> > In the source code of medm, I found the following code segment
> > in medm/medm/medmCA.c file.
> > if (strlen(name) > (size_t)0) {
> > status = ca_build_and_connect(name,TYPENOTCONN,0,
> > &(pCh->chid),NULL,medmConnectEventCb,pCh);
> > } else {
> > status = ca_build_and_connect(" ",TYPENOTCONN,0,
> Yes, I have noticed. It was that way when I got it. I think it
> is a hack to avoid some kind of error, but I don't know what. Perhaps
> it is to force CA to allocate the usual structures instead of properly
> handling the situation.
I suspect that the original Author was attempting to circumvent the error
returned from the CA client library when you create a channel with a zero
length name.
Jeff
- Re: empty channel field in medm/dm2k Ken Evans
cvs check out failed. Noboru Yamamoto
Re: empty channel field in medm/dm2k Ben-chin K. Cha
<1999>
2025
2026
<1999>
2025
2026
