1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: using vxWorks td() to shutdown CA clients and sequence tasks
To: "EPICS-tech-talk" <[email protected]>
Cc: "William Lupton" <[email protected]>, "Rozelle Wright" <[email protected]>
Date: Mon, 24 Jan 2000 14:05:04 -0700
All,
Proposed impact:
1) All vxWorks EPICS users must, starting with EPICS R3.14,
avoid deleting CA related tasks (threads) with "td() and
"taskDelete()".
2) Sequence programs will be shut down with some as-of-yet
unwritten subroutine (vxWorks command line) provided by
the sequencer facility. Other facilities based on the CA
client library and also vxWorks might need to implement
similar capabilities.
If this sort of thing has an impact on you, then please
read on.
At some point in the past we went to great lengths to
ensure that the sequencer and the CA client library
would gracefully shutdown if on vxWorks, out of the
blue, one of the CA client's tasks (threads) was abruptly
deleted by any user using vxWorks shell commands such as
"td()" or "taskDelete()". We provided support for this
probably because at the time users were used to "kill"ing
UNIX processes, and they naturally assumed that directly
deleting tasks (threads) should be possible also.
We are now porting iocCore to other multi-threaded
operating systems, and this feature is particularly
difficult and error prone to implement on all operating
systems. We now see that it would have been much easier
to implement a special command in the sequencer for deleting
one or all of its sequence program(s).
So I propose that we remove the thread deletion cleanup
handler from the CA client library, and in the
future (starting with release 3.14) all vxWorks client
tool applications must implement a graceful shutdown
at the client tool application level which calls
ca_task_exit(), and that users will need to be more
careful about directly deleting threads with the operating
system in the future. If they are not careful they may
crash their IOC.
Jeff
______________________________________________
Jeffrey O. Hill         E-mail [email protected]
LANL MS H820            Voice  505 665 1831
Los Alamos NM 87545 USA FAX    505 665 5107
Re: using vxWorks td() to shutdown CA clients and sequence tasks Chip Watson
Prev: Re: Python/CA Noboru Yamamoto
Next: Re: using vxWorks td() to shutdown CA clients and sequence tasks Chip Watson
Index: 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Python/CA Jeff Hill
