1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: unbundled sequencer v1.9.4 is available
To: [email protected], [email protected]
Date: Thu, 3 Feb 2000 07:57:10 -0700 (MST)
> This version of the sequencer is in operational use at SLAC (the operational
> version at Keck pre-dates the SLAC extensions). The only known problem is
> that "td" does not reliably delete sequencers.
Hi William,
Have you added a snl specific command that will delete sequencers.
We really need to be able to delete sequences without bringing iocs down.
One of the main advantages of using the sequencer is that you can
debug it without rebooting the ioc, in contrast to debugging databases.
With the sequencer I am currently using I can try out something delete,
try out something else delete, etc. until the sequence works.
When I tried your new sequencer most recently the ioc stopped
responding as soon as I killed the sequence.
Rozelle
> William
Prev: Re: VxWorks global variable device support Ralph . Lange
Next: RE: Python/CA Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: unbundled sequencer v1.9.4 is available William Lupton
Next: Re: unbundled sequencer v1.9.4 is available William Lupton
