It was it. In fact I tried that casPV::bestExternalType () and it didn't
work as it suppose to.
And reason for that was that this function must be defined as const, and in
my case it wasn't, so it
wasn't overloaded properly. May be it will be interesting for others ..
Vladimir
----- Original Message -----
To: Vladimir Sirotenko <[email protected]>; <[email protected]>
Sent: Wednesday, February 23, 2000 11:54 AM
Subject: RE: native type of gdd object
> Vladimir,
> > Could someone advise me please how to control the native type of PV
created
> > in portable CA server
> > with use of gdd library ( pVV = new gddScalar(gddAppType_value,
> > aitEnumFloat32); )
> > I mean native type which can be asked using ca_field_type() function ..
> > I have two servers running with the same PV creation, but one gives
native
> > type = 2 (float) and
> > another gives 0 (string). Is there any way to change native type from 0
to
> > 2, for example? Thanks,
> The virtual function "casPV::bestExternalType ()" determines the native
data type
> as seen by the client application. The base implementation of this virtual
> function returns type string, but you can override this behavior by
implementing a
> replacement in your derived class.
> Jeff
- RE: native type of gdd object Jeff Hill
Switching from a 167 to a 162 Dennis M. Reichhold
Re: Switching from a 167 to a 162 Andrew Johnson
<2000>
2025
2026
Re: native type of gdd object Kay Kasemir
<2000>
2025
2026
