1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: motor record v3.4 - home speed
To: [email protected]
Cc: [email protected], [email protected]
Date: Tue, 23 Nov 1999 7:22:14 -0600
> I think there's a problem in the motor record.
> ( v3.4 under EPICS 3.13.1 )
> - the home fwd/rev (HOMR/HOMF) are supposed to 'hit home at 1000 steps per
> sec.'
> the conversion in motorRecord.c is erronous:
>    double hvel = 1000 * fabs(pmr->mres / pmr->eres);
>    WRITE_MSG(SET_VELOCITY, &hvel);
> where:
>   mres = steps size in EGU
>   eres = steps / rev
> hvel should simply be set to 1000.
I think you may misunderstand the meaning of the "eres" field, which you said
equals steps/rev.  eres is the encoder resolution, and has the same units as
"mres".  Thus, in most cases mres/eres is 1 (eres should be set to mres when
there is no encoder present).
However, I agree that there is a problem here.  Hardcoding 1000 steps/second
as the home speed is not the right thing to do - some controllers can home
faster, some must find home slower.  The home speed should be a settable field
Mark Rivers
Re: motor record v3.4 - home speed Ron Sluiter
Prev: motor record v3.4 - home speed Matthieu D.C. Bec
Next: Re: motor record v3.4 - home speed Ron Sluiter
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
