> In the source code of medm, I found the following code segment
> in medm/medm/medmCA.c file.
> if (strlen(name) > (size_t)0) {
> status = ca_build_and_connect(name,TYPENOTCONN,0,
> &(pCh->chid),NULL,medmConnectEventCb,pCh);
> } else {
> status = ca_build_and_connect(" ",TYPENOTCONN,0,
Yes, I have noticed. It was that way when I got it. I think it
is a hack to avoid some kind of error, but I don't know what. Perhaps
it is to force CA to allocate the usual structures instead of properly
handling the situation. I haven't changed it on the grounds that (1)
it (up to now) didn't seem to be causing problems and (2) "Never
change a working code ...". It looks like bad coding proctice, and it
would be nice to eliminate it, even if it weren't continually calling
CA as Noboru says.
Unless someone tells me it is a known trick and has a purpose, I
will eliminate it (in the next release).
-Ken
- RE: empty channel field in medm/dm2k Jeff Hill
empty channel field in medm/dm2k Noboru Yamamoto
cvs check out failed. Noboru Yamamoto
<1999>
2025
2026
<1999>
2025
2026
