1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: support for output records
To: [email protected]
Date: Sat, 05 Feb 2000 19:46:00 +0100
Hi all,
Bob wrote:
> This affects bo, mbbo, mbbo-direct, longout, and ao.
> Does it relate to steppermotors?
> Does it relate to algorithmic records with OUT fields?
> I think it only relates to output records with device support. I also think
> that we could omit the case for steppermotors (even though I said it would
> be nice to be consistent.....)
> What else does this need to turn into an action item?
Reading back the hardware value into the out records is useful independent
of the DOL being empty or not, I think.
If the output record run in scan and get its value from an algorithmic record
using the DOL inlink, the algorithmic record needs to set its out value after
the readback in the out record.
Principally more steps are possible. If there would be a RINI (read init)
field, like Deb Kerstiens proposed, and a P H A S E for this action, it
would be possible to do inits in reverse order in these chains.
Bernd
RE: VxWorks global variable device support Jeff Hill
support for output records Leo R. Dalesio
Prev: Re: VxWorks global variable device support (boRecord.c) Benjamin Franksen
Next: Re: support for output records Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: support for output records Leo R. Dalesio
Next: Re: VxWorks global variable device support Deb Kerstiens
