1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: imageRecord
To: Ned Arnold <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Thu, 24 Feb 2000 09:54:49 -0800
Ned,
I now have a modified version of your image record working and async
device support for my DataCell board grabbing frames.  I am going to
attempt to use the genSub record to connect a subroutine now.  Do you
have any example code that shows an implementation of what you discussed
below.
Len
Ned Arnold wrote:
> Hey Len,
> > Thanks for the reply,
> > A couple of quick questions:
> > What was the intended purpose of the enab and rate fields?
> These were implemented as safe guards to "throttle" the transferring of
> the entire image to a client. In my application, the client will fetch
> the image whenever the VAL field of the image record changes (increments).
> So, if ENAB (enable) is set to 0, the VAL field will not increment even if
> something processes the image record. One would set ENAB to 0 if the image is
> known to be invalid (maybe the camera is off!).
> The RATE field sets a minimum time between increments of the VAL field.
> If the image record scans at 10 Hz (because of a database flub up) and
> RATE is set to .49, the VAL field will only increment at 2 hertz, thereby
> "throttling" the client's fetching of an image. Set RATE to 0 for
> no throttling.
> Both of these are a result of my paranoia of swamping the network with
> image data. Ignore them if you don't have the same fears.
> > I understand the vxnm now and I actually have two different versions
> > of your record code.  If I add pimg field as you suggest is this just
> > another DBLINK or how do I specify it in the ImageRecord.dbd file?
> Marty Kraimer had a better idea than "exporting" the pointer through
> a record field. Your subroutine can find out all the information it
> needs about .L0 (the pointer to the first pixel) by using the database
> access routines described in Chapter 12 of the EPICS IOC Application
> Developer's Guide. Specifically, if you call dbGetPdbAddrFromLink(for INPn)
> (Pg 138) from your subroutine record, you get all the "dbAddr" information
> described on pg 129, including the address of the field. This would allow
> you to find the image without passing any of the image data around. I
> agree that this is probably the best way to meet your need.
> For example, if the subroutine record had input links defined for ...
> INPA   image_record_1.L0
> INPB   image_record_1.XRES
> INPC   image_record_1.YRES
> INPD   image_record_1.SIZE
> your analysis routine could find out all the information about the image
> without duplicating any definition of it.
> Hope this helps ...
>         Ned
____________________________________________________
Leonard J. Reder
Jet Propulsion Laboratory
Interferometry Systems and Technology Section 383
Email: [email protected]
Phone (Voice): 818-354-3639
Prev: Re: eddCvrt1.16To2.2 Deb Kerstiens
Next: Re: Switching from a 167 to a 162 Garrett D. Rinehart
Index: 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: SUMMARY: Re: vxworks statistics Marty Kraimer
Next: in search of: high current binary output device pate
