1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VxWorks global variable support extension proposal
To: William Lupton <[email protected]>
Cc: [email protected]
Date: Thu, 13 Jan 2000 17:58:50 -0600
William,
I agree this would be a good idea, although I'm not totally convinced
about the 'keyword=value' part.
When (or given current progress *if*) link support and the associated
device addressing changes gets implemented, addresses will be simpler to
convert if they're in the format typename(arg1, arg2, arg3, ...) where
arguments can be empty or terminal args omitted to default them.  You will
be able to use and parse string arguments yourself, but they then become
opaque to the higher level software.  Given the current vapourware status
of link support though you might want to ignore this completely for now.
In any case there's an unbundled version of the symbol support (partially
conveted for R3.14 though so it uses configure instead of config) in
$CVSROOT/epics/modules/soft/symb.  Please do any development here rather
than in $CVSROOT/epics/base.  These files have their old CVS version
history available in their new location.
- Andrew
Complexity comes for free, Simplicity you have to work for.
VxWorks global variable support extension proposal William Lupton
Prev: RE: epics on x86 Jeff Hill
Next: RE: NULL record Name on IOC Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VxWorks global variable support extension proposal Carl Lionberger
Next: Monitors for the STAT field Benjamin Franksen
