1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: SUMMARY: Re: vxworks statistics
To: Geoff Savage <[email protected]>
Date: Thu, 24 Feb 2000 07:28:59 -0600
Geoff Savage wrote:
> Here's what I found to resolve this problem.
> Somehow the INST_IO field in the device declaration had been changed to
> VME_IO for devAiVXStats and devAoVXStats in base.dbd.
Please note that this is documented in the release notes. The change occured
between 3.13.0beta11 and 3.13.0beta12. The notes state:
devVXStats
Major rewrite of this routine. It computes the cpu usage via a low priority task
rather than using spy. It reports file descriptor usage rather
than tcp connections (this is what is actually measures). The format of the INP
,and OUT fields has changed since the previous version.  The
new device definitions are:
    device(ai,INST_IO,devAiVXStats,"VX stats")
    device(ao,INST_IO,devAoVXStats,"VX stats")
The INP fields now have the form
    field(INP,"@memory")
    field(INP,"@cpu")
    field(INP,"@fd")
The OUT fields now have the form
    field(OUT,"@memoryScanPeriod")
    field(OUT,"@fdScanPeriod")
    field(OUT,"@cpuScanPeriod")
The source file has comments showing a sample database.
Marty Kraimer
vxworks statistics Geoff Savage
SUMMARY: Re: vxworks statistics Geoff Savage
Prev: SUMMARY: Re: vxworks statistics Geoff Savage
Next: Re: eddCvrt1.16To2.2 Deb Kerstiens
Index: 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: imageRecord Leonard J. Reder
