1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: alarm handler question
To: [email protected], [email protected]
Cc: [email protected]
Date: Wed, 5 Jan 2000 08:53:43 -1000
Janet Anderson wrote:
>Maybe we could allow the operator to enable/disable force pvs.
>We could add a ForcePV Button to each alarm group or channel line
>for which a Force PV is defined ( similar to the Guidance and Related
>Process buttons). Pressing this button would bring up the ForcePV Dialog
>window which allows the operator to view/change the ForcePV settings.
>This dialog could be modified to allow the operator to enable/disable
>the ForcePV.  The color of the button could also indicate the enabled/disabled
>status.
That sounds good. My only reservation is that this forces the concept of
FORCEPV to be visible to the operator, whereas, as I understand it, FORCEPV
is intended to be a hidden mechanism which "magically" avoids alarms when
other aspects of the system state indicate that the alarm is not real.
Do people have objections to my two proposals of yesterday, namely
a) allow the FORCEPV reset mask to honor any operator overrides,
b) allow the FORCEPV logic to check for transitions to the force or
   reset values
>From my point of view, these seem to address the problem at source. Really,
I think you could almost view them as bug fixes.
William
Re: alarm handler question Sue Witherspoon
Re: alarm handler question Janet Anderson
Prev: RE: EPICS 3.13.2 and vxWorks 5.4 Hammonds, John
Next: Re: alarm handler question Sue Witherspoon
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: alarm handler question Janet Anderson
