1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS 3.13.2 and vxWorks 5.4
To: "'[email protected]'" <[email protected]>
Date: Wed, 5 Jan 2000 11:02:44 -0600
Jeff,
I'm not sure if this works into the same problems that you have with the
10/100 Ethernet you are using but, when loading the databases I get some
strange messages that look like the ethernet is being reset.
cd startup
value = 0 = 0x0
dbLoadDatabase("../../dbd/daqApp.dbd")
value = 0 = 0x0
dbLoadDatabase("../../dbd/RunfileApp.dbd")
value = 0 = 0x0
dbLoadRecords   ("../../db/roc_slave.db","inst=hrcs2:ROC:,inst2=hrcs1:ROC:")
value = 0 = 0x0
dbLoadRecords("../../db/instsetup.db","USER=hammonds,INST=hrcs2")
value = 0 = 0x0
dbLoadRecords("../../db/hrcs2_tof.db")
interrupt:
ei0: reset
value = 0 = 0x0
note the two lines above the last value statement.  This line usually
appears here but will sometimes occur elsewhere.  This is a fairly good size
database so it's likely that probablity states that I see it here.
John
Prev: RE: EPICS 3.13.2 and vxWorks 5.4 Jeff Hill
Next: Re: alarm handler question William Lupton
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS and Gemini Stephen Goodsell
