Coles Sibley wrote:
> `/home/locus/epicsdev/R3.13.1.Vx53/base/src/cvtDctsdr/O.solaris'
> /usr/local/bin/gcc -ansi -pedantic -o sf2db -O -Wall -DSOLARIS
> -DUNIX -I. -I.. -I../../../include
> -I../../../include/os/solaris -L../../../lib/solaris/
> dbStaticLib.o sf2dbYacc.o -lCom -lsocket -lnsl -lm
> ld: fatal: file ../../../lib/solaris//libCom.a: unknown type, unable to
> process using elf(3E) libraries
> ld: fatal: library -lCom: not found
> ld: fatal: File processing errors. No output written to sf2db
Hello Coles ,
Two month ago I met the same questions as yours. It's yielded by using ld
in
.../Tornado1.0.1/host/sun4-solaris2/m68k-wrs-vxworks/bin instead of
solaris's ld. Prof.R. Wright helped me to find it. Please check your path
in .profile(bsh) or .cshrc(csh). Use the solaris's ld instead of vxWorks'
ld.
You could also use the commands "file libCom.a", "nm libCom.a" to check?
Good luck,
Lifang
- Problems compiling EPICS Coles Sibley
Re: New EPICS base release R3.13.2 Leonard J. Reder
<1999>
2025
2026
<1999>
2025
2026
