John,
This is a symptom off EPICS R3.13's incompatibility with
the new SENS IP kernel from WRS. You can also install the
original IP kernel from WRS. This is frequently the default.
Jeff
> -----Original Message-----
> From: john sinclair [mailto:[email protected]]
> Sent: Wednesday, January 12, 2000 2:12 PM
> To: tech talk
> Subject: epics on x86
> I recently did a fresh install of tornado 1.0.1 (vxw 5.3.1) on solaris
> 5.7. I do not have sens installed. Here is my setup file:
> 05-Jan-00.13:06 TDK-12217-ZC-08 SETUP-1.5
> 05-Jan-00.13:06 100-8827-30 Tornado Cumulative Patch Rev 1: i86
> 05-Jan-00.13:06 100-6808-30 Tornado Object: solaris x i86
> 05-Jan-00.13:15 TDK-12217-ZC-08 SETUP-1.5
> 05-Jan-00.13:15 100-7009-30 VxWorks BSP: pc486
> 10-Jan-00.17:24 Individual Patch for SPR 21254 SETUP-1.5
> 10-Jan-00.17:24 100-10860-30 Tornado 1.0.1: solaris patch SPR 21254
> When the ioc runs iocInit, it does this:
> IocLogClient: EPICS environment variable "EPICS_IOC_LOG_INET" undefined
> iocLogClient: logging disabled
> ### @(#)EPICS IOC CORE
> ### @(#)Version R3.13.1..0 $$Date: 1998/11/19 16:18:25 $$
> Starting iocInit
> ioctl SIOCGIFCONF failed: errno = 0x6
> Failed to set time from Unix server
> CAC: SIOCGIFCONF ioctl failed because "errno = 0x6"
> value = 0 = 0x0
> iocInit: All initialization complete
> CA online: A call to "assert (semTake(client_lock, WAIT_FOREVER)==OK)"
> failed in ../access.c at 3089
> Please send a copy of the output from "tt (0x1f89668)" and a copy of this
> message
> to the author or "[email protected]"
> This problem occurred in "@(#)Version R3.13.1..0 $$Date: 1998/11/19
> 16:18:25 $$"
> #seq &snctest
> -> filename="../taskwd.c" line number=175
> task 1f89668 CA online suspended
> tt (0x1f89668) gives the following:
> 154036 _vxTaskEntry +a : 3503fc (0, 0, 0, 0, 0, 0, 0, 0, 0, 0)
> 350488 _rsrv_online_notify_task+190: _caSetupBCastAddrList
> (&_beaconAddrList, 10, 13c9)
> 362e55 _caSetupBCastAddrList+bd : _genLocalExcepWFL ([188, 0, 361fd0,
> 2fb, 1f89618])
> 36a526 _genLocalExcepWFL+86 : _epicsAssert (366124, c11, 3660fd, 0)
> 35eade _epicsAssert +8e : _taskSuspend ([1f89668, 2fb, 0, 361fd0,
> 1f89598])
> value = 0 = 0x0
> Everything else seems to work. Any ideas?
> John Sinclair
> [email protected]
> Oak Ridge National Lab
> 865-576-6362 865-574-1268 (fax)
- epics on x86 john sinclair
Re: VxWorks global variable support extension proposal Carl Lionberger
Re: VxWorks global variable support extension proposal Andrew Johnson
<2000>
2025
2026
Re: epics on x86 john sinclair
<2000>
2025
2026
