1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Channel Archiving
To: [email protected]
Cc: [email protected]
Date: Wed, 17 Nov 1999 15:39:57 -0600 (CST)
> Sddslogger, for instance, can be set up to log PVs at a particular data
> rate for a specified time, etc...
sddslogger is a new SDDS tool for EPICS logging.  It uses raw CA instead
of EZCA and supports multiple input and output files.  It will also do
averaging.  Presently, it samples everything at the same rate, but that
could be changed.  It also automatically makes generation files with
the date as part of the filename, which allows the job to run
indefinitely with a new file every day.  We are gradually switching
to sddslogger from sddsmonitor in most archival applications.
sddslogger isn't documented yet but I think the usage message is
more than sufficient for those familiar with sddsmonitor.  You can
get it in the latest release from
http://www.aps.anl.gov/asd/oag/oagPackages.shtml.
You'll need "SDDS1.13.Beta 7" and "SDDSepics1.13 Beta 3".  *Note
that the source code in these releases may be incompatible with prior
releases.* If you have trouble downloading or building these versions,
contact [email protected].
sddssynchlog is also included.  We will try to get these programs
documented shortly.  In the meantime, questions and suggestions
can be emailed directly to me.
Prev: Re: Channel Archiving Bakul Banerjee
Next: capfast symbol for transform and ANL motor record? Paul Stomski
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Channel Archiving Garrett D. Rinehart
Next: assertion failiure in dbEvent.c Noboru Yamamoto
