'98p$_1Cb>BsT$C>l;>*TF]L_WO>Ba+;h(6OT
%n?4,q_bQ8d7'D;h'#K_EU#(#WMS7u0(\^_<gK@%_#qWpRb2DAa[APR^98nd4O[cc
-pFMPn-Q(7V/Tl2)sa(]EntfF`lCe3mQJs]/(OZ>NXKVdQ[!u8k`ZtW8Up>:OjaK#
Ae-k.PkfBm5jt;3pZr@'G"-HP6=CQ3G'Bs3#!BrF"S<+W@K$DVE^DlO#kUmdoNDE#
s./d6Dtq:Tp!VQ:T=%IAr:iAPfd67;/f/gDi:8[NErO*f7nrSuN#dBEC+[_?50nU8
WPPLN`Z9juQ(dWkYk<0q?ESbFs1."<>2J:YdXMnbNo8ph(hVm2lkVARDg9WWXC5l]
3or(tDCT?iqAAWOC6J@8]^J18CMJklci5>ZM$_%*%3-a/I1BK)5Bl.CFe693HhZBF
(CU6Jo9SQXs$uajJ+EU5ArO,fpIG%JYF9rKL$qf_9Adc]W.7+(n2M[#$Nu,L@8Jp?
(&\Z!6K1hoPThOMLr5tW=QFWg+-8tP&d]hL)%VWt,gs56[TtPR9P.2sX4?_8I(^n+
\`;*0qL61g&IJp)m.Qjci:NsZ2AI^+e6t3@>`(T^MH-G%C=H:r;Q!(P<]^1+btG%h
jNuO:ZINm'>]*V'/Cn`"T$M'A)B:r!8%Dj*Pko5`"W,(mnJ4,JQP"tP@k9ArUh2Jm
XOQgGS/+m6BXZVM=W=2U58^*5XZB%>*jM*\lulSrV:KKC]\]S$/+*=uEPZ:%EidRs
e&Kd*0m]qp&fj`mo(dV@Q&DQ7i::YA?)B!'g?qUVSSh3Sc0+_(0&)B0me=Afn$"h^
+%M`Oqu*;gIWeMUs#c9FqW#!OgFW3:aBQOQ]?_usq8#Wq`q7-0X=TFGCW"ku2f%[U
q)Al$R,KWTlgkcNWq5Zc33c\^c7/-**lpaOH]IAQn6?gQ6-nQ9OXlO+Kd"Nn9J[-U
:OG;:/e>=>l9Go-q].ce_uUX\/q]\[b-K6>/4pLJM$D*Wo$&+?1+^s5]b3Gi,r_ae
N8Ma[6j#NiZ!:3iX)?EU)nup4ks)bbbf)nFdd2)(b`gi_[7g"2fh'VM<8A#/%ufSb
0J#"G)GJZh2+=nbXK:bRk`&9U7k$f2:Jt!];[K8k*-fZQd0s/Xd^AIiUse^K187]g
V13".(/:'*fp6DH@(/$4rF4I2XfZBn(<s62g'c0%&)*?*`Gs\"/^8@1(@-(V:,AEj
;FjfXpl\qjA^KO..f9g(hj6d]Sm1brRp&duPb/aL/8]MG4B3F8rSEeZ-"P(QmJDgs
p\WbVh6c8/.)ulsYjKb:4B/`(GHNEY]I^/O.c'j,nVh(H*]55'Ph"TDd5'HQ`B[*L
9:/TC[J)L5OA70%`c5P+bfgb'+'UKO?<s#c(=$h.?('8+\%=E/CK<HYk)EKo;8).U
:DM*a4)P`_o)[C.X+<W%];DpJfm;KWE9$:+Vl.md1rHmT]3aY%0UbJS`n,:_+#;8a
,p/4eSBZDqB/V)\^ts+\s&.B%*mq9#4BDoDjEu+mUIJJ>8!;HZSK5t!(-ag^o@j-c
qI'61&^te@09)cD1VVnJna`#\PBa=HKc]tPY;Y.Q<Ymi3oD8`!OS7F'#GQ'B/'Fm<
>UPNY;#MI*oBtE>,rGJUXOZ.@*USij<XU3=jkb%c<s>]E4Tl1F<Em[U9"jK(8-J/s
9C[Lk<WGE5m02"GfI-0+%RJ-[pDrlCKM[[A6</R@T^3UF%K5_3BO)#)KJ=U+*1r:J
D%2KC/;,_"*^eS-h]\ZhL@F,k_l*5>i^?@p99D/#=GY6FqV[(4/h0:lXKj$d6Ab)L
r5&`#(#oF*N(?rA_c,5)&mKmFENV2hdcVKW'PE6L\iN>`lqJP=!0$HANlCe^+63QT
=<m)o`+!L*j@"ie;D(F0fc;<uKTVEq:.e)\/LBJrR?LNd:.a,%-fkK)PZ!N>8m*/A
@,X.n1%DG>BjE7NKX$h@c<<kDD(Xkf\X-2<<"nfn04ABYQr=K(9Nd?0k![=Z;_DZU
fpsq]K[H5e:23L+XYo7ZfpboXDGAft1SStYKl[;DPZba]k="R*;m(:=g"eaQK^kX4
c='HbDGDN@jWC;XIS\Yq5Ni7OTMuDQ:g+;okX>fO<%`o%g)WQEKb:%Y:5VnP/OemB
)5C.LHULI25,JK,Uf<A;;Hcddks[%t<3DNbg0IA9Ke]H(cC.[8D,'963Mc6VEQd&.
4XpV$W)X>%<*G8Yl9t9>V;?U=fVMJ\Ki+jM:9%;tX]=Lh9;&ZiUXe)3=6g#uXAt:d
<a*aNlU>Ni<N`c2g>-!!KlO7qcFR(\m9T%sH*:69ZV0Qrp>V?bYZ;7N=Bc5ClpZc9
<\DBogDsAV,lpRfY,<s&"(gi;DNJlNJ6312Ao.^FMRIBga#c_(m6jL*"l50gaSfjj
Ks?7'XuTYKeSMA,\T]c?H^BXbDQX/ZCDQImg[nsn'J($0="`VK3.ioYc*iLJ7HV34
Rs"/8EOk[u,2FYjqcmYA]/Pc@6?;O%W!11i&,i<[AjX<e/b->AB#r=<eG,MK5Cb1W
Z.uDAJ)h;h:%rreSMkf9S4hbT(bXpbLspJ81Z6#dRIXb0/SX]rICr"X"/D/pIW3"E
[MWSZ8*6\8YWL7MNZSjBgG=[.dkX>S=ehF%Bm_XY3O;fo9OL3"j,1G;^Y%ir>-)uB
X`5N)#.Gf;f`R0Wp.ib59d=1kUQ:qr6RHbCiao3jH#eUi^orFihZs^q&OQ_PCn/'[
k#P,1#%,MuL<lcO8VL?[Mn6EpknS5GS9'ukcBd;m.+TU>%1AkWpdhMJ<XA$8L&5]K
@n5Q2"/)s*hTH^il<hPue".V>cc819VMu5R*s:c=fm?BIbm/nX-DPNV!P5Zi'q68!
Mb?O10ktpaXYj^m^3XD6@/*'DSNHId:$FdQQ1^`:&iDY+h,tW52SSkh_TmK@cK(:>
Z?5fiA/^pE3d;@\cn;7n33u7lh6hkmHol6ahcoB);hT;:%+D_1EB]BJGcq>?_Y_A.
m\T.I;r[@]HX2PI_]$sck6Y/6UMObl"f<k`"5DH]0(FBF*qI&bj4o[Wn4lQsolf,u
[T>e19h*5"7koj*Rt,C9gW[4H-K^Z,DtD7qcel2niHMNXF2P>Iq?KSqr<Z`dSYl#+
_schq9l9OGn\6`sb2M/TXt9"Bo=DpTEHkQfp/nTBU5(;N%@=;rB?.MD2fV`DID"Qp
e[dR"EplX#\h^uHkr#/3_jr$cpf&j$0@s$2=i8.%hYGkOAhhNA#FbGV/<Kd"Qh+!W
baskD<EL=Si&oo:E.:1<</7+<q('iJX8gf$:P=;[:&_t0Mo.E9hU^PYL[e_CcaCYA
n2rY>Ho;nc4l<<`CeNX(DdfA(':=%kK9phRf=RO[K_Z\lmX:/%b;9I7ae((cr'Fnb
HB_CogEX[OjLSbmF&lrp^ZdN?blLucWqQk[#3N'0lXV(9cNa3+i:^\XI#WC+`B_2X
ReC@S0i(3^:<7ShoQZ2-q=#FN/cNbFAps(E`BpB:/YI@l]R=`]lu%-h:7h=&h"n1Z
:a[Stjm;>p[d*>Pe;`nFN@]5udW0#f!tO,2O5_rcNs*]!pW`?[X?Qe8$uAW<l;/,2
D1:?^W.&\Nqljc1-]6SrRVkil"%Qnp98<!Fmer29I*K\!nBD<"nkfpLs6Xo##?Y=\
&9\5%paoJLV^VQsUi[pTdVkFAVb6b:Ue:#)$jWC57V`8?M[8K`s/rZ\cZ9*r_[2GO
!Tr6T8!OEUfQiQi$.$j(E2NF"isUu%7aOQ6"_/-6Bb?HPrQGuh#Qk_,E6f*C'$Y=O
&G4:g-OOiV'9A+d:k[U.W_tN?AMJ68#Up%?P8%\Y(!P,!LK;*MW]Uh:J^>`oYMLKp
&H@`_@&Oq>7T0k:D\(4Z(ls2I9\-`BW%4"<%PIf;kS!9FcNT'h%`kgEY%7cHd`>9g
$#^1n:4FAGPou,G]Zrdk:..1K?QenZ2Qm\4&>9go+!RM6n#[)Engu(sf-:jC,>[&=
P!k<!aO>$^&?FP&1.NX#AHNJ-"-1>DZ<8Mfn@\$V+`M8onma#0GpJPhQ`5H[cC4.&
ZR<&;/F2MX9;*ahE(Wr-mkP>#nnBO%Ln&LSm\?H$N>j?F\0`toTM+__-#2pgK.F7O
--PMFEl)X56McbT/Fq^AEWlEdR49uOnZn=R;Qh_Dq!dKDPnL1c9><-d#Yh8gUT:.C
Esj^4B"Mi)ngpOjP9`9VLuU8B135.]9E^k1feW.T1ZHWeKJbR75r><E1eq*(b?m*T
=='pNOKsQtZXl#<Nj:7K0L>&lF*0E_GrN'X2tMS[1PD)%6Bt9&A$^qN1R0tAR5qUE
3V/o,.=ilsI-jP23qKU<1UT;c\N?dJX&Gs^[email protected]`.Bbi@RZ/dU4nIVr
1Z^fAkruH@54e;/1\EtHs#^WPjbe1G1^--d#sbj,5kGXS1_i;u)*mJ44=F,jF4EU!
.71Bn6L(U7M2ai$0gi<26hEZ4.Bu63MaN^t7.a>F1fZoDd%I=U7)AAlFB:qRBh#IG
W2o3VZB[lc#tFQ88+_@'.G17!Ln$:qYK;eQBPnp6^IaZU*u(651npC;SP!UX+mFnX
'VLhXVb<t*92qTWe?#$Z^mJ*/9Q[a8oYX7BUJ/%Y86"PC.@!G\LIfmqL@gRpeCpHM
]U>#3:J%*L[)ku5dnQ(]9!kj"<<Z)rZVZn2:mApm'baI[.8[D/:/s#I.sjAMG>@d>
McAq;FIuDEfi5>n;"[UUPg<%q[NZFpLil9goh/<8@o_&f;RKM&'\ub(7opF49m(AS
[=)*+),bU2=S2VpoiG4[2-I:`<%*MsbTBUq5T_ia=1&cFFgXq$F')GS>P2o=23D+.
a\d1$>SVT`e\ta7qcq[p;:U(h<P)P%03f72=Z)aW1auTCWC?IIT%3XC'tm8*eQ=]V
?Id)%ee(`$mp).><`U;M[?"WOG?jhN@MUP)<Td5%@p8RB>o!$C1bW5o5@;s=A@4@(
Q.&W2=&d\7A!Pq]ots\8?X^AX>kH!De`0u%,@.`4B6D6k[Mr`,hc7(@A6+gU<_6I`
gLUc'AQEMY2?dE1*FT^pATfqE[R"Z:@:nNrCDLi$<k2\j]kd<`?.DAU<Ujc]ffQX/
;miMkQ%NjQNGb&;C=_Wc'e*89YABMMC3F6)<i]^'D/^6=Dq>5&2L0._gMs6lVl<O(
_B'fn.<:\;TQJ:XQ"sB$3E4O[CUI;QoZLaQ>>fTZ?roR*'iS!&)-`Ao?<"sFQX+`W
k@iFN@hrKH2c"U@;/t38Wmi/F-uX.8.OZJ:+-^6-MQLlbIsJMo:-no)_>/C$K6\-B
D&8gk2mlBsWHe0LHIo?GQa_?da[B4FHhY^32q<=jc[>J`I@&oA2rpDDh0QPeEgMc8
2t_ZEq1#mPJ+s%p3!FhW$%TMpJG9_-3#.!h)1f:<JbUC?3$j0$.>#&]JX>hT([Z^g
q1AB)KD7`c3(8LF8VFTJK_SDu3)tKQ]75%&K8eW@3+[hhBnj-7LA5bD3-C"$H&&nX
L\QFV3/*05M28[$M"m*h30f>:h1`?2L%kEcR$ihVWJ\3fMYOH7344Zh\Vmu2Mtiim
2l7[aac*aSMtk\Z37X"5fo<MtNVMIliW"khkT>BX~>
EI
Q
PDFVars/TermAll get exec end end
showpage
%%PageTrailer
%%EndPage
%%Trailer
%%DocumentProcessColors: Cyan Magenta Yellow Black
%%EOF
Prev: VxWorks reliable source level debugger Carl Schumann
Next: An Evaluation of EPICS by the LHC J. Frederick Bartlett ([email protected])
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VxWorks reliable source level debugger john sinclair
