1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: empty channel field in medm/dm2k
To: [email protected], [email protected]
Date: Mon, 22 Nov 1999 11:52:12 -0600 (CST)
> > I also use this " " to replace the NULL pvname if the user
> > mistakenly provided a NULL string for name search to an
> > interactive CA client. If I remember it right this will
> > avaoid the problem of core dump and accidentally get
> > out of the interactive CA client.
>   I don't understand: if you're going to test for a zero-
> length string, why even bother making the CA function call
> with name " " when you know it's going to fail?
Sometimes we do want to have some legal 'NULL' string pvname,
e.g. in montitoring variable number of positioner and
detector pvnames in a scan record. It is intentionally as
a NULL string.
Ben-chin
Prev: Re: empty channel field in medm/dm2k Christopher A. Larrieu
Next: EPICS drivers for PLCs? Tony Wilson
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: empty channel field in medm/dm2k Jeff Hill
Next: cvs check out failed. Noboru Yamamoto
