1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Need up-to-date documentation for SCAN record
To: Tim Mooney <[email protected]>
Cc: [email protected]
Date: Thu, 27 Jan 2000 19:37:44 -0500
> Actually, most of the changes made in '95/'96 were in implementation of
> existing features, and the Record Reference Manual still serves pretty
> well with some exceptions: positioner readback arrays (PnRA), positioner
> after-scan mode (PASM), positioner absolute/relative (PnAR), and some new
> options for the CMND field are not in the Record Reference Manual.  For
> these fields, the best available doc is still in the source code.
best == only
Finding all the places and ways that Relative Mode (which should be a simple
concept) affects operation from reading the code is non-trivial.
What does PREVIEW (CMND = 2) do ?
How to know the distinctions between
	scanPASM_Start_Pos (REC_SCAN_AS_ST)
and
	scanPASM_Prior_Pos (REC_SCAN_AS_BS)
as the PnPP fields are not documented ?
Also undocumented :
       Before/After Scan PVs/CMDs (looks very useful)
       DPT
       PnPP
       PnCV
       DnNE
Brian McAllister                 Application Programmer/Beam Physicist
[email protected]                        MIT-Bates Linear Accelerator
Re: Need up-to-date documentation for SCAN record Tim Mooney
Prev: Re: Need up-to-date documentation for SCAN record Tim Mooney
Next: Re: Need up-to-date documentation for SCAN record Leo R. Dalesio
Index: 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Need up-to-date documentation for SCAN record Ned Arnold
