1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: VxWorks global variable device support
To: [email protected]
Date: Mon, 31 Jan 2000 11:34:43 -1000
Dear all,
  Another change that I made to the VxWorks global variable device support
was to read the global variable at record initialization time and use it to
initialize the value of the record.
  This is not backwards-compatible and may not, I suspect, always be
desireable (indeed I fell foul of it myself this morning where I had
a longout with a constant in its DOL and expected that to be the value
output... it wasn't, because the .VAL field was initialized from the global
variable, and that had a different value).
  So I propose making this behavior configurable, with the default being
the backwards compatible behavior (i.e. don't read the global variable at
init time). I propose supporting an abbreviable "initread" keyword in the
OUT specification to control this behavior.
  Comments?
  William
Re: VxWorks global variable device support Ralph . Lange
Prev: January 6-10 meetings at Los Alamos Leo R. Dalesio
Next: January Notes for non-us individuals. Leo R. Dalesio
Index: 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: VxWorks global variable device support Ralph . Lange
