1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA online: A call to "assert (semTake ...
To: Jeff Hill <[email protected]>
Cc: Coles Sibley <[email protected]>, EPICS-tech-talk <[email protected]>
Date: Mon, 13 Dec 1999 08:32:48 -0600
Jeff Hill wrote:
> Hi Coles,
> The symptoms you describe occur when you try to run EPICS R3.13 with the
> SENS IP kernel which is option with vxWorks 5.3 and I suspect mandatory
> with vxWorks 5.4. You can avoid this problem by choosing to _not_ install
> SENs when you install vxWorks 5.3. The API used to query the broadcast
> addresses used for each network interface card changes when using the
> SENS IP kernel, and this causes original versions of CA to fail miserably.
> I have installed a workaround for this problem into 3.14 and could back
> patch 3.13 if there is a strong desire to use SENS with R3.13.
> Jeff
I think it would be a good idea to support SENS on R3.13.
Marty Kraimer
RE: CA online: A call to "assert (semTake ... Jeff Hill
Prev: RE: CA monitors...Update #2 Jeff Hill
Next: Re: CA online: A call to "assert (semTake ... Bob Dalesio
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: CA online: A call to "assert (semTake ... Jeff Hill
