1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: motor record v3.4 - home speed
To: [email protected]
Date: Tue, 23 Nov 1999 10:13:11 +0000 (GMT)
I think there's a problem in the motor record.
( v3.4 under EPICS 3.13.1 )
- the home fwd/rev (HOMR/HOMF) are supposed to 'hit home at 1000 steps per
sec.'
the conversion in motorRecord.c is erronous:
   double hvel = 1000 * fabs(pmr->mres / pmr->eres);
   WRITE_MSG(SET_VELOCITY, &hvel);
where:
  mres = steps size in EGU
  eres = steps / rev
hvel should simply be set to 1000.
I checked by turning on the debuging of the OMS diver, and ended up having
VL values over the allowed maximum (522000 for an OMS-VME8). Hence the slow
speed was not registered and I ended up datuming at 'normal' speed.
otherwise the new INIT/PREM/POST fields are really usefull, great!
un saludo,
   Matthieu
Matthieu Bec                       Isaac Newton Group
tel  : +34 922 425427              Apartado de Correos 321
fax  : +34 922 425429              38780 Santa Cruz de La Palma
url  : www.ing.iac.es/~mdcb        Canary Islands, Spain
Prev: Re: EPICS drivers for PLCs? GongFa Liu
Next: RE: motor record v3.4 - home speed Mark Rivers
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CA Gateway enhancements Ron Chestnut
