Andrew Johnson wrote:
> Thanks for the reply. I have added a bunch of #includes to
> devCommonGpib.h - IMHO if a header file requires declarations from other
> headers it should include those itself. In my case I had to add dbScan.h
> (for IOSCANPVT) and the xxRecord.h headers (my device doesn't need them
> all so some like eventRecord weren't included by the devXx.c file and
> caused warning messages). I also notice that the struct devGpibParmBlock
> has renamed the old member dmaTimeout to timeout (which doesn't quite
> match the documentation's claim of complete backwards compatibility for
> old device support).
Korhonen Timo wrote:
> I was installing the latest version of the lanGPIB driver for tests
> with the newest EPICS release (3.13.2). I stumbled on compilation
> of some old drivers that come with the release.
> I would like to confirm if the (quick) fixes I made to get the modules
> to compile make sense.
> Fix one:
> compiler stumbled at a place where IOSCANPVT was not defined. I added
> #include <dbScan.h>
> where IOSCANPVT is declared as a pointer to void.
> Fix two:
> the compiler complained about a missing member (dmaTimeout) in the
> structure of type devGpibParmBlock. A comparison with the older version
> showed that this has been renamed to timeout. Is it OK to change the
> original source dmaTimeout -> timeout?
> (like
> devSupParms.dmaTimeout = DMA_TIME;
> to
> devSupParms.timeout = DMA_TIME;
Shame on me!
Yes, these changes are correct and necessary for version 2.4. I
apologize for the inconvenience this has caused. I have made a patched
version (2.4.a) that has
- all the necessary #includes
- a macro for the dmaTimeout structure tag
so that compatibility to old device supports is restored. This version
also includes a number of other bug-fixes included. See release notes
for 2.4.a. For completeness, I also added some of the older versions of
lanGpib to the web-page for download.
Ben
P.S.: The 'dmaTimeout -> timeout' problem appears only if you use newer
versions of EPICS base. Marty fixed the GPIB device supports in base to
get around a compiler bug in the newest vxWorks release. In the original
versions, the assignments to the devSupParms structure was done by
aggregate initialization which doesn't mention the tag name. I didn't
realize this at the time Marty announced his changes.
P.P.S.: Sorry for the delayed answer.
P.P.P.S.: The 'unbundled' version is still not ready yet :(
The Notorious Neb Nesknarf
- Extended talker/listener support in LanGPIB Version 2.4? Eric Norum
ethernet switches john sinclair
Summary of ethernet switch discussion john sinclair
<2000>
2025
2026
<2000>
2025
2026
