1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS R3.13.1 and Power PC
To: [email protected]
Date: Wed, 22 Mar 2000 11:34:25 +0100 (MET)
Hi all,
I work with EPICS R3.13.1, vxWorks 5.3.1.
I started to work with Power PC board (mv2306). When I tried to build
EPICS base I got following compilation error in base/rsrv:
gmake -C O.mv2306 -f ../Makefile.Vx T_A=mv2306 BUILD_TYPE=Vx install
gmake[1]: Entering directory `/import/epixF/solaris2/mks/slava/EpicsR3.13.1/bas
e/src/rsrv/O.mv2306'
rm -f camessage.o
/usr/wind/host/sun4-solaris2/bin/ccppc -B/usr/wind/host/sun4-solaris2/lib/gcc-l
ib/ -nostdinc -ansi -pedantic -O2 -fstrength-reduce  -Wall  -UUNIX -DCPU=PPC603
 -mcpu=603 -DCPU_FAMILY=PPC603  -DvxWorks -DV5_vxWorks -fno-builtin  -I. -I.. -
I../../ca  -I../../../include -I../../../include/os/vxWorks -I/usr/wind/target/
h   -c  ../camessage.c
../camessage.c: In function `write_notify_action':
../camessage.c:952: warning: implicit declaration of function `dbNotifyCancel'
../camessage.c:1003: warning: implicit declaration of function `dbPutNotifyMapType'
../camessage.c:1010: warning: implicit declaration of function `dbPutNotify'
../camessage.c: In function `send_err':
../camessage.c:1878: incompatible types in assignment
../camessage.c: At top level:
../camessage.c:53: warning: `sccsId' defined but not used
../server.h:46: warning: `serverhSccsId' defined but not used
../camessage.c:2204: warning: `casMalloc' defined but not used
gmake[1]: *** [camessage.o] Error 1
gmake[1]: Leaving directory `/import/epixF/solaris2/mks/slava/EpicsR3.13.1/base/src/rsrv/O.mv2306'
gmake: *** [install.mv2306] Error 2
the code line is:
                        logMsgArgs[i] = va_arg(args, int);
I didn't have such error when I built EPICS for mv162.
In tech-talk archives I've found the report of Nobory Yamamoto , where
were listed all remarked problems for Power PC EPICS (Beta12). Along with
other problems it was  mentioned there:
> 1-4) va_list in errPrintfVX.c.
> In 68K compiler, va_list is "typedef"-ed as pointer type, while PPC
>compiler "typedef" va_list as an array type. There is a code segment
>in src/libCoom/errPrintfVX.c which assgined "va_list" value
>to a "va_list" variable.
> In 68K compiler, it is a simple pointer assignment. In PPC compiler,
>it turns to be an array assginment which is not allowed in the
>current compiler.
In R3.13.1 errPrintfVX.c module doesn't exist, it was completely rewritten
by M.Kraimer. But in rsrv/camessage.c module still exist codes dealing
with va_list and cause compilation error for PPC architecture.
Best regards,
V.Korobov
e-mail: [email protected]
Re: EPICS R3.13.1 and Power PC Andrew Johnson
Prev: RE: CA question (caRepeater) Ralph . Lange
Next: Re: Who is using what EPICS version Janousch Markus
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: compiler bug in unpatched Solaris C++ 5.0, Visual C++ Kay Kasemir
Next: Re: EPICS R3.13.1 and Power PC Andrew Johnson
