1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: January 6-10 meetings at Los Alamos
To: <[email protected]>
Date: Mon, 31 Jan 2000 13:30:45 -0800
Hello All,
    We had a small group get together to discuss the future direction of archiving, the requirements for high level applications, and the way that Channel Access could evolve to support high level applications. The meeting notes, as well as a task list are attached. If you find that there are some high level application requirements that are missing, you may want to take a little time and send them. We believe that if we are successful in encapsulating the communication requirements for high level applications, we will be able to produce clients that can use any data on the network and produce results that can then be served to any other client. This should give us a tremendous amount of flexibility in developing high level applications.
    Best Wishes,
    Bob
Attachment: Jan00mtgnotes.doc
Description: MS-Word document
Attachment: cav4 (1).xls
Description: MS-Excel spreadsheet
Prev: Re: Need up-to-date documentation for SCAN record Tim Mooney
Next: VxWorks global variable device support William Lupton
Index: 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
