1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CA question (caRepeater)
To: <[email protected]>
Cc: "EPICS-tech-talk" <[email protected]>, "Ken Evans" <[email protected]>
Date: Tue, 21 Mar 2000 11:16:15 -0700
Ralph,
> I have a machine with six network interfaces to six different subnets.
> I'm running six CA Proxy Gateways on that machine --- one for each
> subnet. All these Gateways differ on the client side, i.e. each Gateway
> has a different EPICS_CA_ADDR_LIST, but these settings aren't disjunct
> (each Gateway mirrors channels from an arbitrary number of the five
> other subnets).
> How should I start caRepeater(s) to handle this situation correctly?
If all of these servers are on the same port then there will be only one
CA repeater per client host.
The CA repeater is a client side beast. It is started automatically by the
client and it normally requires no special configuration if it can be found
by the client in its path.
However, there is a known problem with the new ca server library which I have
mentioned earlier on tech-talk. The problem is that if you run multiple ca servers
on the same port on the same host then CA clients will see beacons from all of
these servers as one beacon source. This causes the clients to perceive this
beacon source's period to be irregular and therefore they are always concluding
that there is a new server on the network. The result is that all clients with
unresolved channels will, in unison, periodically reset their search interval
to 0.5 seconds and then exponentially backoff to a longer interval.
*** This will occur only on the subnets that the multiple servers ***
*** on the same host and port are attached to.                    ***
A fix for this problem is on my task list.
On a related topic, it is possible for one CA server to
attach to a list of network interface cards specified by IP address
in an environment variable (see the doc in CONFIG_ENV), but the gateway
appears to have limitations which prevent this.
It should be in principal possible to run one gateway which
attaches its server to some set of network interface cards and its client
to some other non-intersecting set of network interface cards and therefore
there would be no need for multiple gateways per host.
Note also that due to limitations in most IP kernels all of the multiple
servers on one host will receive all broadcast messages, but only one
of the servers will receive unicast messages. This implies that if
EPICS_CA_ADDR_LIST has a unicast address (the IP address of a single host)
then only one server will be contacted at this address.
Jeff
RE: CA question (caRepeater) Ralph . Lange
Prev: Summary of ethernet switch discussion john sinclair
Next: getting record type john sinclair
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: CA question (caRepeater) Ralph . Lange
