1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: IOC Errors when StripTool is Running
To: "John K Munro Jr" <[email protected]>, <[email protected]>
Cc: <[email protected]>
Date: Tue, 15 Feb 2000 14:25:40 -0700
> "Attached are the intermittent memory errors we are getting on the ioc. I
> would think some of your contacts in the EPICS community would be able to
> tell us what these mean, if not what's causing them."
> 0x1fa2d4 (CA TCP): CAS: task creation for new client failed because
> "S_memLib_NOT_ENOUGH_MEMORY"
These error messages certainly indicate that the IOC has insufficient space
in
memory to allow a new client to attach. This is probably because the total
client initiated load is too high, but could also be caused by other
problems
such as a memory leaking program, a large database, or corruption
of pool. It is possible that one client is creating a disproportionate load.
To find out if this is the case type "casr <interest level>" on the IOC.
Jeff
> 0xf0cc4 (CA client): memPartAlloc: block too big - 25072 in partition
> 0xafae8.
> 0xf0cc4 (CA client): CAS: unable to init the event facility
> iocA~> 0x1fa2d4 (CA TCP): memPartAlloc: block too big - 11412 in partition
> 0xafae8.
> iocA~> 0xf0cc4 (CA client): memPartAlloc: block too big - 25072 in
> partition 0xafae8.
> 0xafae8.
> 0xafae8.
> iocA~>
> iocA~>
> 0xafae8.
> 0xf2bd0 (CA client): memPartAlloc: block too big - 25072 in partition
> 0xafae8.
> 0xf2bd0 (CA client): CAS: unable to init the event facility
> Have we possibly overlooked something in how we use StripTool?
> Again, from one of Delphy's messages:
> "There didn't seem to be a relation with the alarm handler, but I'll keep
> checking. Error messages also print on the Sun about invalid
> channels that
> aren't invalid unless the StripTool is running."
> Any help here with understanding better how channel access works will also
> be appreciated.
> Regards,
> John K. Munro, Jr., PhD
> Voice: (423) 574-0635
> Development Staff
> Pager: (423) 417-6585
> Instrumentation and Controls Division		FAX: (423) 576-8380
> Oak Ridge National Laboratory				Email: [email protected]
> Bldg. 3500, MS 6010, PO Box 2008
> Bethel Valley Road
> Oak Ridge, TN 37831-6010
Re: IOC Errors when StripTool is Running Christopher A. Larrieu
IOC Errors when StripTool is Running John K Munro Jr
Prev: Re: Fwd: alh correction Maren Purves
Next: Improving S/N on tech-talk Harvey Rarback
Index: 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: IOC Errors when StripTool is Running John K Munro Jr
Next: Re: IOC Errors when StripTool is Running Christopher A. Larrieu
