> > Yes, I have noticed. It was that way when I got it. I think it
> > is a hack to avoid some kind of error, but I don't know what. Perhaps
> > it is to force CA to allocate the usual structures instead of properly
> > handling the situation. I haven't changed it on the grounds that (1)
> > it (up to now) didn't seem to be causing problems and (2) "Never
> > change a working code ...". It looks like bad coding proctice, and it
> > would be nice to eliminate it, even if it weren't continually calling
> > CA as Noboru says.
> > Unless someone tells me it is a known trick and has a purpose, I
> > will eliminate it (in the next release).
> I also use this " " to replace the NULL pvname if the user
> mistakenly provided a NULL string for name search to an
> interactive CA client. If I remember it right this will
> avaoid the problem of core dump and accidentally get
> out of the interactive CA client.
I assume that this "core dump" occurs when SEVCHK() is
called and the severity level of the status returned from
CA is higher than a warning. SEVCHK calls abort() in this
situation.
In production code you should check the status from CA
and take appropriate action when the user supplies an
invalid channel name. I assume that appropriate action
in PV wave would be to set a "bad channel" flag in your
code and return bad status back to PV wave applications
when they attempt to read and write to a poorly named
channel.
Jeff
- Re: empty channel field in medm/dm2k Ben-chin K. Cha
EPICS drivers for PLCs? Tony Wilson
Re: EPICS drivers for PLCs? DMW Software
<1999>
2025
2026
Re: empty channel field in medm/dm2k Christopher A. Larrieu
<1999>
2025
2026
