1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problems compiling EPICS
To: [email protected]
Date: Thu, 23 Dec 1999 12:11:54 -0500
Hello,
  We have recently upgraded to solaris and to VxWorks 5.3.  WRS finally
sent the correct key and we installed it withou SENS.  Now were having
problems compiling EPICS.  We get the following errors after running
make clean and make.
make
lots off  stuff
../sdr2recordtype.c:127: warning: `pfldDes' might be used uninitialized
in this function
../sdr2recordtype.c:141: warning: `paprecChoiceNames' might be used
uninitialized in this function
make[4]: Entering directory
`/home/locus/epicsdev/R3.13.1.Vx53/base/src/cvtDctsdr/O.solaris'
/usr/local/bin/gcc -ansi -pedantic -o sf2db -O  -Wall   -DSOLARIS
-DUNIX  -I. -I..   -I../../../include
-I../../../include/os/solaris       -L../../../lib/solaris/
dbStaticLib.o sf2dbYacc.o    -lCom   -lsocket -lnsl  -lm
ld: fatal: file ../../../lib/solaris//libCom.a: unknown type, unable to
process using elf(3E) libraries
ld: fatal: library -lCom: not found
ld: fatal: File processing errors. No output written to sf2db
make[4]: *** [sf2db] Error 1
make[4]: Leaving directory
make[3]: *** [sf2db] Error 2
make[3]: Leaving directory
make[2]: *** [buildInstall.solaris] Error 2
make[2]: Leaving directory
`/home/locus/epicsdev/R3.13.1.Vx53/base/src/cvtDctsdr'
make[1]: *** [cvtDctsdr.buildInstall] Error 2
make[1]: Leaving directory `/home/locus/epicsdev/R3.13.1.Vx53/base/src'
make: *** [src.buildInstall] Error 2
epics>
Any suggestions?
Thanks, Coles
Re: Problems compiling EPICS Lifang Zheng
Prev: RE: New EPICS base release R3.13.2 Jeff Hill
Next: Re: Problems compiling EPICS Lifang Zheng
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: R3.12.2 Release notes Marty Kraimer
