1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: VXI Kinetic Systems V151 cpu - PowerPC
To: [email protected]
Date: Tue, 07 Mar 2000 14:01:19 -0800 (PST)
I'm trying to bring up an exiting EPICS application
on a PowerPC (Kinetic Systems V151 VXI)
running EPICS R3.13.2 and vxWorks 5.3.1
The existing software has been successully running
on an niCpu030 under EPICS R3.13.1 and vxWorks 5.3.1
for quite awhile.
I've run into a number issues with this PowerPC (VXI module):
1) missing lib vix functions such as SetMODID
2) missing or renamed unsolicited interrupt handlers
   excStub and excIntStub.
  (from  devlib.c defaultHandlerNames[])
3) Is anything else tobe used in place of intHandlerCreate()
   for powerPC...or is this handled in some other way?
4) sysBusTas() seems to be different for the PowerPC but
   I can't find out what the difference is in the WindRiver
   manuals. Does anyone know how this function differs for the
   PPC?  When calling sysBusTas() from the allenBradley driver
   the following occurs:
SC_LOCK: calling sysBusTas  0xfcc0011d
alignment
Exception current instruction address: 0x0016f1a8
Machine Status Register: 0x0000b130
Data Access Register: 0xfcc0011d
Condition Register: 0x44000080
Data storage interrupt Register: 0x000000a0
Task: 0x1c2f2f8 "abScan00"
filename="../taskwd.c" line number=175
task 1c2f2f8 abScan00 suspended
initPeriodic: menuScan not present
value = 0 = 0x0
If anyone else has run into these problems with the PowerPC
I'd appreciate the any insite you gained.
       - Thanks,
            Kristi Luchini
Re: VXI Kinetic Systems V151 cpu - PowerPC Andrew Johnson
Prev: Re: mv162 hangs on reboot Garrett D. Rinehart
Next: Re: VXI Kinetic Systems V151 cpu - PowerPC Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: IOC Crash with CA Messages saa
