1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Summary of ethernet switch discussion
To: tech talk <[email protected]>
Date: Mon, 20 Mar 2000 18:26:12 -0500 (EST)
The following summarizes the ethernet switch discussion:
Man/Model		Problems
Cisco 2912		None
Cisco 2916M		Random disconnections
			(This was reported by a non-EPICS user
                         (Inland Steel Co.) who uses many Cisco 29xx
                         devices)
Cisco 2924		None
Cisco 35xx		None
Cabletron SS2200	None
Cabletron SS6000	None
3COM 3900		large number of errors can cause switch
			to stop working (prior to firmware upgrade)
Other comments:
John Hammonds
We have found that some NICs have trouble deciding for 10 or 100 Mbit.
Esp. PC card NICs.  This is probably a problem with the NIC though.
Paul Sichta
Our only "network problem" was with the CA broadcast; The AB PLC-5/40E
(Model # 1785L40E) will temporarily disconnect (minutes, as I recall) from
the network if there is "too much" network traffic.  We have a lot of
traffic due to the broadcasts when people launch medm screens, as well as
other CA client activity.
The drop out problem was attributed to a "Throttle Back " feature
built in the ethernet PLC's so that the PLC process has priority over
E-net traffic.
(My comment) This is, of course, Allen-Bradley's problem. We have had
some problems with Allen-Bradley PLCs interacting with Windows broadcasts.
Bobby Whitus
We are currently using 3COM 3900s as our top level switches.  These
switches have 36 10/100 ports and up to 3 Gigabit ports. Overall they
work well..
We have seen problems where a large number of errors on a port could cause
to switch to stop working.  We recently installed a new firmware version
that will isolate ports with excessive errors.  We have not seen any
problems since then.
This model is a couple of years old.  It provided the best value for our
needs when we purchased them.  If I were doing it again today, I would
look at the new CISCO 10/100/1000 switches.
Pete Jemian
Cisco 3524-XL-A
Just received three of them
Easy to set up, 24 ports each, auto-negotiating
Each switch provides a WWW server for configuration management
Also can telnet into the switch
Also provides 2 each gigabit uplinks (GBIC)
Can't tell you about performance yet
Bought them on recommendation of Steve Wasserman, COM-CAT (our neighbor)
Thanks to all who responded.
John Sinclair
[email protected]
Oak Ridge National Lab
865-576-6362   865-574-1268 (fax)
Prev: Backward compatibility problems in LanGPIB Version 2.4 Benjamin Franksen
Next: RE: CA question (caRepeater) Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Extended talker/listener support in LanGPIB Version 2.4? Eric Norum
