1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Need up-to-date documentation for SCAN record
To: [email protected], [email protected]
Date: Fri, 28 Jan 2000 08:26:17 -0600 (CST)
Yes, sometimes the documentation does not keep up with the code evolution.
Attached are a few medm displays (to Brian) that contain a sample of almost
all the fields in the scan record (Version 3.13) . It basically is a "scan
control panel" that allows a scan to be configured interactively. Although
I don't view this as "documentation", it does help to convey most of the
functionality.
If you have specific questions, let me know.
Also, I have to tattle on Tim Mooney (since he didn't say anything). The
reason the SCAN record in base has not had any edits since 1996 is
because Tim has been evolving the SCAN record in his synApps area. He has
improved it greatly (I think it now supports 70 detectors !) Probably the
biggest change is that he now uses put-callbacks for the positioners
and detectors, so there is no need for WAIT records to figure out when
positioners/detectors are done (the callbacks don't occur until motors are
stopped or detectors are done). This has shown to be a much more flexible
approach. Contact Tim for details (sorry, Tim).
	Ned
> Where can I find documentation on the current version of the SCAN record ?
> Why does the latest (1998) version of the Record Reference Manual seem to
> reflect the state of the software circa 1994, and not any of the (significant)
> changes made in 1995-1996 ?
> Brian McAllister                 Application Programmer/Beam Physicist
> [email protected]                        MIT-Bates Linear Accelerator
Prev: Re: Need up-to-date documentation for SCAN record Leo R. Dalesio
Next: Re: Need up-to-date documentation for SCAN record Leo R. Dalesio
Index: 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Need up-to-date documentation for SCAN record Brian McAllister
Next: Re: Need up-to-date documentation for SCAN record Tim Mooney
