1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: IOC Errors when StripTool is Running
To: [email protected]
Cc: [email protected]
Date: Tue, 15 Feb 2000 14:55:02 -0500
Chris, can you give us help with apparent problems we are having with
StripTool?
>From a message I got from a colleague of mine (Delphy Nypaver):
"I ran a test this morning and it appears that it is the StripTool that is
causing the memory problem. Every time I run it I get those errors on the
ioc. My theory is that the reason rebooting the Sun caused the problem to
go away is because it killed the StripTool program when it rebooted."
>From a previous message Delphy sent documenting the error messages she gets:
"Attached are the intermittent memory errors we are getting on the ioc. I
would think some of your contacts in the EPICS community would be able to
tell us what these mean, if not what's causing them."
iocA~> 0x1fa2d4 (CA TCP): memPartAlloc: block too big - 11412 in partition
0xafae8.
0x1fa2d4 (CA TCP): CAS: task creation for new client failed because
"S_memLib_NOT_ENOUGH_MEMORY"
0xf0cc4 (CA client): memPartAlloc: block too big - 25072 in partition
0xafae8.
0xf0cc4 (CA client): CAS: unable to init the event facility
0xafae8.
iocA~> 0xf0cc4 (CA client): memPartAlloc: block too big - 25072 in
partition 0xafae8.
0xafae8.
0xafae8.
iocA~>
iocA~>
0xafae8.
0xf2bd0 (CA client): memPartAlloc: block too big - 25072 in partition
0xafae8.
0xf2bd0 (CA client): CAS: unable to init the event facility
Have we possibly overlooked something in how we use StripTool?
Again, from one of Delphy's messages:
"There didn't seem to be a relation with the alarm handler, but I'll keep
checking. Error messages also print on the Sun about invalid channels that
aren't invalid unless the StripTool is running."
Any help here with understanding better how channel access works will also
be appreciated.
John K. Munro, Jr., PhD					Voice: (423) 574-0635
Development Staff							Pager: (423) 417-6585
Instrumentation and Controls Division		FAX: (423) 576-8380
Oak Ridge National Laboratory				Email: [email protected]
Bldg. 3500, MS 6010, PO Box 2008
Bethel Valley Road
Oak Ridge, TN 37831-6010
RE: IOC Errors when StripTool is Running Jeff Hill
Prev: Access Fault Dennis M. Reichhold
Next: Fwd: alh correction John K Munro Jr
Index: 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Access Fault Jeff Hill
Next: RE: IOC Errors when StripTool is Running Jeff Hill
