We occasionary encounter the following error messages on IOC.
CA event: A call to "assert (ev_que->evUser->nDuplicates>=1u)" failed in
../dbEvent.c at 977
Please send a copy of the output from "tt (0xddc5f0)" and a copy of this message
to the author or "[email protected]"
This problem occurred in "@(#)Version R3.13.1.1 $$Date: 1999/05/13
05:35:28 $$"
filename="../taskwd.c" line number=176
task ddc5f0 CA event suspended
-> tt (0xddc5f0)
173f5c vxTaskEntry +60 : event_task ()
1c96778 event_task +100: 1c96928 ()
1c96a68 event_task +3f0: epicsAssert ()
1cb4320 epicsAssert +d4 : taskSuspend ()
value = 0 = 0x0
-> ti (0xddc5f0)
NAME ENTRY TID PRI STATUS PC SP ERRNO
DELAY
CA event event_task ddc5f0 49 SUSPEND+I 16f230 ddc510
0 0
stack: base 0xddc5f0 end 0xddb208 size 4816 high 2840 margin 1976
options: 0xc
VX_DEALLOC_STACK VX_FP_TASK
r0 = 160620c sp = ddc510 r2 = 0 r3 =
0
r4 = fcfbe r5 = 32 r6 = 0 r7 =
3
r8 = 2 r9 = 64 r10 = 1 r11 =
0
r12 = 2 r13 = 0 r14 = 0 r15 =
0
r16 = 0 r17 = 0 r18 = 0 r19 =
0
As you see, this error suspend "CA event" task and noone can open new CA
connection on this IOC, resulting IOC reboot.
In the tech-talk archive, I can find the similar but slightly different
post shown bellow.
> Hi Rosemary,
> I think you must be running the sequencer and
> there may be a problem with it.
> There were several bugs fixed in the sequencer between the
> versions sent out with Beta11 and the one sent out with Beta12
> and there is also a special version that William Lupton at Keck
> is using, so it would be helpful to know which one you have.
> When you first start
> up the sequencer on the ioc by
> typing
> seq &<your sequence program name>
> it should tell you what version you are using.
> In my case I type:
> seq & llrfFillHistory
> and it replies:
> @(#)SNC/SEQ Version 1.9.2.Beta12 : Fri Sep 4 10:42:22 1998
> which means it is Version 1.9.2.Beta12.
> Could you please tell us what Version of the sequencer you are using?
> Thanks,
> Rozelle
> |Rozelle Wright Phone (505) 667-4804 |
> |Los Alamos Natl Labs LANSCE-8 FAX (505) 665-5107 |
> |PO Box 1663 MS-H820 Group Office (505) 667-6087|
> |Los Alamos, NM 87545 email : [email protected] |
> > From [email protected] Mon Oct 5 21:06 MDT 1998
> > Date: Mon, 5 Oct 1998 17:00:47 -1000
> > To: [email protected]
> > Subject: Failure of assert within dbEvet.c
> > Content-Type: text
> > Content-Length: 1095
> > X-Lines: 36
> > Aloha,
> > Any ideas with regard to the below?
> > EV seqAux: A call to "assert (ev_que->evUser->nDuplicates>=1u)" failed in ../dbEvent.c at 1036
> > Please send a copy of the output from "tt (0xb635d8)" and a copy of this message
> > This problem occurred in "@(#)Version R3.13.0.beta.11 $$Date: 1997/07/14 14:04:12 $$"
> > cp_control (ready): offset
> > task: 0Xc7b338 taskwd
> > task b635d8 EV seqAux suspended
> > -> tt (0xb635d8)
> > 2cb98 _vxTaskEntry +c : _event_task (c4e188, a63478, b6ce60, 0, 0, 0)
> > e5367c _event_task +cc : e53858 (a63478, ffffffff, 0, b2000, 4401fc3, 8)
> > e53968 _event_task +3b8: _epicsAssert (e53130, 40c, e53838, 0, e7a208, 4)
> > e6fcd8 _epicsAssert +8c : _taskSuspend (0, e6fc10, e53838, e53130, 40c, &_dtiPixX)
> > value = 0 = 0x0
> > Mahalo,
> > Rosemary Alles
> > Software Engineer
> > Canada France Hawaii Telescope
> > e-mail: <[email protected]>
> > Phone : 808-885-3178
> > Fax : 808-885-7288
Does anyone have any idea to avoid this error ?
Noboru Yamamoto
KEKB control group
KEK, Accelerator Lab.
- R3.13.1 RISC Arch IOC BUG Report (assertion failure in dbEvent.c) Jeff Hill
Re: Channel Archiving Bob Dalesio
Re: Channel Archiving Garrett D. Rinehart
<1999>
2025
2026
Re: Channel Archiving Michael Borland
<1999>
2025
2026
