1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VxWorks global variable device support (boRecord.c)
To: [email protected]
Date: Sat, 05 Feb 2000 00:52:22 +0100
[email protected] wrote:
> Hello -
> Since we're on the subject of save/restore, there is a little problem
> with boRecord.c that forces us to restore soft BOs differently from
> soft AOs.  For both record types, we set DOL to blank (these are soft records
> and are used for storing constants and user inputs).  We then use use static
> db restore in initHooks.c before record initialization to restore VALs from
> file.  I need to set PINI to YES on the soft BOs in order to get the proper
> severity to drive the color on some displays (usually RED if OFF and GREEN if
> ON).  However, for a soft BO with a blank DOL, process won't reset the udf flag
> to true and the severity is INVALID until somebody does a ca put to change
> VAL.  So I'm forced to restore soft BOs with channel access after initHooks
> is done.  I don't have the problem with soft AOs since process (convert, really)
> will always set udf to false no matter what.
> Could the process function of the boRecord.c be changed:
>                 /* convert val to rval */
>                 if ( pbo->mask != 0 ) {
>                         if(pbo->val==0) pbo->rval = 0;
>                         else pbo->rval = pbo->mask;
>                 } else pbo->rval = (unsigned long)pbo->val;
> >>>add this>>>  pbo->udf = FALSE;
IMHO it would not be correct to do this. Setting UDF to FALSE should
only be done if the value is defined. This is not the case if DOL is
undefined, at least as long as we are not shure that some kind of
readback actually happened.
We need a way to tell if readback at init time actually happened or not.
At the moment, only the code that does the readback knows this. So, in
your case, the right place to put the UDF=FALSE is in the code that sets
the RVAL or VAL (i.e. the db restore code that is called from the
initHook).
Things would be different if the readback would be initiated by the
record support.
Ben
The Notorious Neb Nesknarf
Re: VxWorks global variable device support (boRecord.c) saa
Prev: support for output records Leo R. Dalesio
Next: Re: support for output records Bernd Schoeneburg
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VxWorks global variable device support (boRecord.c) saa
Next: Re: support for output records Benjamin Franksen
