1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Data Fanouts
To: [email protected], [email protected]
Date: Fri, 21 Jan 2000 13:07:58 -0600 (CST)
I have never used the data fanout, so I don't know about it. For the
requirement you described I would use two sequence (seq) records (each
has ten output links with a unique data source link (DOLn) for each).
Make all the data source links (DOLn) indentical and it becomes a data fanout.
	Ned
> Hi All:
> According to the Record Reference Manual, a Fanout record which supports six
> output links, can be chained with one or more additional Fanout records in
order
> to increase the number of output links available. For example, two Fanouts
> records chained together can propagate 11 outputs (one output from the first
> record links to the input of the second).
> The Data Fanout record is "similar" to the Fanout. Where as the Fanout record
> only supports control links (i.e. no data is passed), the Data Fanout
propagates
> control AND data. A Data Fanout record supports eight output links. Can the
Data
> Fanout record also be chained, like the Fanout? If so, could someone explain
> how? I have tried every permutation I can thank of, linking various types of
> records with the Data Fanout, to no avail.
> My needs are a Data Fanout of 16 outputs from a single Binary Output. I have
> successfully used a single Data Fanout with all eight outputs.
> Thanks
> Russ
Re: Data Fanouts Maren Purves
Prev: Data Fanouts Russell Page
Next: Re: Data Fanouts Maren Purves
Index: 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
