1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Data Fanouts
To: tech-talk <[email protected]>
Date: Fri, 21 Jan 2000 14:05:49 -0500
Hi All:
According to the Record Reference Manual, a Fanout record which supports six
output links, can be chained with one or more additional Fanout records in order
to increase the number of output links available. For example, two Fanouts
records chained together can propagate 11 outputs (one output from the first
record links to the input of the second).
The Data Fanout record is "similar" to the Fanout. Where as the Fanout record
only supports control links (i.e. no data is passed), the Data Fanout propagates
control AND data. A Data Fanout record supports eight output links. Can the Data
Fanout record also be chained, like the Fanout? If so, could someone explain
how? I have tried every permutation I can thank of, linking various types of
records with the Data Fanout, to no avail.
My needs are a Data Fanout of 16 outputs from a single Binary Output. I have
successfully used a single Data Fanout with all eight outputs.
Thanks
Russ
begin:vcard
adr;dom:;;P.O. Box 846;Middleton;MA;01949;
n:Page;Russell
x-mozilla-html:FALSE
org:MIT -- Bates Linear Accelerator Center
version:2.1
email;internet:[email protected]
title:SW Engineer / Controls & Instrumentation
tel;fax:(617)  253-9799
tel;home:(978)  682-1964
tel;work:(617)  253-9585
x-mozilla-cpt:;0
fn:Page, Russell
end:vcard
Prev: Re: alh CA Disconnects Marty Kraimer
Next: Re: Data Fanouts Ned Arnold
Index: 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: event_handler_args Jeff Hill
