Dear all,
We realized yesterday that the VxWorks global variable device support
does not support selection of an individual bit (for bi/bo) or a range
of bits (for mbbi/mbbo) from the underlying global variable. Device
support for bi/bo simply copies a 'short' into .VAL and for mbbi/mbbo
copies a 'long'.
This hasn't been in an issue for us in past applications but now we have
a case where a device is mapping extensive data structures, including
some words where we would like to map individual bits on to bi/bo or
ranges of bits on to mbbi/mbbo, into VxWorks memory. We would like to
use the global variable device support to access these data structures.
Here is a proposal:
1. extend the VxWorks global variable device support (INST_IO version) so
the link string, which is currently of the form
[ "*" ] name [ "[" index "]" ]
is of the form
[ "*" ] name [ "[" index "]" ] [ keyword "=" value ] ...
where the keyword/value pairs carry extra configuration information
2. keyword names would be case-independent and abbreviable (ambiguous
abbreviations would refer to that keyword which was first supported;
this guarantees backwards compatibility); initially, two keywords
would be supported
name value default
start bit number of lsb (0-31) -1
type type of underlying var. as at present (*)
"start" specifies the same information that the "S" field does (by
convention) for VME_IO; the default of -1 means that the entire
variable is copied (as at present; needed for backwards compatibility)
"type" specifies the type of the underlying global variable; currently
this is implied by the record type; it would be particularly useful to
be able to specify that a bi/bo comes from a long, which is not possible
at present; the type names are the C names (with no support for "unsigned")
and are case-independent and abbreviable
3. white space is permitted everywhere (and is ignored, as at present)
4. note that bo/mbbo support may (strictly) require use of a semaphore to
cover the case where several records which access the same word are
processing concurrently (I recall an earlier discussion that resulted
in the use of intLock()/intUnlock(); one could add taskLock()/taskUnlock()
instead of a semaphore?)
Here are some examples:
assume that ssss is a 'short' global variable whose value is 0x1234 and
llll is a 'long' global variable whose value is 0x12345678
1. bi: ssss s=4
VAL field is set to ssss's bit 4 (1)
2. bi: llll s=31 t=long
VAL field is set to llll's bit 31 (0)
3. mbbo: ssss s=8 t=short
NOBT bits of ssss, starting at bit 8, are set to VAL (VAL masked to NOBT
bits and shifted left by 8 bits)
Comments?
William
- Re: VxWorks global variable support extension proposal Carl Lionberger
- Re: VxWorks global variable support extension proposal Andrew Johnson
DL-PC board question john sinclair
RE: DL-PC board question Jeff Hill
<2000>
2025
<2000>
2025
