Hi all,
[the following is fairly long and perhaps tedious,
so here's the executive summary]
I'm working on a data logger which will run on an
ioc, compress channel data in real-time, and stream
it over the network to a spooler. I hope that the
resulting system can be generally useful to other
sites, and so need some small amount of information
and/or comments.
[end executive summary, but there's some more good
stuff at the bottom]
(1) What is the fastest rate at which people want to
log data from an ioc?
(2) How much of this data is there?
My preliminary investigation of how data behaves on
the ioc's here at JLAB indicates that, if we consider
each byte which comprises a signal's value as an
independent quantity, the probability that any particular
one of these will change in a ten minute period ranges
between 0.005 and 0.05 (this is sampling at 1 hz).
Futhermore, when a byte does change, it does so in a
remarkably structured manner (see
http://www.sura.org/~larrieu/Info.html).
>From an information theory standpoint, this means that
(1) the observation that a signal has not changed
carries very little information and can therefore
be conveyed with minimal overhead.
(2) when a byte does change, it will probably change
to one of the predictable values, so this too can
be encoded using very low bit rates.
(3) when a byte changes to an unlikely value, then
we need more bits to indicate such, though this
happens relatively infrequently.
Of course, when you know that a certain byte belongs
to a certain signal, then you know more about its
behavior over time. By monitoring this behavior we
can build a fairly accurate statistical model of it
so that we can further reduce the amount of information
required to indicate a change in value.
The whole point here is that I believe we can achieve
dramatic results by compressing the channel data on the
ioc, then sending the result over the wire to a simple
spooling process.
My intent is to:
(1) implement this logging system
(2) implement a client library for accessing the logged
data, using Kay's C++ API.
(3) build a new data extraction tool using (2)
The benefits should be:
(1) ability to store more information with less data
(2) significantly reduced network traffic
(3) circumvent CA size limit
(4) compatible high-level interface, facilitating
sharing of tools between participating labs.
Trade-offs:
(1) increased memory requirements on ioc
(2) possibly significant CPU time on ioc
(3) increased access time to archived data (decompress)
(4) annoyance: another archiver?!
Chris
Christopher A. Larrieu
Jefferson Laboratory
(757) 269-5097
- RE: Channel Archiving Jeff Hill
- Re: Channel Archiving Bob Dalesio
capfast symbol for transform and ANL motor record? Paul Stomski
Re: capfast symbol for transform and ANL motor record? Rozelle Wright
<1999>
2025
2026
Re: Channel Archiving Bakul Banerjee
<1999>
2025
2026
