| Subject |
Priority |
Categories |
| Define
C++ based client side API |
High |
CAV4-Client-API |
| unlimited
matrix bounds |
High |
CAV4-Process-Entity-Paradigm |
| unlimited
string length |
High |
| allow several PCAS servers
on one machine |
High |
Maintenance |
| Convert old
client/serverto use osi routines |
High |
Maintenance |
| EPICS_CA_ADDR_LIST
specifies port numbers |
High |
Maintenance |
| if possible,
dont allow the server to use the last fd |
High |
Maintenance |
| install
PCAS as the IOC server |
High |
Maintenance |
| abstract
base class for data description in the server API (backwards compatible) |
High |
PCAS |
| thread
safe C++ server library |
High |
PCAS |
| Implement C++ based client side
API |
Normal |
CAV4-Client-API |
| write
logging (subscribe for name of client that is writing etc) |
Normal |
CAV4-Data-Acquisition |
| application
extensible container types (msg passing, cmd compl) |
Normal |
| application extensible PV
attribute set |
Normal |
| directory
serivice resorce location update (detect name space collision) |
Low |
CAV4 Directory Service |
| directory
service asynchronous query (implement client) |
Low |
| directory
service asynchronous query (implement server) |
Low |
| directory
service asynchronous query client side plug in (defne API) |
Low |
| directory
service asynchronous query client side plug in (implement) |
Low |
| directory service
PV location event subscription |
Low |
| directory
service redundancy |
Low |
| directory
service server side update (implement client) |
Low |
| directory
service server side update (implement server) |
Low |
| directory
service server side update plug in (define API) |
Low |
| directory
service server side update plug in (implement) |
Low |
| directory service wild card
queies |
Low |
| directory service wildcard
queries |
Low |
| cancel
asynchronous write (put callback) while in progress |
Low |
CAV4-Client-API |
| export process passive to
client API |
Low |
CAV4-Client-API |
| 2 channels
same name => effective 1 channel in client |
Low |
CAV4-Compression |
| combine event
subscriptions on same PV in client |
Low |
CAV4-Compression |
| move
conversions to client |
Low |
CAV4-Compression |
| protocol
compression (level 1) |
Low |
CAV4-Compression |
| protocol
compression (level 2) |
Low |
CAV4-Compression |
| application extensable event
types |
Low |
| client
adj monitor Q length |
Low |
| client adj
server's dispatch priority and net QOS |
Low |
| client sets event
subscription's min / max rate |
Low |
| client sets server's event
queue length |
Low |
| client specified
analog event subscription deadband |
Low |
| dynamic
evaluation of event trigger criteria in event subscriupton |
Low |
| built in PVs for server
diagnostics |
Low |
| client discovers N
dimensional bounds of matrix |
Low |
| N
dimensional matrix addressing |
Low |
| replace IP broadcast with IP
multicast |
Low |
CAV4-WAN |
| strengthened security
(kerberos SSH tuinnel) |
Low |
CAV4-WAN |
